Reply 20 of 50, by PCBONEZ
wrote:wrote:Just FYI for the general population. - A public service announcement? […]
wrote:@mockingbird:....... The old glue was also removed and fresh white glue was applied in its place .........
The usual purpose of the glue is to hold the parts in place until the soldering is complete.
It's presence is actually a bad thing as it reduces component cooling. (Reduces exposure to air flow.)
It doesn't need to be replaced EXCEPT in the case where components may move and short each other out.~~~~~~~
That Enermax PSU looks like a winner post an easy recap.
.I think you are the right person to answer my next question:
I somehow remember that sometimes the glue was used to lessen excess sounds, preventing parts from vibrating and/or lessen or dampen the noise of coil whine. Is this correct, or have I just been misinformed or have I just made a wrong assumption? I can't remember how I got that bit of memory in my head though, but I might as well ask right now and "update" my own memory 😉
I imagine some companies do that with reducing noise as their intention but unless they are using some problematic parts (like cheap toroids that aren't wound tight enough) I can't see doing it.
Personally, when I have to work on something, I remove as much of it as I can and put back as little as possible.
I've never had it create a noise problem yet. I suppose it could and I just haven't experienced it.
I think I'll stick with what I've been doing and should a noise issue ever come up I'll add some silicon later.
Actually typical glue or silicon sealer/caulk (what most people including many low-end companies and myself use) is not the correct stuff.
The correct product would be certified as non-conductive.
It is around but harder to find. Usually requires research (because the damned labels often don't say) and a mail order to get some.
I -have- heard of such noise issues several times on CCFL inverter boards for LCD screens (including laptops) but it's not super common. Just occasional.
LED backlight screens don't use that high frequency type of inverter so they shouldn't have the problem.
There is an issue with Enermax and glue that I forgot about until a few minutes ago.
The Liberty and Noisetaker models (possibly other same vintage models) had issues when the glue got old. It would become conductive as it aged.
As they were sometimes sloppy with the glue some units had it all over the leads on the big diodes (those after the main transformer) and it eventually caused a short which literally burned up the PSU.
Badcaps.net had a thread on the problem with some good photos but currently BCN is down.
[EDIT] BCN is back up. Here's the link: http://www.badcaps.net/forum/showthread.php?t=5466
