First post, by Tetrium
That's the question. This is one of those things that has been on the back of my mind for a long time now and the idea of tweaking with BIOS files has always seemed like an interesting thing to do, along with the troubles it can save me when wanting to try different things out.
Hardware is nice, but having the right tools is just as important.
So I have basically 2 questions:
Which ones should/could I get and which ones would be advisable? It can't be too costly though, I really can't spend €300 on such a thing (no idea if the cheaper ones can be worth it).
I'd prefer to buy one form a shop in The Netherlands (I'd only ebay one if I really can't get around it).
Please feel free to share your experiences with them to me, this can help me make a decision 😀
My retro rigs (old topic)
Report spammers here!
Reply 1 of 18, by PhilsComputerLab
I have a Genius G540, I used it for flashing BIOS chips.
YouTube, Facebook, Website
Reply 2 of 18, by Tetrium
Flashing BIOS chips is actually my main reason why I'm contemplating getting one. Thanks, I'll take a look at the one you have.
Reply 3 of 18, by keropi
TL866CS: cheap and supports GAL burning as opposed to willem programmers and their usb derivatives.
http://www.autoelectric.cn/minipro/miniprosupportlist.txt
Reply 4 of 18, by Tetrium
Thanks! Checking this one out also now.
I'm also reading up a bit and it seems I have quite a lot to learn. I do recognize the hardware but the software and technical data is mostly new to me, so feel free to tell me all you know! 😜
Edit:
Yours seems to come with a load of adapters as well, seems very handy!
Reply 5 of 18, by PhilsComputerLab
I sent you a PM with an early access, for VIP, video 🤣
Reply 6 of 18, by Tetrium
Lol, ok 😜
Do you by any chance happen to have a vid about using a tool like this? 😀
Reply 7 of 18, by keropi
@Tetrium
nah, rom burning is easy if you make sure the programmer supports the device you want to burn and you have the needed adapter (IF necessary).
I have both a GQ-3X and the 866CS , both need adapters for some bigger eproms (or eproms that are not DIP sized) but the 866CS does not need external PSU, supports more devices (GALs!!!!) and has 74xxx logic IC testing functionality. It's a winner for me.
Reply 8 of 18, by PCBONEZ
I am no expert here. Never personally owned one. Have been shopping/reading up on them though.
TL866A is what I've been looking at. Same as TL866CS but additionally supports ICSP.
The reason is it seems to support the widest range of ICs and I wanna play with more than just BIOS.
This one comes with -all- the adapters. http://www.ebay.com/itm/201448006503
Been on my shopping list a while but I probably won't buy until I actually need it for something.
The Genius G540 looks pretty good too if it does the ICs you want.
Reply 9 of 18, by Tetrium
Not needing external PSU is a nice bonus (I noticed I liked my external non-PSU'ed HDDs and ZIP drives a lot more than the ones that have an external PSU).
Obviously I'd want as much compatibility as possible, but I'd mostly want one that can handle the older chips of, say, roughly (s)s7 area (both mobos and graphics cards) but I'd prefer one that can handle 486 and s939-era stuff as well (if only for extracting the flash file).
The one posted by PCBONEZ seems like the one to have, but it's quite costly (I'd need to eat bread for a couple weeks 🤣) though I do know that sometimes it's better not to skimp on an investment.
Thanks you 2 😀
Reply 10 of 18, by keropi
well, for retro reasons you don't need the A model (meaning the ICSP port - there is a hack to convert the CS to A model btw 😉 ) or all these expensive adapters. A single CS and a couple of PLCC adapters will cost 60-70$ and you can get adapters on a per-need basis.
All programmers mentioned here have no problems with old 8/16bit eproms. Any will serve you well.
Reply 11 of 18, by alexanrs
I have a TL866CS and I like it. I have even programmed PICs with it.
Reply 12 of 18, by PCBONEZ
The adapters are more costly if bought separately later on (assuming they are still available) plus you have to wait again.
I'd rather save up and get the whole kit-n-caboodle in one shot.
(Look! I used caboodle in a sentence!)
Reply 13 of 18, by Tetrium
This is very true. I'll need to see when and where I will be getting one, so I have ample time to see which one I will be needing to look out for, cheers all! 😀
Reply 14 of 18, by Malvineous
I just happened to have purchased a TL866A myself, but haven't had a chance to use it yet. I'm hoping it will make it a bit easier to flash EEPROMs for things like XTIDE. I'm also wondering whether it will be possible to test 4164 DRAM chips in it, because I have an 8-bit VGA card with faulty video memory, so it'd be nice to have a way of testing out those chips so that I only have to replace the likely one or two that don't work.
Reply 15 of 18, by alexanrs
I used my TL866CS to diagnose my 486's faulty cache (managed to narrow it down to the TAG RAM chip), and if I remember correctly, there are some DRAM ICs in their app's list.
Reply 16 of 18, by carlostex
Go for the TL866CS. I have a Genius G540 and although it works well and supports a lot more devices i will ever need its software is subpar and has problems with fast machines. Fortunately it still works well with my core 2 duo desktop but i could never make it work on I7 PC's.
TL866's seem to have frequent software updates.
Here's a review from EEVBLOG:
https://www.youtube.com/watch?v=FLG03f_ua5g
Reply 18 of 18, by Tetrium
Thanks all for the suggestions!
Now I have a much better idea what I should be getting 😀
Lo Wang wrote:
Get one of these, then sell it to me 😎
But can it run Unreal? 😁
