First post, by Anonymous Coward
- l33t++
In my collection I had two cards from Hercules which use different chipsets but have similar components. Both of them stopped working, and were exhibiting similar behaviour: normally showing a black screen, but sometimes spewing random ASCII characters. I was ready to write them off, but I spent a little time on them to see if I could bring them back to life. What I discovered is that the solder holding the yellow surface mount resistor packs had gone bad. Using a solder iron I was able to reflow the solder, and now both cards are working again. I suspect this is probably a common problem with VLB cards, especially since the edge connectors are so long; it causes slight warping of the PCB when going in and out of the slot.
If you have dead VLB cards, don't throw them out. Try applying pressure to various ICs and different points on the circuit board during boot up to see if you can isolate the loose connection.
For the longest time I thought my VLB motherboard was killing my cards.
I also have a Cardex Challenger like this that I have not been able to get working:
I can hear the memory counting, and the system boots up but the screen remains black. This card has very few surface mount devices, so I'm not sure what's going on.
