needs to see cd in drive
First post, by hoodleehoo
I'm using dosbox to try and install football pro 96. But the game requires that the cd is in the cd drive. I have the old cd but my laptop doesn't have a disk drive. So, I copied the cd into an .iso which I then mounted via windows 8. I was able to install the game correctly from this mounted disk. However, I can't play the game because it says the cd was not found and that I should check my cd drive.
I tried mounting the iso drive as the d drive in dosbox as well as mounting my actual c drive as the c:\. But it still isn't finding it.
Is there a workaround for this??
Reply 1 of 11, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
You may have to rereip the CD as a bin/cue image. It might be that it has audio tracks but the iso format only images the data track. Alcohol 120% percent does a good job for that and you don't need to buy it for that.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 11, by collector
Do a full install and copy the SMK folder from the CD to the installed folder. Mount you drives in the [autoexec] of the conf with:
[autoexec]
cls
@ECHO OFF
mount c .
mount d . -t cdrom -ioctl -label FPSFB_96
c:
cd \
call HIKE.BAT
exit
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 3 of 11, by hoodleehoo
Thanks for getting back to me. I downloaded alcohol 120% but don't see an option for making a bin/cue image. I can make a .mdf file. Will that be the same thing? It has two other options as well but don't remember them as it's currently creating the .mdf
Reply 4 of 11, by hoodleehoo
collector wrote:
Do a full install and copy the SMK folder from the CD to the installed folder. Mount you drives in the [autoexec] of the conf wi […]
[autoexec]
cls
@ECHO OFF
mount c .
c:
cd \
call HIKE.BAT
exit
Okay, first off, your avatar. Is that LSL, Roger Wilco, and King Graham??? If so, #1 huge props from me!!! #2 Who is the other one? Police Quest? I had totally forgot about Police Quest. Literally hadn't thought of that in probably 15 years.
Secondly, what you are saying sounds like what I need to do. I'm not sure I follow it, though, as I'm definitely a noob. Could you dumb it down a bit? I understand copying the SMK to the install folder (does it matter where?). I don't understand the second part though.
Reply 5 of 11, by collector
It is Larry, Sonny Bonds, Roger Wilco and Sir/King Graham.
Give me some time and I'll do a new installer for the game. I guess that if you have no CD drive you should be able to mount your image with Daemon Tools to run the installer or install the game on a PC that has a drive and transfer the installed folder to your laptop.
Reply 6 of 11, by hoodleehoo
That would be awesome!!
I got it all installed, but it still requires the cd to be in the drive before it plays. Presumably this was for copyright protection? I created an .iso image of the disc and mounted it as a drive using windows 8 (now 10 since I just upgraded), but it still isn't seeing the cd when I try to actually run the game.
Reply 7 of 11, by hoodleehoo
Okay, I'm mounting the e drive to d:\ but when I try to change to the d: drive it says the directory doesn't exist. It went like this...
C:\> d:
Drive d: does not exist!
You must mount it first
C:\> mount e d:\
Drive E already mounted with local directory d:\
C:\> d:
Reply 9 of 11, by Dominus
DOSBox Moderator
hoodleehoo wrote:
Okay, I'm mounting the e drive to d:\ but when I try to change to the d: drive it says the directory doesn't exist. It went like […]
C:\> d:
C:\> mount e d:\
C:\> d:
You got those commands backwards:
The first letter is the drive it should be in Dosbox, the second letter or path is the real drive or path you want to use for the drive in Dosbox.
So,
mount e d:\
makes your real drive D appear as the "virtual" drive E in Dosbox.
I guess you wanted
mount d e:\
I'll look into the Alcohol image making. Mdf is definitely the wrong format.
Reply 10 of 11, by hoodleehoo
Oh, I need to use the -t cdrom -label fpbro96 for it to work.
Collector, is there a way to make it so that it automatically types all that in (all the mounting) or do I just have to do that every time. It looked like your post above was indicating a way to make it auto execute.
Reply 11 of 11, by hoodleehoo
Oh, I just saw your link collector that is awesome! You are my hero. 😀
