Best SB Pro compatible 16-bit cards?
Reply 20 of 23, by gdjacobs
PhilsComputerLab wrote:
You should be very happy with that card!
For Windows 98, don't use the drivers on the CD, install the latest Yamaha drivers: http://www.philscomputerlab.com/audician-32-plus.html
What is nice is that it also configures MS-DOS mode for you.
Could you please post the DOS mode drivers for those who aren't running Win9x? I understand the driver installer is Windows only.
Reply 21 of 23, by PhilsComputerLab
The pure DOS drivers are on the CD image you can download.
Reply 22 of 23, by gdjacobs
Excellent. Thanks for clarifying that.
Reply 23 of 23, by Tertz
Seems some games may to get problems with playing FM on 1st and DAC of 2nd SB compatible cards
"And sometimes a game would not play sound on a card that had been selected by setting blaster variable and pointing at the right resources."
Yamaha YMF-724 DOS Sound Blaster Setup Assistance Needed
Also, as Emu chip was reported having sometimes issues, hence AWE32-SB32 are doubtful and the only reliable way stays noisy SB16 cards. damn
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
