First post, by Indrid Cold
I think it's an interesting configuration, especially regarding to the cause of the problems I encountered while reconfigure and cleaning up everything, as well as guessing correct identification of the CPU.
The case is a nice full tower, vintage but also very robust - the thing that immediately (as I have already shown in another section of the forum) intrigued me was the presence of a tape drive for backup, but not the tapes that I've seen before, but apparently common cassette tapes, with its proprietary controller board. The motherboard is a PC Chips M919, with PCI bus, ISA, VLB, 16MB SIMM RAM, and processor with active heatsink, which immediately made me think of a fairly-high-clocked 486. The CPU then has proved to be an AMD AM486DX4-100 v3.3 - a CPU with good performance and very competitive at the times, able to overcome in the performance the very first Pentium CPUs - in contrast to common DX4 486, the multiplier for this CPU is x3, so with FSB @33MHz, although versions released after had FSB jumped to 40MHZ. The strange thing is that POST signaled the CPU as DX2-100 o_o
After careful investigation and monitoring of the jumpers about configuration of CPU/FSB clock, I found that who has mounted originally this computer had incorrectly configured CPU with FSB @50MHZ, setting x2 as multiplier -___-
So, for all the time of its use (accounting backup - installed operating system: ScoUnix), this PC was used with CPU set with higher FSB (50 instead of 33 MHz) to that for which it was created.
Other present drives are a 5 1/2 floppy drive, 1.44MB floppy, 1.2GB Seagate hard disk (replaced with IDE2CF adapter and 2GB CF with MS-DOS 6.22) to which I later added a Philips DVD, with yellow bezel which seems to be comfortable with the rest. The video card that was present when I was given the computer was REALTEK Quadtel 87-90 RTG 3105 IEH, that I replaced with a common but compatible S3 Virge DX. The audio board was not present, so I chose one of my SoundBlaster 16 models, the CT2890.
IMG_3996.jpgIMG_3995.jpgIMG_3976.jpgIMG_3978.jpgIMG_3981.jpgIMG_3982.jpgIMG_3983.jpgIMG_3984.jpg
Reply 1 of 17, by gdjacobs
Does the PC Chips board have real cache installed?
Reply 2 of 17, by Indrid Cold
Yes, I found a bank already installed, POST reports 256kb
Reply 3 of 17, by gdjacobs
It's PC Chips, so be sure to double check with independent tools. They're one step away from the guy in the white van in the corner parking lot. 😐
Reply 5 of 17, by Indrid Cold
Sure, I'll do more testing as soon as possible
Reply 7 of 17, by mrau
Indrid Cold wrote:
What kind of module is it?
its cache that usually isn't fake
Reply 8 of 17, by Skyscraper
The utility cachechk will show if there is any L2 cache in the system.
The cache sticks are normally real but I have heard about fake ones, the soldered cache on many PC-Chips 486 boards are often fake.
Reply 10 of 17, by Skyscraper
gdjacobs wrote:
https://en.wikipedia.org/wiki/White_van_speaker_scam
https://www.youtube.com/watch?v=i3B_KKyntQE
PC Chips and the "white van scams" have little in common. PC Chips motherborads with fake cache might be slower than boards with real cache but we are talking about ~10% in performance difference not people selling useless junk as high end audio gear.
There is a reason PC Chips boards are so common, there were cheap. 😀 The M919 is considered to be one of the best 486 overclocking motherboards ever made and with a real cache stick it's also pretty fast.
Reply 11 of 17, by Indrid Cold
Thanks for your great information! I hope it is real cache then...
Reply 12 of 17, by leileilol
You can usually make up for it by putting an AM5x86-P75 in and clocking that 40x4 and setting your memory wait states to 0 or 1 (which can cost you the ability to soft reset, so don't set that until your drivers are all installed 😀 ). At that point it's a 59.79 in speedsys, and Quake is definitely in the realm of being playable to the end.
My personal bad experience with M919s had to do with faulty serial support so my mouse didn't work half the time, and I think that trumps the cache issue.
FUCK "AI"
Reply 13 of 17, by mrau
you could've just went on and installed a usb controller card ;p
Reply 14 of 17, by Skyscraper
A serial port card would have been a better choice as I think he wanted to use the mouse in DOS. 😉
I use a serial port card all the time when testing/benching late Socket-3 and Socket-5/7 motherboards as I cant be bothered with finding a working serial port bracket, there are at least two different pinouts.
edit spelling
Reply 15 of 17, by mrau
is a serial mouse not a bigger burden on the system than a usb or ps/2 one?
Reply 16 of 17, by leileilol
easier said than done, and it didn't work.
(If anyone can get a VIA USB card going on a M919, with both usb storage and usb mice, i'd like to know what you did because i've lost my patience years ago)
FUCK "AI"
Reply 17 of 17, by Indrid Cold
USB mouse working under MS-DOS? I don't think so... FreeDOS supports them instead, by emulation. I'm currently using a serial one, Logitech model
