First post, by pxp
Hi All,
i have the strange thing that when i am running a DOS application and go to a directory and see all the files, and then in Windows Explorer add some files to that same folder, i cannot see the new just-copied files.
Going back to another directory and then back to original still does not show the files. F5 has no use either 😜
Even going out the browser mode of the application and going back to that folder still doen not change anything.
The only 100% working method is leaving the application and going back to the folder,...but that is not a nive and 'normal'way.
Deleting and moving files is working normal, but creating a new folder or adding a file is only visible when quit and run the application again.
Waat's the catch here, what am i overlooking.
Could not find anything on the forum,...so,...plz help me out here...
specs:
Win2000 SP4
DosBOX 0.63
application running from a NTFS drive
client has administrator rights
Thanx in advance,
pxp
