Emulating MT-32 on an RPi2
Reply 40 of 292, by gdjacobs
Two ways to proceed on the Pi zero:
Recompile without flags and test.
Recompile with debug symbols and fire up gdb. This can be done by changing the CMAKE_BUILD_TYPE to RelWithDebInfo
Reply 41 of 292, by stamasd
Here's every package I have installed on the C2
silviu@odroid-jessie64:~$ dpkg-query -l
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii acl 2.2.52-2 arm64 Access control list utilities
ii adduser 3.113+nmu3 all add and remove users and groups
ii apt 1.0.9.8.3 arm64 commandline package manager
ii apt-utils 1.0.9.8.3 arm64 package management related utilit
ii base-files 8+deb8u3 arm64 Debian base system miscellaneous
ii base-passwd 3.5.37 arm64 Debian base system master passwor
ii bash 4.3-11+b1 arm64 GNU Bourne Again SHell
ii bash-completio 1:2.1-4 all programmable completion for the b
ii binutils 2.25-5 arm64 GNU assembler, linker and binary
ii bsdmainutils 9.0.6 arm64 collection of more utilities from
ii bsdutils 1:2.25.2-6 arm64 basic utilities from 4.4BSD-Lite
ii build-essentia 11.7 arm64 Informational list of build-essen
ii busybox-initra 1:1.22.0-15u arm64 Standalone shell setup for initra
ii bzip2 1.0.6-7+b3 arm64 high-quality block-sorting file c
ii cmake 3.0.2-1 arm64 cross-platform, open-source make
ii cmake-data 3.0.2-1 all CMake data files (modules, templa
ii coreutils 8.23-4 arm64 GNU core utilities
ii cpio 2.11+dfsg-4. arm64 GNU cpio -- a program to manage a
ii cpp 4:4.9.2-2 arm64 GNU C preprocessor (cpp)
ii cpp-4.9 4.9.2-10 arm64 GNU C preprocessor
ii cron 3.0pl1-127+d arm64 process scheduling daemon
ii cvs 2:1.12.13+re arm64 Concurrent Versions System
ii dash 0.5.7-4+b3 arm64 POSIX-compliant shell
ii debconf 1.5.56 all Debian configuration management s
ii debconf-i18n 1.5.56 all full internationalization support
ii debian-archive 2014.3 all GnuPG archive keys of the Debian
ii debianutils 4.4+b3 arm64 Miscellaneous utilities specific
ii dialog 1.2-20140911 arm64 Displays user-friendly dialog box
ii diffutils 1:3.3-1+b3 arm64 File comparison utilities
ii dmsetup 2:1.02.90-2. arm64 Linux Kernel Device Mapper usersp
ii dpkg 1.17.26 arm64 Debian package management system
ii dpkg-dev 1.17.26 all Debian package development tools
ii e2fslibs:arm64 1.42.12-1.1 arm64 ext2/ext3/ext4 file system librar
ii e2fsprogs 1.42.12-1.1 arm64 ext2/ext3/ext4 file system utilit
ii file 1:5.22+15-2+ arm64 Determines file type using "magic
ii findutils 4.4.2-9+b3 arm64 utilities for finding files--find
ii fontconfig 2.11.0-6.3 arm64 generic font configuration librar
ii fontconfig-con 2.11.0-6.3 all generic font configuration librar
ii fonts-dejavu-c 2.34-1 all Vera font family derivate with ad
ii freeglut3:arm6 2.8.1-2 arm64 OpenGL Utility Toolkit
ii freeglut3-dev: 2.8.1-2 arm64 OpenGL Utility Toolkit developmen
ii g++ 4:4.9.2-2 arm64 GNU C++ compiler
ii g++-4.9 4.9.2-10 arm64 GNU C++ compiler
ii gcc 4:4.9.2-2 arm64 GNU C compiler
ii gcc-4.8-base:a 4.8.4-1 arm64 GCC, the GNU Compiler Collection
ii gcc-4.9 4.9.2-10 arm64 GNU C compiler
ii gcc-4.9-base:a 4.9.2-10 arm64 GCC, the GNU Compiler Collection
ii gir1.2-atk-1.0 2.14.0-1 arm64 ATK accessibility toolkit (GObjec
ii gir1.2-freedes 1.42.0-2.2 arm64 Introspection data for some FreeD
ii gir1.2-gdkpixb 2.31.1-2+deb arm64 GDK Pixbuf library - GObject-Intr
ii gir1.2-glib-2. 1.42.0-2.2 arm64 Introspection data for GLib, GObj
ii gir1.2-gtk-2.0 2.24.25-3 arm64 GTK+ graphical user interface lib
ii gir1.2-pango-1 1.36.8-3 arm64 Layout and rendering of internati
ii git 1:2.1.4-2.1+ arm64 fast, scalable, distributed revis
Show last 524 lines
ii  git-man        1:2.1.4-2.1+ all          fast, scalable, distributed revis
ii gnupg 1.4.18-7+deb arm64 GNU privacy guard - a free PGP re
ii gpgv 1.4.18-7+deb arm64 GNU privacy guard - signature ver
ii grep 2.20-4.1 arm64 GNU grep, egrep and fgrep
ii groff-base 1.22.2-8 arm64 GNU troff text-formatting system
ii gzip 1.6-4 arm64 GNU compression utilities
ii hostname 3.15+b2 arm64 utility to set/show the host name
ii htop 1.0.3-1 arm64 interactive processes viewer
ii ifupdown 0.7.53.1 arm64 high level tools to configure net
ii init 1.22 arm64 System-V-like init utilities - me
ii init-system-he 1.22 all helper tools for all init systems
ii initramfs-tool 0.120+deb8u1 all generic modular initramfs generat
ii initscripts 2.88dsf-59 arm64 scripts for initializing and shut
ii insserv 1.14.0-5+b2 arm64 boot sequence organizer using LSB
ii iproute2 3.16.0-2 arm64 networking and traffic control to
ii iptables 1.4.21-2+b1 arm64 administration tools for packet f
ii iputils-ping 3:20121221-5 arm64 Tools to test the reachability of
ii isc-dhcp-clien 4.3.1-6+deb8 arm64 DHCP client for automatically obt
ii isc-dhcp-commo 4.3.1-6+deb8 arm64 common files used by all of the i
ii klibc-utils 2.0.4-2 arm64 small utilities built with klibc
ii kmod 18-3 arm64 tools for managing Linux kernel m
ii less 458-3 arm64 pager program similar to more
ii libacl1:arm64 2.2.52-2 arm64 Access control list shared librar
ii libalgorithm-c 0.09-1 all Perl module for merging hierarchi
ii libapr1:arm64 1.5.1-3 arm64 Apache Portable Runtime Library
ii libaprutil1:ar 1.5.4-1 arm64 Apache Portable Runtime Utility L
ii libapt-inst1.5 1.0.9.8.3 arm64 deb package format runtime librar
ii libapt-pkg4.12 1.0.9.8.3 arm64 package management runtime librar
ii libarchive-ext 0.72-1 all generic archive extracting module
ii libarchive13:a 3.1.2-11 arm64 Multi-format archive and compress
ii libasound2:arm 1.0.28-1 arm64 shared library for ALSA applicati
ii libasound2-dat 1.0.28-1 all Configuration files and profiles
ii libasound2-dev 1.0.28-1 arm64 shared library for ALSA applicati
ii libasyncns0:ar 0.8-5 arm64 Asynchronous name service query l
ii libatk1.0-0:ar 2.14.0-1 arm64 ATK accessibility toolkit
ii libatk1.0-data 2.14.0-1 all Common files for the ATK accessib
ii libatk1.0-dev 2.14.0-1 arm64 Development files for the ATK acc
ii libatomic1:arm 4.9.2-10 arm64 support library providing __atomi
ii libattr1:arm64 1:2.4.47-2 arm64 Extended attribute shared library
ii libaudit-commo 1:2.4-1 all Dynamic library for security audi
ii libaudit1:arm6 1:2.4-1+b1 arm64 Dynamic library for security audi
ii libavahi-clien 0.6.31-5 arm64 Development files for the Avahi c
ii libavahi-clien 0.6.31-5 arm64 Avahi client library
ii libavahi-commo 0.6.31-5 arm64 Avahi common data files
ii libavahi-commo 0.6.31-5 arm64 Development files for the Avahi c
ii libavahi-commo 0.6.31-5 arm64 Avahi common library
ii libavcodec-dev 6:11.6-1~deb arm64 Development files for libavcodec
ii libavcodec56:a 6:11.6-1~deb arm64 Libav codec library
ii libavformat-de 6:11.6-1~deb arm64 Development files for libavformat
ii libavformat56: 6:11.6-1~deb arm64 Libav file format library
ii libavresample- 6:11.6-1~deb arm64 Development files for libavresamp
ii libavresample2 6:11.6-1~deb arm64 Libav audio resampling library
ii libavutil-dev 6:11.6-1~deb arm64 Development files for libavutil
ii libavutil54:ar 6:11.6-1~deb arm64 Libav utility library
ii libblkid1:arm6 2.25.2-6 arm64 block device id library
ii libboost-iostr 1.55.0+dfsg- arm64 Boost.Iostreams Library
ii libbsd0:arm64 0.7.0-2 arm64 utility functions from BSD system
ii libbz2-1.0:arm 1.0.6-7+b3 arm64 high-quality block-sorting file c
ii libc-bin 2.19-18+deb8 arm64 GNU C Library: Binaries
ii libc-dev-bin 2.19-18+deb8 arm64 GNU C Library: Development binari
ii libc6:arm64 2.19-18+deb8 arm64 GNU C Library: Shared libraries
ii libc6-dev:arm6 2.19-18+deb8 arm64 GNU C Library: Development Librar
ii libcaca-dev 0.99.beta19- arm64 development files for libcaca
ii libcaca0:arm64 0.99.beta19- arm64 colour ASCII art library
ii libcairo-gobje 1.14.0-2.1 arm64 Cairo 2D vector graphics library
ii libcairo-scrip 1.14.0-2.1 arm64 Cairo 2D vector graphics library
ii libcairo2:arm6 1.14.0-2.1 arm64 Cairo 2D vector graphics library
ii libcairo2-dev 1.14.0-2.1 arm64 Development files for the Cairo 2
ii libcap2:arm64 1:2.24-8 arm64 POSIX 1003.1e capabilities (libra
ii libcap2-bin 1:2.24-8 arm64 POSIX 1003.1e capabilities (utili
ii libcgi-fast-pe 1:2.04-1 all CGI subclass for work with FCGI
ii libcgi-pm-perl 4.09-1 all module for Common Gateway Interfa
ii libclass-c3-pe 0.26-1 all pragma for using the C3 method re
ii libclass-c3-xs 0.13-2 arm64 Perl module to accelerate Class::
ii libcloog-isl4: 0.18.2-1+b2 arm64 Chunky Loop Generator (runtime li
ii libcomerr2:arm 1.42.12-1.1 arm64 common error description library
ii libcpan-meta-p 2.142690-1 all Perl module to access CPAN distri
ii libcryptsetup4 2:1.6.6-5 arm64 disk encryption support - shared
ii libcups2:arm64 1.7.5-11+deb arm64 Common UNIX Printing System(tm) -
ii libcurl3:arm64 7.38.0-4+deb arm64 easy-to-use client-side URL trans
ii libcurl3-gnutl 7.38.0-4+deb arm64 easy-to-use client-side URL trans
ii libdata-optlis 0.109-1 all module to parse and validate simp
ii libdata-sectio 0.200006-1 all module to read chunks of data fro
ii libdatrie1:arm 0.2.8-1 arm64 Double-array trie library
ii libdb5.3:arm64 5.3.28-9 arm64 Berkeley v5.3 Database Libraries
ii libdbus-1-3:ar 1.8.20-0+deb arm64 simple interprocess messaging sys
ii libdbus-1-dev: 1.8.20-0+deb arm64 simple interprocess messaging sys
ii libdebconfclie 0.192 arm64 Debian Configuration Management S
ii libdevmapper1. 2:1.02.90-2. arm64 Linux Kernel Device Mapper usersp
ii libdirectfb-1. 1.2.10.0-5.1 arm64 direct frame buffer graphics - sh
ii libdirectfb-de 1.2.10.0-5.1 arm64 direct frame buffer graphics libr
ii libdirectfb-ex 1.2.10.0-5.1 arm64 direct frame buffer graphics - ex
ii libdns-export1 1:9.9.5.dfsg arm64 Exported DNS Shared Library
ii libdpkg-perl 1.17.26 all Dpkg perl modules
ii libdrm-dev:arm 2.4.58-2 arm64 Userspace interface to kernel DRM
ii libdrm-nouveau 2.4.58-2 arm64 Userspace interface to nouveau-sp
ii libdrm-radeon1 2.4.58-2 arm64 Userspace interface to radeon-spe
ii libdrm2:arm64 2.4.58-2 arm64 Userspace interface to kernel DRM
ii libedit2:arm64 3.1-20140620 arm64 BSD editline and history librarie
ii libegl1-mesa:a 10.3.2-1+deb arm64 free implementation of the EGL AP
ii libelfg0:arm64 0.8.13-5 arm64 an ELF object file access library
ii liberror-perl 0.17-1.1 all Perl module for error/exception h
ii libestr0 0.1.9-1.1 arm64 Helper functions for handling str
ii libexpat1:arm6 2.1.0-6+deb8 arm64 XML parsing C library - runtime l
ii libexpat1-dev: 2.1.0-6+deb8 arm64 XML parsing C library - developme
ii libfcgi-perl 0.77-1+b1 arm64 helper module for FastCGI
ii libffi6:arm64 3.1-2+b2 arm64 Foreign Function Interface librar
ii libflac-dev:ar 1.3.0-3 arm64 Free Lossless Audio Codec - C dev
ii libflac8:arm64 1.3.0-3 arm64 Free Lossless Audio Codec - runti
ii libfluidsynth1 1.1.6-2 arm64 Real-time MIDI software synthesiz
ii libfontconfig1 2.11.0-6.3 arm64 generic font configuration librar
ii libfreetype6:a 2.5.2-3+deb8 arm64 FreeType 2 font engine, shared li
ii libfreetype6-d 2.5.2-3+deb8 arm64 FreeType 2 font engine, developme
ii libgbm1:arm64 10.3.2-1+deb arm64 generic buffer management API --
ii libgcc-4.9-dev 4.9.2-10 arm64 GCC support library (development
ii libgcc1:arm64 1:4.9.2-10 arm64 GCC support library
ii libgcrypt20:ar 1.6.3-2+deb8 arm64 LGPL Crypto library - runtime lib
ii libgdbm3:arm64 1.8.3-13.1 arm64 GNU dbm database routines (runtim
ii libgdk-pixbuf2 2.31.1-2+deb arm64 GDK Pixbuf library
ii libgdk-pixbuf2 2.31.1-2+deb all GDK Pixbuf library - data files
ii libgdk-pixbuf2 2.31.1-2+deb arm64 GDK Pixbuf library (development f
ii libgirepositor 1.42.0-2.2 arm64 Library for handling GObject intr
ii libgl1-mesa-de 10.3.2-1+deb arm64 free implementation of the OpenGL
ii libgl1-mesa-gl 10.3.2-1+deb arm64 free implementation of the OpenGL
ii libglapi-mesa: 10.3.2-1+deb arm64 free implementation of the GL API
ii libglib2.0-0:a 2.42.1-1+b1 arm64 GLib library of C routines
ii libglib2.0-0-d 2.42.1-1+b1 arm64 Debugging symbols for the GLib li
ii libglib2.0-0-r 2.42.1-1+b1 arm64 GLib library of C routines - refd
ii libglib2.0-bin 2.42.1-1+b1 arm64 Programs for the GLib library
ii libglib2.0-dat 2.42.1-1 all Common files for GLib library
ii libglib2.0-dev 2.42.1-1+b1 arm64 Development files for the GLib li
ii libglib2.0-doc 2.42.1-1 all Documentation files for the GLib
ii libglib2.0-tes 2.42.1-1+b1 arm64 GLib library of C routines - inst
ii libglu1-mesa:a 9.0.0-2 arm64 Mesa OpenGL utility library (GLU)
ii libglu1-mesa-d 9.0.0-2 arm64 Mesa OpenGL utility library -- de
ii libgmp10:arm64 2:6.0.0+dfsg arm64 Multiprecision arithmetic library
ii libgnutls-deb0 3.3.8-6+deb8 arm64 GNU TLS library - main runtime li
ii libgnutls-open 3.3.8-6+deb8 arm64 GNU TLS library - OpenSSL wrapper
ii libgomp1:arm64 4.9.2-10 arm64 GCC OpenMP (GOMP) support library
ii libgpg-error0: 1.17-3 arm64 library for common error values a
ii libgpm2:arm64 1.20.4-6.1+b arm64 General Purpose Mouse - shared li
ii libgraphite2-3 1.3.6-1~deb8 arm64 Font rendering engine for Complex
ii libgsm1:arm64 1.0.13-4 arm64 Shared libraries for GSM speech c
ii libgssapi-krb5 1.12.1+dfsg- arm64 MIT Kerberos runtime libraries -
ii libgtk2.0-0:ar 2.24.25-3 arm64 GTK+ graphical user interface lib
ii libgtk2.0-comm 2.24.25-3 all common files for the GTK+ graphic
ii libgtk2.0-dev 2.24.25-3 arm64 development files for the GTK+ li
ii libharfbuzz-de 0.9.35-2 arm64 Development files for OpenType te
ii libharfbuzz-go 0.9.35-2 arm64 OpenType text shaping engine ICU
ii libharfbuzz-ic 0.9.35-2 arm64 OpenType text shaping engine ICU
ii libharfbuzz0b: 0.9.35-2 arm64 OpenType text shaping engine (sha
ii libhogweed2:ar 2.7.1-5+deb8 arm64 low level cryptographic library (
ii libice-dev:arm 2:1.0.9-1+b1 arm64 X11 Inter-Client Exchange library
ii libice6:arm64 2:1.0.9-1+b1 arm64 X11 Inter-Client Exchange library
ii libicu52:arm64 52.1-8+deb8u arm64 International Components for Unic
ii libidn11:arm64 1.29-1+b2 arm64 GNU Libidn library, implementatio
ii libirs-export9 1:9.9.5.dfsg arm64 Exported IRS Shared Library
ii libisc-export9 1:9.9.5.dfsg arm64 Exported ISC Shared Library
ii libisccfg-expo 1:9.9.5.dfsg arm64 Exported ISC CFG Shared Library
ii libisl10:arm64 0.12.2-2+b2 arm64 manipulating sets and relations o
ii libitm1:arm64 4.9.2-10 arm64 GNU Transactional Memory Library
ii libjack-dev 1:0.124.1+20 arm64 JACK Audio Connection Kit (develo
ii libjack0:arm64 1:0.124.1+20 arm64 JACK Audio Connection Kit (librar
ii libjasper1:arm 1.900.1-debi arm64 JasPer JPEG-2000 runtime library
ii libjbig-dev:ar 2.1-3.1 arm64 JBIGkit development files
ii libjbig0:arm64 2.1-3.1 arm64 JBIGkit libraries
ii libjpeg-dev 1:1.3.1-12 all Development files for the JPEG li
ii libjpeg62-turb 1:1.3.1-12 arm64 libjpeg-turbo JPEG runtime librar
ii libjpeg62-turb 1:1.3.1-12 arm64 Development files for the libjpeg
ii libjs-excanvas 0.r3-3 all HTML5 Canvas for Internet Explore
ii libjson-c2:arm 0.11-4 arm64 JSON manipulation library - share
ii libk5crypto3:a 1.12.1+dfsg- arm64 MIT Kerberos runtime libraries -
ii libkeyutils1:a 1.5.9-5+b1 arm64 Linux Key Management Utilities (l
ii libklibc 2.0.4-2 arm64 minimal libc subset for use with
ii libkmod2:arm64 18-3 arm64 libkmod shared library
ii libkrb5-3:arm6 1.12.1+dfsg- arm64 MIT Kerberos runtime libraries
ii libkrb5support 1.12.1+dfsg- arm64 MIT Kerberos runtime libraries -
ii libldap-2.4-2: 2.4.40+dfsg- arm64 OpenLDAP libraries
ii liblocale-gett 1.05-8+b2 arm64 module using libc functions for i
ii liblog-message 0.8-1 all powerful and flexible message log
ii liblog-message 0.10-2 all simplified interface to Log::Mess
ii liblogging-std 1.0.4-1 arm64 easy to use and lightweight loggi
ii liblognorm1:ar 1.0.1-3 arm64 Log normalizing library
ii liblzma-dev:ar 5.1.1alpha+2 arm64 XZ-format compression library - d
ii liblzma5:arm64 5.1.1alpha+2 arm64 XZ-format compression library
ii liblzo2-2:arm6 2.08-1.2 arm64 data compression library
ii libmad0:arm64 0.15.1b-8 arm64 MPEG audio decoder library
ii libmad0-dev 0.15.1b-8 arm64 MPEG audio decoder development li
ii libmagic1:arm6 1:5.22+15-2+ arm64 File type determination library u
ii libmikmod-conf 3.3.7-1 arm64 Portable sound library - developm
ii libmikmod-dev: 3.3.7-1 arm64 Portable sound library - developm
ii libmikmod3:arm 3.3.7-1 arm64 Portable sound library
ii libmnl0:arm64 1.0.3-5 arm64 minimalistic Netlink communicatio
ii libmodule-buil 0.421000-2 all framework for building and instal
ii libmodule-plug 5.1-1 all module for giving modules the ab
ii libmodule-sign 0.73-1+deb8u all module to manipulate CPAN SIGNATU
ii libmount1:arm6 2.25.2-6 arm64 device mounting library
ii libmp3lame0:ar 3.99.5+repac arm64 MP3 encoding library
ii libmpc3:arm64 1.0.2-1+b2 arm64 multiple precision complex floati
ii libmpfr4:arm64 3.1.2-2 arm64 multiple precision floating-point
ii libmro-compat- 0.12-1 all mro::* interface compatibility fo
ii libmtdev1:arm6 1.1.5-1 arm64 Multitouch Protocol Translation L
ii libncurses5:ar 5.9+20140913 arm64 shared libraries for terminal han
ii libncursesw5:a 5.9+20140913 arm64 shared libraries for terminal han
ii libnetfilter-a 1.0.2-1.1 arm64 Netfilter acct library
ii libnettle4:arm 2.7.1-5+deb8 arm64 low level cryptographic library (
ii libnewt0.52:ar 0.52.17-1+b1 arm64 Not Erik's Windowing Toolkit - te
ii libnfnetlink0: 1.0.1-3 arm64 Netfilter netlink library
ii libogg-dev:arm 1.3.2-1 arm64 Ogg bitstream library development
ii libogg0:arm64 1.3.2-1 arm64 Ogg bitstream library
ii libopenal-data 1:1.15.1-5 all Software implementation of the Op
ii libopenal-dev: 1:1.15.1-5 arm64 Software implementation of the Op
ii libopenal1:arm 1:1.15.1-5 arm64 Software implementation of the Op
ii libopenjpeg5:a 1:1.5.2-3 arm64 JPEG 2000 image compression/decom
ii libopts25:arm6 1:5.18.4-3 arm64 automated option processing libra
ii libopus0:arm64 1.1-2 arm64 Opus codec runtime library
ii liborc-0.4-0:a 1:0.4.22-1 arm64 Library of Optimized Inner Loops
ii libp11-kit0:ar 0.20.7-1 arm64 Library for loading and coordinat
ii libpackage-con 0.04-1 all List constants defined in a packa
ii libpam-modules 1.1.8-3.1+de arm64 Pluggable Authentication Modules
ii libpam-runtime 1.1.8-3.1+de all Runtime support for the PAM libra
ii libpam0g:arm64 1.1.8-3.1+de arm64 Pluggable Authentication Modules
ii libpango-1.0-0 1.36.8-3 arm64 Layout and rendering of internati
ii libpango1.0-de 1.36.8-3 arm64 Development files for the Pango
ii libpangocairo- 1.36.8-3 arm64 Layout and rendering of internati
ii libpangoft2-1. 1.36.8-3 arm64 Layout and rendering of internati
ii libpangoxft-1. 1.36.8-3 arm64 Layout and rendering of internati
ii libparams-util 1.07-2+b1 arm64 Perl extension for simple stand-a
ii libpcre3:arm64 2:8.35-3.3+d arm64 Perl 5 Compatible Regular Express
ii libpcre3-dev:a 2:8.35-3.3+d arm64 Perl 5 Compatible Regular Express
ii libpcrecpp0:ar 2:8.35-3.3+d arm64 Perl 5 Compatible Regular Express
ii libpipeline1:a 1.4.0-1 arm64 pipeline manipulation library
ii libpixman-1-0: 0.32.6-3 arm64 pixel-manipulation library for X
ii libpixman-1-de 0.32.6-3 arm64 pixel-manipulation library for X
ii libpng12-0:arm 1.2.50-2+deb arm64 PNG library - runtime
ii libpng12-dev:a 1.2.50-2+deb arm64 PNG library - development
ii libpod-latex-p 0.61-1 all module to convert Pod data to for
ii libpod-readme- 0.11-1 all Perl module to convert POD to REA
ii libpopt0:arm64 1.16-10 arm64 lib for parsing cmdline parameter
ii libportaudio2: 19+svn201401 arm64 Portable audio I/O - shared libra
ii libportaudiocp 19+svn201401 arm64 Portable audio I/O C++ bindings -
ii libprocps3:arm 2:3.3.9-9 arm64 library for accessing process inf
ii libpsl0:arm64 0.5.1-1 arm64 Library for Public Suffix List (s
ii libpthread-stu 0.3-4 arm64 pthread stubs not provided by nat
ii libpulse-dev:a 5.0-13 arm64 PulseAudio client development hea
ii libpulse-mainl 5.0-13 arm64 PulseAudio client libraries (glib
ii libpulse0:arm6 5.0-13 arm64 PulseAudio client libraries
ii libpython-dev: 2.7.9-1 arm64 header files and a static library
ii libpython-stdl 2.7.9-1 arm64 interactive high-level object-ori
ii libpython2.7:a 2.7.9-2 arm64 Shared Python runtime library (ve
ii libpython2.7-d 2.7.9-2 arm64 Header files and a static library
ii libpython2.7-m 2.7.9-2 arm64 Minimal subset of the Python lang
ii libpython2.7-s 2.7.9-2 arm64 Interactive high-level object-ori
ii libqt5concurre 5.3.2+dfsg-4 arm64 Qt 5 concurrent module
ii libqt5core5a:a 5.3.2+dfsg-4 arm64 Qt 5 core module
ii libqt5dbus5:ar 5.3.2+dfsg-4 arm64 Qt 5 D-Bus module
ii libqt5gui5:arm 5.3.2+dfsg-4 arm64 Qt 5 GUI module
ii libqt5multimed 5.3.2-5 arm64 Qt 5 Multimedia module
ii libqt5network5 5.3.2+dfsg-4 arm64 Qt 5 network module
ii libqt5printsup 5.3.2+dfsg-4 arm64 Qt 5 print support module
ii libqt5sql5:arm 5.3.2+dfsg-4 arm64 Qt 5 SQL module
ii libqt5test5:ar 5.3.2+dfsg-4 arm64 Qt 5 test module
ii libqt5widgets5 5.3.2+dfsg-4 arm64 Qt 5 widgets module
ii libqt5xml5:arm 5.3.2+dfsg-4 arm64 Qt 5 XML module
ii libreadline6:a 6.3-8+b3 arm64 GNU readline and history librarie
ii libregexp-comm 2013031301-1 all module with common regular expres
ii librtmp1:arm64 2.4+20150115 arm64 toolkit for RTMP streams (shared
ii libsasl2-2:arm 2.1.26.dfsg1 arm64 Cyrus SASL - authentication abstr
ii libsasl2-modul 2.1.26.dfsg1 arm64 Cyrus SASL - pluggable authentica
ii libschroedinge 1.0.11-2.1 arm64 library for encoding/decoding of
ii libsdl-image1. 1.2.12-5+b3 arm64 Image loading library for Simple
ii libsdl-mixer1. 1.2.12-11 arm64 Mixer library for Simple DirectMe
ii libsdl-net1.2: 1.2.8-4 arm64 Network library for Simple Direct
ii libsdl-net1.2- 1.2.8-4 arm64 Network library for Simple Direct
ii libsdl-sound1. 1.0.3-7 arm64 Sound library for Simple DirectMe
ii libsdl1.2-dev 1.2.15-10+b1 arm64 Simple DirectMedia Layer developm
ii libsdl1.2debia 1.2.15-10+b1 arm64 Simple DirectMedia Layer
ii libselinux1:ar 2.3-2 arm64 SELinux runtime shared libraries
ii libsemanage-co 2.3-1 all Common files for SELinux policy m
ii libsemanage1:a 2.3-1+b2 arm64 SELinux policy management library
ii libsepol1:arm6 2.3-2 arm64 SELinux library for manipulating
ii libserf-1-1:ar 1.3.8-1 arm64 high-performance asynchronous HTT
ii libsigc++-2.0- 2.4.0-1 arm64 type-safe Signal Framework for C+
ii libslang2:arm6 2.3.0-2 arm64 S-Lang programming library - runt
ii libslang2-dev: 2.3.0-2 arm64 S-Lang programming library, devel
ii libsm-dev:arm6 2:1.2.2-1+b1 arm64 X11 Session Management library (d
ii libsm6:arm64 2:1.2.2-1+b1 arm64 X11 Session Management library
ii libsmartcols1: 2.25.2-6 arm64 smart column output alignment lib
ii libsndfile1:ar 1.0.25-9.1 arm64 Library for reading/writing audio
ii libsoftware-li 0.103010-3 all module providing templated softwa
ii libspeex1:arm6 1.2~rc1.2-1 arm64 The Speex codec runtime library
ii libsqlite3-0:a 3.8.7.1-1+de arm64 SQLite 3 shared library
ii libss2:arm64 1.42.12-1.1 arm64 command-line interface parsing li
ii libssh2-1:arm6 1.4.3-4.1+de arm64 SSH2 client-side library
ii libssl1.0.0:ar 1.0.1k-3+deb arm64 Secure Sockets Layer toolkit - sh
ii libstdc++-4.9- 4.9.2-10 arm64 GNU Standard C++ Library v3 (deve
ii libstdc++6:arm 4.9.2-10 arm64 GNU Standard C++ Library v3
ii libsub-exporte 0.986-1 all sophisticated exporter for custom
ii libsub-install 0.928-1 all module for installing subroutines
ii libsvn1:arm64 1.8.10-6+deb arm64 Shared libraries used by Apache S
ii libswscale-dev 6:11.6-1~deb arm64 Development files for libswscale
ii libswscale3:ar 6:11.6-1~deb arm64 Libav video scaling library
ii libsystemd0:ar 215-17+deb8u arm64 systemd utility library
ii libtasn1-6:arm 4.2-3+deb8u1 arm64 Manage ASN.1 structures (runtime)
ii libterm-ui-per 0.42-1 all Term::ReadLine UI made easy
ii libtext-charwi 0.04-7+b1 arm64 get display widths of characters
ii libtext-iconv- 1.7-5+b1 arm64 converts between character sets i
ii libtext-sounde 3.4-1+b1 arm64 implementation of the soundex alg
ii libtext-templa 1.46-1 all perl module to process text templ
ii libtext-wrapi1 0.06-7 all internationalized substitute of T
ii libthai-data 0.1.21-1 all Data files for Thai language supp
ii libthai0:arm64 0.1.21-1 arm64 Thai language support library
ii libtheora0:arm 1.1.1+dfsg.1 arm64 Theora Video Compression Codec
ii libtiff5:arm64 4.0.3-12.3+d arm64 Tag Image File Format (TIFF) libr
ii libtiff5-dev:a 4.0.3-12.3+d arm64 Tag Image File Format library (TI
ii libtiffxx5:arm 4.0.3-12.3+d arm64 Tag Image File Format (TIFF) libr
ii libtimedate-pe 2.3000-2 all collection of modules to manipula
ii libtinfo5:arm6 5.9+20140913 arm64 shared low-level terminfo library
ii libudev1:arm64 215-17+deb8u arm64 libudev shared library
ii libusb-0.1-4:a 2:0.1.12-25 arm64 userspace USB programming library
ii libustr-1.0-1: 1.0.4-3+b2 arm64 Micro string library: shared libr
ii libuuid1:arm64 2.25.2-6 arm64 Universally Unique ID library
ii libva1:arm64 1.4.1-1 arm64 Video Acceleration (VA) API for L
ii libvorbis-dev: 1.3.4-2 arm64 development files for Vorbis Gene
ii libvorbis0a:ar 1.3.4-2 arm64 decoder library for Vorbis Genera
ii libvorbisenc2: 1.3.4-2 arm64 encoder library for Vorbis Genera
ii libvorbisfile3 1.3.4-2 arm64 high-level API for Vorbis General
ii libvpx1:arm64 1.3.0-3 arm64 VP8 and VP9 video codec (shared l
ii libwayland-cli 1.6.0-2 arm64 wayland compositor infrastructure
ii libwayland-ser 1.6.0-2 arm64 wayland compositor infrastructure
ii libwebp-dev:ar 0.4.1-1.2+b2 arm64 Lossy compression of digital phot
ii libwebp5:arm64 0.4.1-1.2+b2 arm64 Lossy compression of digital phot
ii libwebpdemux1: 0.4.1-1.2+b2 arm64 Lossy compression of digital phot
ii libwebpmux1:ar 0.4.1-1.2+b2 arm64 Lossy compression of digital phot
ii libwrap0:arm64 7.6.q-25 arm64 Wietse Venema's TCP wrappers libr
ii libx11-6:arm64 2:1.6.2-3 arm64 X11 client-side library
ii libx11-data 2:1.6.2-3 all X11 client-side library
ii libx11-dev:arm 2:1.6.2-3 arm64 X11 client-side library (developm
ii libx11-xcb-dev 2:1.6.2-3 arm64 Xlib/XCB interface library (devel
ii libx11-xcb1:ar 2:1.6.2-3 arm64 Xlib/XCB interface library
ii libx264-142:ar 2:0.142.2431 arm64 x264 video coding library
ii libxau-dev:arm 1:1.0.8-1 arm64 X11 authorisation library (develo
ii libxau6:arm64 1:1.0.8-1 arm64 X11 authorisation library
ii libxcb-dri2-0: 1.10-3+b1 arm64 X C Binding, dri2 extension
ii libxcb-dri2-0- 1.10-3+b1 arm64 X C Binding, dri2 extension, deve
ii libxcb-dri3-0: 1.10-3+b1 arm64 X C Binding, dri3 extension
ii libxcb-dri3-de 1.10-3+b1 arm64 X C Binding, dri3 extension, deve
ii libxcb-glx0:ar 1.10-3+b1 arm64 X C Binding, glx extension
ii libxcb-glx0-de 1.10-3+b1 arm64 X C Binding, glx extension, devel
ii libxcb-icccm4: 0.4.1-1 arm64 utility libraries for X C Binding
ii libxcb-image0: 0.4.0-1 arm64 utility libraries for X C Binding
ii libxcb-keysyms 0.4.0-1 arm64 utility libraries for X C Binding
ii libxcb-present 1.10-3+b1 arm64 X C Binding, present extension, d
ii libxcb-randr0: 1.10-3+b1 arm64 X C Binding, randr extension
ii libxcb-randr0- 1.10-3+b1 arm64 X C Binding, randr extension, dev
ii libxcb-render- 0.3.9-1 arm64 utility libraries for X C Binding
ii libxcb-render0 1.10-3+b1 arm64 X C Binding, render extension
ii libxcb-render0 1.10-3+b1 arm64 X C Binding, render extension, de
ii libxcb-shape0: 1.10-3+b1 arm64 X C Binding, shape extension
ii libxcb-shape0- 1.10-3+b1 arm64 X C Binding, shape extension, dev
ii libxcb-shm0:ar 1.10-3+b1 arm64 X C Binding, shm extension
ii libxcb-shm0-de 1.10-3+b1 arm64 X C Binding, shm extension, devel
ii libxcb-sync-de 1.10-3+b1 arm64 X C Binding, sync extension, deve
ii libxcb-sync1:a 1.10-3+b1 arm64 X C Binding, sync extension
ii libxcb-util0:a 0.3.8-3 arm64 utility libraries for X C Binding
ii libxcb-xfixes0 1.10-3+b1 arm64 X C Binding, xfixes extension
ii libxcb-xfixes0 1.10-3+b1 arm64 X C Binding, xfixes extension, de
ii libxcb-xkb1:ar 1.10-3+b1 arm64 X C Binding, XKEYBOARD extension
ii libxcb1:arm64 1.10-3+b1 arm64 X C Binding
ii libxcb1-dev:ar 1.10-3+b1 arm64 X C Binding, development files
ii libxcomposite- 1:0.4.4-1 arm64 X11 Composite extension library (
ii libxcomposite1 1:0.4.4-1 arm64 X11 Composite extension library
ii libxcursor-dev 1:1.1.14-1+b arm64 X cursor management library (deve
ii libxcursor1:ar 1:1.1.14-1+b arm64 X cursor management library
ii libxdamage-dev 1:1.1.4-2+b1 arm64 X11 damaged region extension libr
ii libxdamage1:ar 1:1.1.4-2+b1 arm64 X11 damaged region extension libr
ii libxdmcp-dev:a 1:1.1.1-1+b1 arm64 X11 authorisation library (develo
ii libxdmcp6:arm6 1:1.1.1-1+b1 arm64 X11 Display Manager Control Proto
ii libxext-dev:ar 2:1.3.3-1 arm64 X11 miscellaneous extensions libr
ii libxext6:arm64 2:1.3.3-1 arm64 X11 miscellaneous extension libra
ii libxfixes-dev: 1:5.0.1-2+b2 arm64 X11 miscellaneous 'fixes' extensi
ii libxfixes3:arm 1:5.0.1-2+b2 arm64 X11 miscellaneous 'fixes' extensi
ii libxft-dev 2.3.2-1 arm64 FreeType-based font drawing libra
ii libxft2:arm64 2.3.2-1 arm64 FreeType-based font drawing libra
ii libxi-dev 2:1.7.4-1+b2 arm64 X11 Input extension library (deve
ii libxi6:arm64 2:1.7.4-1+b2 arm64 X11 Input extension library
ii libxinerama-de 2:1.1.3-1+b1 arm64 X11 Xinerama extension library (d
ii libxinerama1:a 2:1.1.3-1+b1 arm64 X11 Xinerama extension library
ii libxkbcommon-x 0.4.3-2 arm64 library to create keymaps with th
ii libxkbcommon0: 0.4.3-2 arm64 library interface to the XKB comp
ii libxml2:arm64 2.9.1+dfsg1- arm64 GNOME XML library
ii libxml2-utils 2.9.1+dfsg1- arm64 XML utilities
ii libxmu-dev:arm 2:1.1.2-1 arm64 X11 miscellaneous utility library
ii libxmu-headers 2:1.1.2-1 all X11 miscellaneous utility library
ii libxmu6:arm64 2:1.1.2-1 arm64 X11 miscellaneous utility library
ii libxpm-dev:arm 1:3.5.11-1+b arm64 X11 pixmap library (development h
ii libxpm4:arm64 1:3.5.11-1+b arm64 X11 pixmap library
ii libxrandr-dev: 2:1.4.2-1+b1 arm64 X11 RandR extension library (deve
ii libxrandr2:arm 2:1.4.2-1+b1 arm64 X11 RandR extension library
ii libxrender-dev 1:0.9.8-1+b1 arm64 X Rendering Extension client libr
ii libxrender1:ar 1:0.9.8-1+b1 arm64 X Rendering Extension client libr
ii libxshmfence-d 1.1-4 arm64 X shared memory fences - developm
ii libxshmfence1: 1.1-4 arm64 X shared memory fences - shared l
ii libxt-dev:arm6 1:1.1.4-1+b1 arm64 X11 toolkit intrinsics library (d
ii libxt6:arm64 1:1.1.4-1+b1 arm64 X11 toolkit intrinsics library
ii libxtables10 1.4.21-2+b1 arm64 netfilter xtables library
ii libxtst6:arm64 2:1.2.2-1+b1 arm64 X11 Testing -- Record extension l
ii libxvidcore4:a 2:1.3.3-1 arm64 Open source MPEG-4 video codec (l
ii libxxf86vm-dev 1:1.1.3-1+b1 arm64 X11 XFree86 video mode extension
ii libxxf86vm1:ar 1:1.1.3-1+b1 arm64 X11 XFree86 video mode extension
ii linux-headers- 3.14.29-2016 arm64 Header files related to Linux ker
ii linux-headers- 3.14.29-1 arm64 Linux Image/Headers Meta Package
ii linux-image-3. 3.14.29-2016 arm64 Linux kernel binary image for ver
ii linux-image-ar 3.14.29-1 arm64 Linux Image/Headers Meta Package
ii linux-libc-dev 3.16.7-ckt25 arm64 Linux support headers for userspa
ii locales 2.19-18+deb8 all GNU C Library: National Language
ii locate 4.4.2-9+b3 arm64 maintain and query an index of a
ii login 1:4.2-3+deb8 arm64 system login tools
ii logrotate 3.8.7-1+b1 arm64 Log rotation utility
ii lsb-base 4.1+Debian13 all Linux Standard Base 4.1 init scri
ii make 4.0-8.1 arm64 utility for directing compilation
ii mali450-odroid 20160215-r5p arm64 Mali binary blob and development
ii man-db 2.7.0.2-5 arm64 on-line manual pager
ii manpages 3.74-1 all Manual pages about using a GNU/Li
ii mawk 1.3.3-17+b2 arm64 a pattern scanning and text proce
ii mc 3:4.8.13-3 arm64 Midnight Commander - a powerful f
ii mc-data 3:4.8.13-3 all Midnight Commander - a powerful f
ii mercurial 3.1.2-2+deb8 arm64 easy-to-use, scalable distributed
ii mercurial-comm 3.1.2-2+deb8 all easy-to-use, scalable distributed
ii mesa-common-de 10.3.2-1+deb arm64 Developer documentation for Mesa
ii mime-support 3.58 all MIME files 'mime.types' & 'mailca
ii mount 2.25.2-6 arm64 Tools for mounting and manipulati
ii multiarch-supp 2.19-18+deb8 arm64 Transitional package to ensure mu
ii nano 2.2.6-3 arm64 small, friendly text editor inspi
ii ncurses-base 5.9+20140913 all basic terminal type definitions
ii ncurses-bin 5.9+20140913 arm64 terminal-related programs and man
ii net-tools 1.60-26+b1 arm64 NET-3 networking toolkit
ii netbase 5.3 all Basic TCP/IP networking system
ii netcat-traditi 1.10-41 arm64 TCP/IP swiss army knife
ii nfacct 1.0.1-1.1 arm64 netfilter accounting object tool
ii ntp 1:4.2.6.p5+d arm64 Network Time Protocol daemon and
ii openssh-client 1:6.7p1-5+de arm64 secure shell (SSH) client, for se
ii openssh-server 1:6.7p1-5+de arm64 secure shell (SSH) server, for se
ii openssh-sftp-s 1:6.7p1-5+de arm64 secure shell (SSH) sftp server mo
ii passwd 1:4.2-3+deb8 arm64 change and administer password an
ii patch 2.7.5-1 arm64 Apply a diff file to an original
ii perl 5.20.2-3+deb arm64 Larry Wall's Practical Extraction
ii perl-base 5.20.2-3+deb arm64 minimal Perl system
ii perl-modules 5.20.2-3+deb all Core Perl modules
ii pkg-config 0.28-1+b2 arm64 manage compile and link flags for
ii portaudio19-de 19+svn201401 arm64 Portable audio I/O - development
ii procps 2:3.3.9-9 arm64 /proc file system utilities
ii python 2.7.9-1 arm64 interactive high-level object-ori
ii python-dev 2.7.9-1 arm64 header files and a static library
ii python-minimal 2.7.9-1 arm64 minimal subset of the Python lang
ii python2.7 2.7.9-2 arm64 Interactive high-level object-ori
ii python2.7-dev 2.7.9-2 arm64 Header files and a static library
ii python2.7-mini 2.7.9-2 arm64 Minimal subset of the Python lang
ii qt5-default 5.3.2+dfsg-4 arm64 Qt 5 development defaults package
ii qt5-qmake:arm6 5.3.2+dfsg-4 arm64 Qt 5 qmake Makefile generator too
ii qtbase5-dev:ar 5.3.2+dfsg-4 arm64 Qt 5 base development files
ii qtbase5-dev-to 5.3.2+dfsg-4 arm64 Qt 5 base development programs
ii qtchooser 47-gd2b7997- arm64 Wrapper to select between Qt deve
ii readline-commo 6.3-8 all GNU readline and history librarie
ii rename 0.20-3 all Perl extension for renaming multi
ii rsyslog 8.4.2-1+deb8 arm64 reliable system and kernel loggin
ii sed 4.2.2-4+b3 arm64 The GNU sed stream editor
ii sensible-utils 0.0.9 all Utilities for sensible alternativ
ii setup-odroid 0.0.1-6 all ODROID Setup (ODROID build)
ii sgml-base 1.26+nmu4 all SGML infrastructure and SGML cata
ii shared-mime-in 1.3-1+b2 arm64 FreeDesktop.org shared MIME datab
ii startpar 0.59-3+b2 arm64 run processes in parallel and mul
ii subversion 1.8.10-6+deb arm64 Advanced version control system
ii sudo 1.8.10p3-1+d arm64 Provide limited super user privil
ii systemd 215-17+deb8u arm64 system and service manager
ii systemd-sysv 215-17+deb8u arm64 system and service manager - SysV
ii sysv-rc 2.88dsf-59 all System-V-like runlevel change mec
ii sysvinit-utils 2.88dsf-59 arm64 System-V-like utilities
ii tar 1.27.1-2+b3 arm64 GNU version of the tar archiving
ii tasksel 3.31+deb8u1 all tool for selecting tasks for inst
ii tasksel-data 3.31+deb8u1 all official tasks used for installat
ii traceroute 1:2.0.20-2+b arm64 Traces the route taken by packets
ii tzdata 2015g-0+deb8 all time zone and daylight-saving tim
ii u-boot-tools 2014.10+dfsg arm64 companion tools for Das U-Boot bo
ii ucf 3.0030 all Update Configuration File(s): pre
ii udev 215-17+deb8u arm64 /dev/ and hotplug management daem
ii unzip 6.0-16+deb8u arm64 De-archiver for .zip files
ii util-linux 2.25.2-6 arm64 Miscellaneous system utilities
ii uuid-dev:arm64 2.25.2-6 arm64 universally unique id library - h
ii vim 2:7.4.488-7 arm64 Vi IMproved - enhanced vi editor
ii vim-common 2:7.4.488-7 arm64 Vi IMproved - Common files
ii vim-runtime 2:7.4.488-7 all Vi IMproved - Runtime files
ii vim-tiny 2:7.4.488-7 arm64 Vi IMproved - enhanced vi editor
ii wget 1.16-1 arm64 retrieves files from the web
ii whiptail 0.52.17-1+b1 arm64 Displays user-friendly dialog box
ii x11-common 1:7.7+7 all X Window System (X.Org) infrastru
ii x11proto-compo 1:0.4.2-2 all X11 Composite extension wire prot
ii x11proto-core- 7.0.26-1 all X11 core wire protocol and auxili
ii x11proto-damag 1:1.2.1-2 all X11 Damage extension wire protoco
ii x11proto-dri2- 2.8-2 all X11 DRI2 extension wire protocol
ii x11proto-fixes 1:5.0-2 all X11 Fixes extension wire protocol
ii x11proto-gl-de 1.4.17-1 all X11 OpenGL extension wire protoco
ii x11proto-input 2.3.1-1 all X11 Input extension wire protocol
ii x11proto-kb-de 1.0.6-2 all X11 XKB extension wire protocol
ii x11proto-randr 1.4.0-2 all X11 RandR extension wire protocol
ii x11proto-rende 2:0.11.1-2 all X11 Render extension wire protoco
ii x11proto-xext- 7.3.0-1 all X11 various extension wire protoc
ii x11proto-xf86v 2.3.1-2 all X11 Video Mode extension wire pro
ii x11proto-xiner 1.2.1-2 all X11 Xinerama extension wire proto
ii xdg-user-dirs 0.15-2 arm64 tool to manage well known user di
ii xkb-data 2.12-1 all X Keyboard Extension (XKB) config
ii xml-core 0.13+nmu2 all XML infrastructure and XML catalo
ii xorg-sgml-doct 1:1.11-1 all Common tools for building X.Org S
ii xtrans-dev 1.3.4-1 all X transport library (development
ii xz-utils 5.1.1alpha+2 arm64 XZ-format compression utilities
ii zlib1g:arm64 1:1.2.8.dfsg arm64 compression library - runtime
ii zlib1g-dev:arm 1:1.2.8.dfsg arm64 compression library - development
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 42 of 292, by gdjacobs
Not saying it's the root of the problem, but you'll want alsa-base and alsa-util.
Reply 43 of 292, by stamasd
I have actually installed quite a few alsa packages this morning for the other project I'm working on.
ii alsa-utils 1.0.28-1 arm64 Utilities for configuring and usi
ii alsaplayer-als 0.99.81-1+b1 arm64 alsaplayer output module for ALSA
ii alsaplayer-com 0.99.81-1+b1 arm64 audio player (common files)
ii alsaplayer-gtk 0.99.81-1+b1 arm64 alsaplayer gtk interface
ii alsaplayer-jac 0.99.81-1+b1 arm64 alsaplayer output module for JACK
ii alsaplayer-tex 0.99.81-1+b1 arm64 alsaplayer text interface
Still get the same.
 sudo aconnect -o
client 14: 'Midi Through' [type=kernel]
0 'Midi Through Port-0'
That is of course after starting mt32d.
I/O, I/O,
I/O, I/O
Reply 44 of 292, by gdjacobs
If you install timidity, does it properly register?
Can you play to port 128:0 even though it isn't shown as registered?
Can you tie Munt to the midi through port via aconnect even though it isn't registered? (aconnect 14:0 128:0)
Reply 45 of 292, by stamasd
No, no and no.
I/O, I/O,
I/O, I/O
Reply 46 of 292, by gdjacobs
Something wrong with the sound stack, then. Permissions, maybe? Are you running everything as root?
Reply 49 of 292, by stamasd
Argh. I managed to get munt compiled on the Odroid C2. Took a while, as I also needed to recompile the kernel (due to missing sequencer modules in the default install). Here are my working notes:
Odroid-C2 Ubuntu 16.04 alpha, March 2016
Munt install notes
Packages to install (sudo apt-get):
git
cmake
portaudio19-dev
libx11-dev
libxt-dev
sudo apt-get purge mali-fbdev
wget http://oph.mdrjr.net/odrobian/pool/s905/m/mali-fbdev/mali-fbdev_20160319-r5p1-1_arm64.deb
sudo dpkg -i mali-fbdev_20160319-r5p1-1_arm64.deb
qt5-default (cannot install until mali-fbdev driver is replaced as above)
libglib2.0
qtmultimedia5-dev
alsa-base alsa-utils alsa-tools alsaplayer-alsa aconnectgui pulseaudio
(1) see below
checkout:
git clone https://github.com/munt/munt.git
mkdir build
cd build
export CCFLAGS="-Ofast -march=armv8-a+crc -mtune=cortex-a53 -mcpu=cortex-a53"
export CXXFLAGS="-Ofast -march=armv8-a+crc -mtune=cortex-a53 -mcpu=cortex-a53"
cmake -DCMAKE_BUILD_TYPE=Release ../munt
make -j 4
sudo make install
cd ../munt/mt32emu_alsadrv
mkdir roms
(copy MT32_CONTROL.ROM and MT32_PCM.ROM to roms directory)
make
sudo make install
(testing another day)
(1)
alsa can't open sequencer: no sound/core modules built by default, need to check out kernel and build sequencer module
git clone --depth 1 https://github.com/hardkernel/linux.git -b odroidc2-3.14.y
install: libncurses5-dev lzop
make odroidc2_defconfig
make menuconfig
device drivers > sound card support > ALSA > sequencer support <M>
make modules
sudo make modules_install
might as well compile and install the kernel too
make -j 4 Image dtbs
sudo make firmware_install
Show last 17 lines
sudo make headers_install INSTALL_HDR_PATH=/usr
sudo cp -f arch/arm64/boot/Image arch/arm64/boot/dts/meson64_odroidc2.dtb /media/boot/
cd /lib/modules/<kernel version>
sudo find . -type f -name '*.ko' | sudo xargs -n 1 objcopy --strip-unneeded
cd ~/linux/linux
kver=`make kernelrelease`
sudo cp .config /boot/config-${kver}
cd /boot
sudo update-initramfs -c -k ${kver}
sudo mkimage -A arm64 -O linux -T ramdisk -a 0x0 -e 0x0 -n initrd.img-${kver} -d initrd.img-${kver} uInitrd-${kver}
sudo cp uInitrd-${kver} /media/boot/uInitrd
sudo sync
sudo reboot
However,
odroid@odroid64:~/munt/munt/mt32emu_alsadrv$ mt32d
MT-32 emulator ALSA address is 128:0
Buffer resize: Requested 40 msec got 40 msec / 60 periods
Starting MT-32 core
Segmentation fault
Guess I'll try to debug it, but not today. FWIW the same segfault happens if I compile munt without optimizations
I/O, I/O,
I/O, I/O
Reply 50 of 292, by stamasd
Ugh. If I start mt32d as root it doesn't segfault, but it still doesn't work.
odroid@odroid64:~/munt/munt/mt32emu_alsadrv$ sudo mt32d
Home directory not accessible: Permission denied
Set thread priority to -20
Starting MT-32 core
odroid@odroid64:~/munt/munt/mt32emu_alsadrv$ aconnect -o
I/O, I/O,
I/O, I/O
Reply 51 of 292, by stamasd
I finally got one of the Orange Pi boards, using the Allwinner H3 CPU. I had trouble getting it to run at all since the official images are crappy and unsupported. I finally got it up using Armbian. Of course I had to recompile the kernel, because as is customary with those boards sequencer support is not included in the default build. The build process was similar to the one for Odroid C2, with one extra library that I needed to install (libxpm-dev).
mt32d segfaults as a regular user.
As root, it gives me
silviu@orangepipc:~/munt/munt/mt32emu_alsadrv$ sudo mt32d
[sudo] password for silviu:
Error setting number of periods.
I/O, I/O,
I/O, I/O
Reply 52 of 292, by gdjacobs
Can you load a 32 bit release of Linux and try, or cross compile a 32 bit version of mt32d?
Reply 53 of 292, by stamasd
The Armbian on the Orange Pi is 32-bit and the mt32d in the post above was compiled 32-bit. On the Odroid, I tried Odrobian which is a mixed OS, 64-bit kernel with 32-bit userland, but haven't had much success there either (there is no pure 32-bit Linux version on the C2 due to unavailability of 32-bit drivers - primarily video).
BTW for the Armbian build I used no compiler flags.
silviu@orangepipc:~/munt/munt/mt32emu_alsadrv$ file mt32d
mt32d: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-armhf.so.3, for GNU/Linux 2.6.32, BuildID[sha1]=a0225d15da3d54f0893cd672aac2cb3ddb2286fb, not stripped
I/O, I/O,
I/O, I/O
Reply 56 of 292, by gdjacobs
The Munt library is static, but please check your libasound and libc versions to make sure the ABIs are not out of whack. You will need a 32 bit userland for the dependencies.
    mt32d.7z
    57.63 KiB
    91 downloads
    mt32d binary, dynamic link deps, and dependency package versions.
Reply 57 of 292, by stamasd
Yup, that works. Or at least it doesn't segfault, and registers with alsa.
silviu@orangepipc:~/munt/static$ ./mt32d
Starting MT-32 core
MT-32 emulator ready
$ aconnect -o
client 128: 'MT-32' [type=user]
0 'Standard '
1 'GM Emulation '
That again is on Orange Pi PC, Armbian-5.05 (Debian Jesie-based)
I/O, I/O,
I/O, I/O
Reply 59 of 292, by stamasd
Nope, no clue. I haven't really had time to delve into this.
All I can say right now is that:
1. alsa works - the problem is with the munt build, and
2. The error occurs between the "Starting MT-32 core" and the "MT-32 emulator ready" messages
I/O, I/O,
I/O, I/O
