First post, by zorach
Given that the source is quite sparsely commented, I have two questions:
- When adding significant chunks of code for a patch, would it be preferred to maintain this sparseness or is a more literary style acceptable? I'm not going to submit patches that just go through and comment existing functionality, mind you...this is for new/substantially revised code.
- Regardless of the answer to the first, would a "developers'/contributors'" section of the Wiki be appropriate? I'd be happy to write up stuff as I explore the code. Of course it'd be clearly labelled with both the version to which it applies and the usual "the source is the final word" disclaimers. If the authors want to look at it and make corrections that'd be great, of course, but I don't envision it as any sort of burden or obligation for them.
