Reply 20 of 187, by superfury
After looking at the disassembly generated by my emulator, I find that it's trying to read the MDA range (port 3BA to be exact) and waits for bit 0 to set before continuing. It seems to first try the MDA mode 7h on a MDA, then CGA modes 0/2?
And yes, it's actually the Turbo XT BIOS waiting: It's executing code in the F000 memory block, where the BIOS is mapped. After looking at the disasembly (IN AL,DX; TEST AL,01; JNZ repeatloop) in my emulator, I notice it's waiting for bit 1 of port 3B8 to clear for some reason?
So it's actually waiting for the display enable signal(It's waiting for it to render active display)? But since the hardware isn't initialised (It's in CGA mode, thus the VGA's IO_AS bit of the Misc Output Register(bit 0) is set, all writes to port 3B0-3B7 are ignored by the hardware, thus there's no active display or any other CRT values written(all zeroed out) and active display/display enable never occurs according to the CGA CRT registers and the BIOS waits infinitely for the display enable signal? Is this supposed to happen on a CGA?
Edit: It seems at this point(reading the register dump with a hex editor):
CGA Mode Control register: F0
CGA Pallette Register: 30
MDA Mode Control register: 00
CGA CRT registers (Index=Value):
00=61
01=50
02=52
03=0F
04=19
05=06
06=19
07=19
08=02
09=0D
0A=0B
0B=0C
0C=00
0D=00
0E=00
0F=00
10=00
11=00
Is this correct? Is there something wrong in my CRT emulation? It seems to be waiting for the bit 0 to lower for some reason(start of active display?
This is the log of the generated CRT timings (VGA-style, but based on CGA input(same as VGA, but instant start of retrace and blank signals(VGA does this a clock later in the case of the start of the period programmed))):
0:00:18:23.9.0259: Row #0=+VRETRACEEND+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0067: Row #1=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0088: Row #2=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0109: Row #3=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0129: Row #4=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0148: Row #5=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0166: Row #6=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0187: Row #7=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0205: Row #8=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0226: Row #9=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0244: Row #10=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0265: Row #11=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0283: Row #12=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0304: Row #13=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0322: Row #14=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0343: Row #15=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0363: Row #16=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0382: Row #17=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0400: Row #18=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0421: Row #19=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0441: Row #20=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0460: Row #21=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0480: Row #22=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0501: Row #23=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0519: Row #24=+VACTIVEDISPLAY+OVERSCAN
0:00:18:24.0.0540: Row #25=+VRETRACESTART+OVERSCAN
0:00:18:24.0.0558: Row #26=+VRETRACESTART+OVERSCAN
0:00:18:24.0.0579: Row #27=+VRETRACESTART+OVERSCAN
0:00:18:24.0.0597: Row #28=+VRETRACESTART+OVERSCAN
0:00:18:24.0.0618: Row #29=+VRETRACESTART+OVERSCAN
0:00:18:24.0.0636: Row #30=+VRETRACESTART+OVERSCAN
0:00:18:24.0.0657: Row #31=+VRETRACESTART+OVERSCAN
0:00:18:24.0.0679: Row #32=+VTOTAL+VRETRACESTART+OVERSCAN
0:00:18:24.0.0700: Col #0=+HRETRACEEND+HACTIVEDISPLAY
0:00:18:24.0.0716: Col #1=+HACTIVEDISPLAY
0:00:18:24.0.0731: Col #2=+HACTIVEDISPLAY
0:00:18:24.0.0747: Col #3=+HACTIVEDISPLAY
0:00:18:24.0.0763: Col #4=+HACTIVEDISPLAY
0:00:18:24.0.0778: Col #5=+HACTIVEDISPLAY
0:00:18:24.0.0794: Col #6=+HACTIVEDISPLAY
0:00:18:24.0.0811: Col #7=+HACTIVEDISPLAY
0:00:18:24.0.0827: Col #8=+HACTIVEDISPLAY
0:00:18:24.0.0842: Col #9=+HACTIVEDISPLAY
0:00:18:24.0.0858: Col #10=+HACTIVEDISPLAY
0:00:18:24.0.0874: Col #11=+HACTIVEDISPLAY
0:00:18:24.0.0891: Col #12=+HACTIVEDISPLAY
0:00:18:24.0.0905: Col #13=+HACTIVEDISPLAY
0:00:18:24.0.0922: Col #14=+HACTIVEDISPLAY
0:00:18:24.0.0938: Col #15=+HACTIVEDISPLAY
0:00:18:24.0.0954: Col #16=+HACTIVEDISPLAY
0:00:18:24.0.0969: Col #17=+HACTIVEDISPLAY
0:00:18:24.0.0985: Col #18=+HACTIVEDISPLAY
0:00:18:24.1.0002: Col #19=+HACTIVEDISPLAY
0:00:18:24.1.0018: Col #20=+HACTIVEDISPLAY
0:00:18:24.1.0032: Col #21=+HACTIVEDISPLAY
0:00:18:24.1.0049: Col #22=+HACTIVEDISPLAY
0:00:18:24.1.0065: Col #23=+HACTIVEDISPLAY
0:00:18:24.1.0082: Col #24=+HACTIVEDISPLAY
0:00:18:24.1.0098: Col #25=+HACTIVEDISPLAY
0:00:18:24.1.0113: Col #26=+HACTIVEDISPLAY
0:00:18:24.1.0129: Col #27=+HACTIVEDISPLAY
0:00:18:24.1.0143: Col #28=+HACTIVEDISPLAY
0:00:18:24.1.0160: Col #29=+HACTIVEDISPLAY
0:00:18:24.1.0176: Col #30=+HACTIVEDISPLAY
0:00:18:24.1.0193: Col #31=+HACTIVEDISPLAY
0:00:18:24.1.0209: Col #32=+HACTIVEDISPLAY
0:00:18:24.1.0223: Col #33=+HACTIVEDISPLAY
0:00:18:24.1.0240: Col #34=+HACTIVEDISPLAY
0:00:18:24.1.0256: Col #35=+HACTIVEDISPLAY
0:00:18:24.1.0271: Col #36=+HACTIVEDISPLAY
0:00:18:24.1.0287: Col #37=+HACTIVEDISPLAY
0:00:18:24.1.0303: Col #38=+HACTIVEDISPLAY
0:00:18:24.1.0320: Col #39=+HACTIVEDISPLAY
0:00:18:24.1.0334: Col #40=+HACTIVEDISPLAY
0:00:18:24.1.0351: Col #41=+HACTIVEDISPLAY
0:00:18:24.1.0367: Col #42=+HACTIVEDISPLAY
0:00:18:24.1.0381: Col #43=+HACTIVEDISPLAY
0:00:18:24.1.0398: Col #44=+HACTIVEDISPLAY
0:00:18:24.1.0414: Col #45=+HACTIVEDISPLAY
0:00:18:24.1.0431: Col #46=+HACTIVEDISPLAY
0:00:18:24.1.0445: Col #47=+HACTIVEDISPLAY
0:00:18:24.1.0462: Col #48=+HACTIVEDISPLAY
0:00:18:24.1.0478: Col #49=+HACTIVEDISPLAY
0:00:18:24.1.0494: Col #50=+HACTIVEDISPLAY
0:00:18:24.1.0509: Col #51=+HACTIVEDISPLAY
0:00:18:24.1.0525: Col #52=+HACTIVEDISPLAY
0:00:18:24.1.0542: Col #53=+HACTIVEDISPLAY
0:00:18:24.1.0659: Col #54=+HACTIVEDISPLAY
0:00:18:24.1.0675: Col #55=+HACTIVEDISPLAY
0:00:18:24.1.0692: Col #56=+HACTIVEDISPLAY
0:00:18:24.1.0706: Col #57=+HACTIVEDISPLAY
0:00:18:24.1.0722: Col #58=+HACTIVEDISPLAY
0:00:18:24.1.0739: Col #59=+HACTIVEDISPLAY
0:00:18:24.1.0755: Col #60=+HACTIVEDISPLAY
0:00:18:24.1.0772: Col #61=+HACTIVEDISPLAY
0:00:18:24.1.0786: Col #62=+HACTIVEDISPLAY
0:00:18:24.1.0802: Col #63=+HACTIVEDISPLAY
0:00:18:24.1.0819: Col #64=+HACTIVEDISPLAY
0:00:18:24.1.0833: Col #65=+HACTIVEDISPLAY
0:00:18:24.1.0850: Col #66=+HACTIVEDISPLAY
0:00:18:24.1.0866: Col #67=+HACTIVEDISPLAY
0:00:18:24.1.0882: Col #68=+HACTIVEDISPLAY
0:00:18:24.1.0899: Col #69=+HACTIVEDISPLAY
0:00:18:24.1.0913: Col #70=+HACTIVEDISPLAY
0:00:18:24.1.0930: Col #71=+HACTIVEDISPLAY
0:00:18:24.1.0946: Col #72=+HACTIVEDISPLAY
0:00:18:24.1.0960: Col #73=+HACTIVEDISPLAY
0:00:18:24.1.0977: Col #74=+HACTIVEDISPLAY
0:00:18:24.2.0006: Col #75=+HACTIVEDISPLAY
0:00:18:24.2.0022: Col #76=+HACTIVEDISPLAY
0:00:18:24.2.0038: Col #77=+HACTIVEDISPLAY
0:00:18:24.2.0055: Col #78=+HACTIVEDISPLAY
0:00:18:24.2.0069: Col #79=+HACTIVEDISPLAY
0:00:18:24.2.0086: Col #80=+HACTIVEDISPLAY
0:00:18:24.2.0102: Col #81=+HACTIVEDISPLAY
0:00:18:24.2.0117: Col #82=+HACTIVEDISPLAY
0:00:18:24.2.0133: Col #83=+HACTIVEDISPLAY
0:00:18:24.2.0149: Col #84=+HACTIVEDISPLAY
0:00:18:24.2.0166: Col #85=+HACTIVEDISPLAY
0:00:18:24.2.0182: Col #86=+HACTIVEDISPLAY
0:00:18:24.2.0197: Col #87=+HACTIVEDISPLAY
0:00:18:24.2.0213: Col #88=+HACTIVEDISPLAY
0:00:18:24.2.0229: Col #89=+HACTIVEDISPLAY
0:00:18:24.2.0244: Col #90=+HACTIVEDISPLAY
0:00:18:24.2.0260: Col #91=+HACTIVEDISPLAY
0:00:18:24.2.0277: Col #92=+HACTIVEDISPLAY
0:00:18:24.2.0293: Col #93=+HACTIVEDISPLAY
0:00:18:24.2.0310: Col #94=+HACTIVEDISPLAY
0:00:18:24.2.0324: Col #95=+HACTIVEDISPLAY
0:00:18:24.2.0340: Col #96=+HACTIVEDISPLAY
0:00:18:24.2.0357: Col #97=+HACTIVEDISPLAY
0:00:18:24.2.0371: Col #98=+HACTIVEDISPLAY
0:00:18:24.2.0388: Col #99=+HACTIVEDISPLAY
0:00:18:24.2.0404: Col #100=+HACTIVEDISPLAY
0:00:18:24.2.0420: Col #101=+HACTIVEDISPLAY
0:00:18:24.2.0437: Col #102=+HACTIVEDISPLAY
0:00:18:24.2.0453: Col #103=+HACTIVEDISPLAY
0:00:18:24.2.0468: Col #104=+HACTIVEDISPLAY
0:00:18:24.2.0486: Col #105=+HACTIVEDISPLAY
0:00:18:24.2.0500: Col #106=+HACTIVEDISPLAY
0:00:18:24.2.0517: Col #107=+HACTIVEDISPLAY
0:00:18:24.2.0533: Col #108=+HACTIVEDISPLAY
0:00:18:24.2.0550: Col #109=+HACTIVEDISPLAY
0:00:18:24.2.0566: Col #110=+HACTIVEDISPLAY
0:00:18:24.2.0581: Col #111=+HACTIVEDISPLAY
0:00:18:24.2.0597: Col #112=+HACTIVEDISPLAY
0:00:18:24.2.0613: Col #113=+HACTIVEDISPLAY
0:00:18:24.2.0630: Col #114=+HACTIVEDISPLAY
0:00:18:24.2.0646: Col #115=+HACTIVEDISPLAY
0:00:18:24.2.0663: Col #116=+HACTIVEDISPLAY
0:00:18:24.2.0679: Col #117=+HACTIVEDISPLAY
0:00:18:24.2.0695: Col #118=+HACTIVEDISPLAY
0:00:18:24.2.0710: Col #119=+HACTIVEDISPLAY
0:00:18:24.2.0726: Col #120=+HACTIVEDISPLAY
0:00:18:24.2.0743: Col #121=+HACTIVEDISPLAY
0:00:18:24.2.0759: Col #122=+HACTIVEDISPLAY
0:00:18:24.2.0774: Col #123=+HACTIVEDISPLAY
0:00:18:24.2.0790: Col #124=+HACTIVEDISPLAY
0:00:18:24.2.0806: Col #125=+HACTIVEDISPLAY
0:00:18:24.2.0823: Col #126=+HACTIVEDISPLAY
0:00:18:24.2.0839: Col #127=+HACTIVEDISPLAY
0:00:18:24.2.0856: Col #128=+HACTIVEDISPLAY
0:00:18:24.2.0872: Col #129=+HACTIVEDISPLAY
0:00:18:24.2.0888: Col #130=+HACTIVEDISPLAY
0:00:18:24.2.0903: Col #131=+HACTIVEDISPLAY
0:00:18:24.2.0919: Col #132=+HACTIVEDISPLAY
0:00:18:24.2.0936: Col #133=+HACTIVEDISPLAY
0:00:18:24.2.0952: Col #134=+HACTIVEDISPLAY
0:00:18:24.2.0967: Col #135=+HACTIVEDISPLAY
0:00:18:24.2.0985: Col #136=+HACTIVEDISPLAY
0:00:18:24.2.0999: Col #137=+HACTIVEDISPLAY
0:00:18:24.3.0016: Col #138=+HACTIVEDISPLAY
0:00:18:24.3.0032: Col #139=+HACTIVEDISPLAY
0:00:18:24.3.0049: Col #140=+HACTIVEDISPLAY
0:00:18:24.3.0065: Col #141=+HACTIVEDISPLAY
0:00:18:24.3.0081: Col #142=+HACTIVEDISPLAY
0:00:18:24.3.0098: Col #143=+HACTIVEDISPLAY
0:00:18:24.3.0112: Col #144=+HACTIVEDISPLAY
0:00:18:24.3.0129: Col #145=+HACTIVEDISPLAY
0:00:18:24.3.0205: Col #146=+HACTIVEDISPLAY
0:00:18:24.3.0221: Col #147=+HACTIVEDISPLAY
0:00:18:24.3.0238: Col #148=+HACTIVEDISPLAY
0:00:18:24.3.0252: Col #149=+HACTIVEDISPLAY
0:00:18:24.3.0268: Col #150=+HACTIVEDISPLAY
0:00:18:24.3.0285: Col #151=+HACTIVEDISPLAY
0:00:18:24.3.0303: Col #152=+HACTIVEDISPLAY
0:00:18:24.3.0320: Col #153=+HACTIVEDISPLAY
0:00:18:24.3.0336: Col #154=+HACTIVEDISPLAY
0:00:18:24.3.0488: Col #155=+HACTIVEDISPLAY
0:00:18:24.3.0504: Col #156=+HACTIVEDISPLAY
0:00:18:24.3.0521: Col #157=+HACTIVEDISPLAY
0:00:18:24.3.0537: Col #158=+HACTIVEDISPLAY
0:00:18:24.3.0554: Col #159=+HACTIVEDISPLAY
0:00:18:24.3.0568: Col #160=+HACTIVEDISPLAY
0:00:18:24.3.0585: Col #161=+HACTIVEDISPLAY
0:00:18:24.3.0601: Col #162=+HACTIVEDISPLAY
0:00:18:24.3.0617: Col #163=+HACTIVEDISPLAY
0:00:18:24.3.0634: Col #164=+HACTIVEDISPLAY
0:00:18:24.3.0650: Col #165=+HACTIVEDISPLAY
0:00:18:24.3.0665: Col #166=+HACTIVEDISPLAY
0:00:18:24.3.0681: Col #167=+HACTIVEDISPLAY
0:00:18:24.3.0697: Col #168=+HACTIVEDISPLAY
0:00:18:24.3.0714: Col #169=+HACTIVEDISPLAY
0:00:18:24.3.0730: Col #170=+HACTIVEDISPLAY
0:00:18:24.3.0747: Col #171=+HACTIVEDISPLAY
0:00:18:24.3.0763: Col #172=+HACTIVEDISPLAY
0:00:18:24.3.0780: Col #173=+HACTIVEDISPLAY
0:00:18:24.3.0794: Col #174=+HACTIVEDISPLAY
0:00:18:24.3.0810: Col #175=+HACTIVEDISPLAY
0:00:18:24.3.0827: Col #176=+HACTIVEDISPLAY
0:00:18:24.3.0843: Col #177=+HACTIVEDISPLAY
0:00:18:24.3.0858: Col #178=+HACTIVEDISPLAY
0:00:18:24.3.0874: Col #179=+HACTIVEDISPLAY
0:00:18:24.3.0890: Col #180=+HACTIVEDISPLAY
0:00:18:24.3.0907: Col #181=+HACTIVEDISPLAY
0:00:18:24.3.0923: Col #182=+HACTIVEDISPLAY
0:00:18:24.3.0940: Col #183=+HACTIVEDISPLAY
0:00:18:24.3.0956: Col #184=+HACTIVEDISPLAY
0:00:18:24.3.0973: Col #185=+HACTIVEDISPLAY
0:00:18:24.4.0069: Col #186=+HACTIVEDISPLAY
0:00:18:24.4.0085: Col #187=+HACTIVEDISPLAY
0:00:18:24.4.0108: Col #188=+HACTIVEDISPLAY
0:00:18:24.4.0124: Col #189=+HACTIVEDISPLAY
0:00:18:24.4.0141: Col #190=+HACTIVEDISPLAY
0:00:18:24.4.0157: Col #191=+HACTIVEDISPLAY
0:00:18:24.4.0174: Col #192=+HACTIVEDISPLAY
0:00:18:24.4.0190: Col #193=+HACTIVEDISPLAY
0:00:18:24.4.0207: Col #194=+HACTIVEDISPLAY
0:00:18:24.4.0223: Col #195=+HACTIVEDISPLAY
0:00:18:24.4.0239: Col #196=+HACTIVEDISPLAY
0:00:18:24.4.0254: Col #197=+HACTIVEDISPLAY
0:00:18:24.4.0270: Col #198=+HACTIVEDISPLAY
0:00:18:24.4.0287: Col #199=+HACTIVEDISPLAY
0:00:18:24.4.0303: Col #200=+HACTIVEDISPLAY
0:00:18:24.4.0317: Col #201=+HACTIVEDISPLAY
0:00:18:24.4.0334: Col #202=+HACTIVEDISPLAY
0:00:18:24.4.0350: Col #203=+HACTIVEDISPLAY
0:00:18:24.4.0367: Col #204=+HACTIVEDISPLAY
0:00:18:24.4.0383: Col #205=+HACTIVEDISPLAY
0:00:18:24.4.0400: Col #206=+HACTIVEDISPLAY
0:00:18:24.4.0416: Col #207=+HACTIVEDISPLAY
0:00:18:24.4.0432: Col #208=+HACTIVEDISPLAY
0:00:18:24.4.0447: Col #209=+HACTIVEDISPLAY
0:00:18:24.4.0463: Col #210=+HACTIVEDISPLAY
0:00:18:24.4.0480: Col #211=+HACTIVEDISPLAY
0:00:18:24.4.0498: Col #212=+HACTIVEDISPLAY
0:00:18:24.4.0515: Col #213=+HACTIVEDISPLAY
0:00:18:24.4.0531: Col #214=+HACTIVEDISPLAY
0:00:18:24.4.0545: Col #215=+HACTIVEDISPLAY
0:00:18:24.4.0562: Col #216=+HACTIVEDISPLAY
0:00:18:24.4.0578: Col #217=+HACTIVEDISPLAY
0:00:18:24.4.0609: Col #218=+HACTIVEDISPLAY
0:00:18:24.4.0627: Col #219=+HACTIVEDISPLAY
0:00:18:24.4.0644: Col #220=+HACTIVEDISPLAY
0:00:18:24.4.0658: Col #221=+HACTIVEDISPLAY
0:00:18:24.4.0675: Col #222=+HACTIVEDISPLAY
0:00:18:24.4.0691: Col #223=+HACTIVEDISPLAY
0:00:18:24.4.0720: Col #224=+HACTIVEDISPLAY
0:00:18:24.4.0738: Col #225=+HACTIVEDISPLAY
0:00:18:24.4.0755: Col #226=+HACTIVEDISPLAY
0:00:18:24.4.0771: Col #227=+HACTIVEDISPLAY
0:00:18:24.4.0788: Col #228=+HACTIVEDISPLAY
0:00:18:24.4.0851: Col #229=+HACTIVEDISPLAY
0:00:18:24.4.0868: Col #230=+HACTIVEDISPLAY
0:00:18:24.4.0884: Col #231=+HACTIVEDISPLAY
0:00:18:24.4.0901: Col #232=+HACTIVEDISPLAY
0:00:18:24.4.0917: Col #233=+HACTIVEDISPLAY
0:00:18:24.4.0933: Col #234=+HACTIVEDISPLAY
0:00:18:24.4.0950: Col #235=+HACTIVEDISPLAY
0:00:18:24.4.0966: Col #236=+HACTIVEDISPLAY
0:00:18:24.5.0034: Col #237=+HACTIVEDISPLAY
0:00:18:24.5.0050: Col #238=+HACTIVEDISPLAY
0:00:18:24.5.0067: Col #239=+HACTIVEDISPLAY
0:00:18:24.5.0081: Col #240=+HACTIVEDISPLAY
0:00:18:24.5.0098: Col #241=+HACTIVEDISPLAY
0:00:18:24.5.0114: Col #242=+HACTIVEDISPLAY
0:00:18:24.5.0131: Col #243=+HACTIVEDISPLAY
0:00:18:24.5.0147: Col #244=+HACTIVEDISPLAY
0:00:18:24.5.0163: Col #245=+HACTIVEDISPLAY
0:00:18:24.5.0180: Col #246=+HACTIVEDISPLAY
0:00:18:24.5.0194: Col #247=+HACTIVEDISPLAY
0:00:18:24.5.0211: Col #248=+HACTIVEDISPLAY
0:00:18:24.5.0227: Col #249=+HACTIVEDISPLAY
0:00:18:24.5.0243: Col #250=+HACTIVEDISPLAY
0:00:18:24.5.0258: Col #251=+HACTIVEDISPLAY
0:00:18:24.5.0274: Col #252=+HACTIVEDISPLAY
0:00:18:24.5.0291: Col #253=+HACTIVEDISPLAY
0:00:18:24.5.0307: Col #254=+HACTIVEDISPLAY
0:00:18:24.5.0324: Col #255=+HACTIVEDISPLAY
0:00:18:24.5.0340: Col #256=+HACTIVEDISPLAY
0:00:18:24.5.0356: Col #257=+HACTIVEDISPLAY
0:00:18:24.5.0371: Col #258=+HACTIVEDISPLAY
0:00:18:24.5.0387: Col #259=+HACTIVEDISPLAY
0:00:18:24.5.0404: Col #260=+HACTIVEDISPLAY
0:00:18:24.5.0420: Col #261=+HACTIVEDISPLAY
0:00:18:24.5.0434: Col #262=+HACTIVEDISPLAY
0:00:18:24.5.0451: Col #263=+HACTIVEDISPLAY
0:00:18:24.5.0467: Col #264=+HACTIVEDISPLAY
0:00:18:24.5.0496: Col #265=+HACTIVEDISPLAY
0:00:18:24.5.0512: Col #266=+HACTIVEDISPLAY
0:00:18:24.5.0529: Col #267=+HACTIVEDISPLAY
0:00:18:24.5.0545: Col #268=+HACTIVEDISPLAY
0:00:18:24.5.0562: Col #269=+HACTIVEDISPLAY
0:00:18:24.5.0578: Col #270=+HACTIVEDISPLAY
0:00:18:24.5.0595: Col #271=+HACTIVEDISPLAY
0:00:18:24.5.0609: Col #272=+HACTIVEDISPLAY
0:00:18:24.5.0625: Col #273=+HACTIVEDISPLAY
0:00:18:24.5.0642: Col #274=+HACTIVEDISPLAY
0:00:18:24.5.0658: Col #275=+HACTIVEDISPLAY
0:00:18:24.5.0673: Col #276=+HACTIVEDISPLAY
0:00:18:24.5.0689: Col #277=+HACTIVEDISPLAY
0:00:18:24.5.0705: Col #278=+HACTIVEDISPLAY
0:00:18:24.5.0722: Col #279=+HACTIVEDISPLAY
0:00:18:24.5.0738: Col #280=+HACTIVEDISPLAY
0:00:18:24.5.0755: Col #281=+HACTIVEDISPLAY
0:00:18:24.5.0771: Col #282=+HACTIVEDISPLAY
0:00:18:24.5.0785: Col #283=+HACTIVEDISPLAY
0:00:18:24.5.0802: Col #284=+HACTIVEDISPLAY
0:00:18:24.5.0818: Col #285=+HACTIVEDISPLAY
0:00:18:24.5.0835: Col #286=+HACTIVEDISPLAY
0:00:18:24.5.0851: Col #287=+HACTIVEDISPLAY
0:00:18:24.5.0866: Col #288=+HACTIVEDISPLAY
0:00:18:24.5.0882: Col #289=+HACTIVEDISPLAY
0:00:18:24.5.0898: Col #290=+HACTIVEDISPLAY
0:00:18:24.5.0915: Col #291=+HACTIVEDISPLAY
0:00:18:24.5.0931: Col #292=+HACTIVEDISPLAY
0:00:18:24.5.0948: Col #293=+HACTIVEDISPLAY
0:00:18:24.5.0964: Col #294=+HACTIVEDISPLAY
0:00:18:24.5.0978: Col #295=+HACTIVEDISPLAY
0:00:18:24.5.0997: Col #296=+HACTIVEDISPLAY
0:00:18:24.6.0011: Col #297=+HACTIVEDISPLAY
0:00:18:24.6.0028: Col #298=+HACTIVEDISPLAY
0:00:18:24.6.0044: Col #299=+HACTIVEDISPLAY
0:00:18:24.6.0061: Col #300=+HACTIVEDISPLAY
0:00:18:24.6.0075: Col #301=+HACTIVEDISPLAY
0:00:18:24.6.0091: Col #302=+HACTIVEDISPLAY
0:00:18:24.6.0108: Col #303=+HACTIVEDISPLAY
0:00:18:24.6.0124: Col #304=+HACTIVEDISPLAY
0:00:18:24.6.0141: Col #305=+HACTIVEDISPLAY
0:00:18:24.6.0157: Col #306=+HACTIVEDISPLAY
0:00:18:24.6.0171: Col #307=+HACTIVEDISPLAY
0:00:18:24.6.0188: Col #308=+HACTIVEDISPLAY
0:00:18:24.6.0204: Col #309=+HACTIVEDISPLAY
0:00:18:24.6.0221: Col #310=+HACTIVEDISPLAY
0:00:18:24.6.0237: Col #311=+HACTIVEDISPLAY
0:00:18:24.6.0252: Col #312=+HACTIVEDISPLAY
0:00:18:24.6.0268: Col #313=+HACTIVEDISPLAY
0:00:18:24.6.0284: Col #314=+HACTIVEDISPLAY
0:00:18:24.6.0301: Col #315=+HACTIVEDISPLAY
0:00:18:24.6.0317: Col #316=+HACTIVEDISPLAY
0:00:18:24.6.0334: Col #317=+HACTIVEDISPLAY
0:00:18:24.6.0350: Col #318=+HACTIVEDISPLAY
0:00:18:24.6.0364: Col #319=+HACTIVEDISPLAY
0:00:18:24.6.0381: Col #320=+HACTIVEDISPLAY
0:00:18:24.6.0397: Col #321=+HACTIVEDISPLAY
0:00:18:24.6.0414: Col #322=+HACTIVEDISPLAY
0:00:18:24.6.0428: Col #323=+HACTIVEDISPLAY
0:00:18:24.6.0445: Col #324=+HACTIVEDISPLAY
0:00:18:24.6.0461: Col #325=+HACTIVEDISPLAY
0:00:18:24.6.0477: Col #326=+HACTIVEDISPLAY
0:00:18:24.6.0494: Col #327=+HACTIVEDISPLAY
0:00:18:24.6.0590: Col #328=+HACTIVEDISPLAY
0:00:18:24.6.0607: Col #329=+HACTIVEDISPLAY
0:00:18:24.6.0623: Col #330=+HACTIVEDISPLAY
0:00:18:24.6.0640: Col #331=+HACTIVEDISPLAY
0:00:18:24.6.0656: Col #332=+HACTIVEDISPLAY
0:00:18:24.6.0670: Col #333=+HACTIVEDISPLAY
0:00:18:24.6.0687: Col #334=+HACTIVEDISPLAY
0:00:18:24.6.0703: Col #335=+HACTIVEDISPLAY
0:00:18:24.6.0720: Col #336=+HACTIVEDISPLAY
0:00:18:24.6.0736: Col #337=+HACTIVEDISPLAY
0:00:18:24.6.0752: Col #338=+HACTIVEDISPLAY
0:00:18:24.6.0769: Col #339=+HACTIVEDISPLAY
0:00:18:24.6.0785: Col #340=+HACTIVEDISPLAY
0:00:18:24.6.0800: Col #341=+HACTIVEDISPLAY
0:00:18:24.6.0816: Col #342=+HACTIVEDISPLAY
0:00:18:24.6.0833: Col #343=+HACTIVEDISPLAY
0:00:18:24.6.0849: Col #344=+HACTIVEDISPLAY
0:00:18:24.6.0863: Col #345=+HACTIVEDISPLAY
0:00:18:24.6.0880: Col #346=+HACTIVEDISPLAY
0:00:18:24.6.0896: Col #347=+HACTIVEDISPLAY
0:00:18:24.6.0913: Col #348=+HACTIVEDISPLAY
0:00:18:24.6.0929: Col #349=+HACTIVEDISPLAY
0:00:18:24.6.0945: Col #350=+HACTIVEDISPLAY
0:00:18:24.6.0962: Col #351=+HACTIVEDISPLAY
0:00:18:24.6.0976: Col #352=+HACTIVEDISPLAY
0:00:18:24.6.0995: Col #353=+HACTIVEDISPLAY
0:00:18:24.7.0011: Col #354=+HACTIVEDISPLAY
0:00:18:24.7.0028: Col #355=+HACTIVEDISPLAY
0:00:18:24.7.0042: Col #356=+HACTIVEDISPLAY
0:00:18:24.7.0058: Col #357=+HACTIVEDISPLAY
0:00:18:24.7.0075: Col #358=+HACTIVEDISPLAY
0:00:18:24.7.0091: Col #359=+HACTIVEDISPLAY
0:00:18:24.7.0106: Col #360=+HACTIVEDISPLAY
0:00:18:24.7.0122: Col #361=+HACTIVEDISPLAY
0:00:18:24.7.0138: Col #362=+HACTIVEDISPLAY
0:00:18:24.7.0155: Col #363=+HACTIVEDISPLAY
0:00:18:24.7.0171: Col #364=+HACTIVEDISPLAY
0:00:18:24.7.0188: Col #365=+HACTIVEDISPLAY
0:00:18:24.7.0204: Col #366=+HACTIVEDISPLAY
0:00:18:24.7.0219: Col #367=+HACTIVEDISPLAY
0:00:18:24.7.0235: Col #368=+HACTIVEDISPLAY
0:00:18:24.7.0251: Col #369=+HACTIVEDISPLAY
0:00:18:24.7.0268: Col #370=+HACTIVEDISPLAY
0:00:18:24.7.0284: Col #371=+HACTIVEDISPLAY
0:00:18:24.7.0299: Col #372=+HACTIVEDISPLAY
0:00:18:24.7.0315: Col #373=+HACTIVEDISPLAY
0:00:18:24.7.0331: Col #374=+HACTIVEDISPLAY
0:00:18:24.7.0348: Col #375=+HACTIVEDISPLAY
0:00:18:24.7.0364: Col #376=+HACTIVEDISPLAY
0:00:18:24.7.0381: Col #377=+HACTIVEDISPLAY
0:00:18:24.7.0397: Col #378=+HACTIVEDISPLAY
0:00:18:24.7.0412: Col #379=+HACTIVEDISPLAY
0:00:18:24.7.0428: Col #380=+HACTIVEDISPLAY
0:00:18:24.7.0444: Col #381=+HACTIVEDISPLAY
0:00:18:24.7.0461: Col #382=+HACTIVEDISPLAY
0:00:18:24.7.0475: Col #383=+HACTIVEDISPLAY
0:00:18:24.7.0494: Col #384=+HACTIVEDISPLAY
0:00:18:24.7.0508: Col #385=+HACTIVEDISPLAY
0:00:18:24.7.0524: Col #386=+HACTIVEDISPLAY
0:00:18:24.7.0541: Col #387=+HACTIVEDISPLAY
0:00:18:24.7.0557: Col #388=+HACTIVEDISPLAY
0:00:18:24.7.0574: Col #389=+HACTIVEDISPLAY
0:00:18:24.7.0590: Col #390=+HACTIVEDISPLAY
0:00:18:24.7.0607: Col #391=+HACTIVEDISPLAY
0:00:18:24.7.0621: Col #392=+HACTIVEDISPLAY
0:00:18:24.7.0637: Col #393=+HACTIVEDISPLAY
0:00:18:24.7.0654: Col #394=+HACTIVEDISPLAY
0:00:18:24.7.0670: Col #395=+HACTIVEDISPLAY
0:00:18:24.7.0687: Col #396=+HACTIVEDISPLAY
0:00:18:24.7.0701: Col #397=+HACTIVEDISPLAY
0:00:18:24.7.0717: Col #398=+HACTIVEDISPLAY
0:00:18:24.7.0734: Col #399=+HACTIVEDISPLAY
0:00:18:24.7.0750: Col #400=+HACTIVEDISPLAY
0:00:18:24.7.0767: Col #401=+HACTIVEDISPLAY
0:00:18:24.7.0783: Col #402=+HACTIVEDISPLAY
0:00:18:24.7.0800: Col #403=+HACTIVEDISPLAY
0:00:18:24.7.0814: Col #404=+HACTIVEDISPLAY
0:00:18:24.7.0830: Col #405=+HACTIVEDISPLAY
0:00:18:24.7.0847: Col #406=+HACTIVEDISPLAY
0:00:18:24.7.0863: Col #407=+HACTIVEDISPLAY
0:00:18:24.7.0878: Col #408=+HACTIVEDISPLAY
0:00:18:24.7.0894: Col #409=+HACTIVEDISPLAY
0:00:18:24.7.0910: Col #410=+HACTIVEDISPLAY
0:00:18:24.7.0927: Col #411=+HACTIVEDISPLAY
0:00:18:24.7.0943: Col #412=+HACTIVEDISPLAY
0:00:18:24.7.0960: Col #413=+HACTIVEDISPLAY
0:00:18:24.7.0976: Col #414=+HACTIVEDISPLAY
0:00:18:24.7.0993: Col #415=+HACTIVEDISPLAY
0:00:18:24.8.0009: Col #416=+HACTIVEDISPLAY
0:00:18:24.8.0023: Col #417=+HACTIVEDISPLAY
0:00:18:24.8.0040: Col #418=+HACTIVEDISPLAY
0:00:18:24.8.0081: Col #419=+HACTIVEDISPLAY
0:00:18:24.8.0095: Col #420=+HACTIVEDISPLAY
0:00:18:24.8.0112: Col #421=+HACTIVEDISPLAY
0:00:18:24.8.0128: Col #422=+HACTIVEDISPLAY
0:00:18:24.8.0145: Col #423=+HACTIVEDISPLAY
0:00:18:24.8.0161: Col #424=+HACTIVEDISPLAY
0:00:18:24.8.0177: Col #425=+HACTIVEDISPLAY
0:00:18:24.8.0194: Col #426=+HACTIVEDISPLAY
0:00:18:24.8.0210: Col #427=+HACTIVEDISPLAY
0:00:18:24.8.0225: Col #428=+HACTIVEDISPLAY
0:00:18:24.8.0241: Col #429=+HACTIVEDISPLAY
0:00:18:24.8.0257: Col #430=+HACTIVEDISPLAY
0:00:18:24.8.0274: Col #431=+HACTIVEDISPLAY
0:00:18:24.8.0288: Col #432=+HACTIVEDISPLAY
0:00:18:24.8.0305: Col #433=+HACTIVEDISPLAY
0:00:18:24.8.0321: Col #434=+HACTIVEDISPLAY
0:00:18:24.8.0337: Col #435=+HACTIVEDISPLAY
0:00:18:24.8.0354: Col #436=+HACTIVEDISPLAY
0:00:18:24.8.0370: Col #437=+HACTIVEDISPLAY
0:00:18:24.8.0387: Col #438=+HACTIVEDISPLAY
0:00:18:24.8.0403: Col #439=+HACTIVEDISPLAY
0:00:18:24.8.0418: Col #440=+HACTIVEDISPLAY
0:00:18:24.8.0434: Col #441=+HACTIVEDISPLAY
0:00:18:24.8.0450: Col #442=+HACTIVEDISPLAY
0:00:18:24.8.0467: Col #443=+HACTIVEDISPLAY
0:00:18:24.8.0483: Col #444=+HACTIVEDISPLAY
0:00:18:24.8.0500: Col #445=+HACTIVEDISPLAY
0:00:18:24.8.0516: Col #446=+HACTIVEDISPLAY
0:00:18:24.8.0533: Col #447=+HACTIVEDISPLAY
0:00:18:24.8.0547: Col #448=+HACTIVEDISPLAY
0:00:18:24.8.0563: Col #449=+HACTIVEDISPLAY
0:00:18:24.8.0580: Col #450=+HACTIVEDISPLAY
0:00:18:24.8.0596: Col #451=+HACTIVEDISPLAY
0:00:18:24.8.0613: Col #452=+HACTIVEDISPLAY
0:00:18:24.8.0629: Col #453=+HACTIVEDISPLAY
0:00:18:24.8.0645: Col #454=+HACTIVEDISPLAY
0:00:18:24.8.0662: Col #455=+HACTIVEDISPLAY
0:00:18:24.8.0676: Col #456=+HACTIVEDISPLAY
0:00:18:24.8.0693: Col #457=+HACTIVEDISPLAY
0:00:18:24.8.0709: Col #458=+HACTIVEDISPLAY
0:00:18:24.8.0726: Col #459=+HACTIVEDISPLAY
0:00:18:24.8.0740: Col #460=+HACTIVEDISPLAY
0:00:18:24.8.0756: Col #461=+HACTIVEDISPLAY
0:00:18:24.8.0773: Col #462=+HACTIVEDISPLAY
0:00:18:24.8.0789: Col #463=+HACTIVEDISPLAY
0:00:18:24.8.0806: Col #464=+HACTIVEDISPLAY
0:00:18:24.8.0822: Col #465=+HACTIVEDISPLAY
0:00:18:24.8.0838: Col #466=+HACTIVEDISPLAY
0:00:18:24.8.0855: Col #467=+HACTIVEDISPLAY
0:00:18:24.8.0869: Col #468=+HACTIVEDISPLAY
0:00:18:24.8.0886: Col #469=+HACTIVEDISPLAY
0:00:18:24.8.0902: Col #470=+HACTIVEDISPLAY
0:00:18:24.8.0919: Col #471=+HACTIVEDISPLAY
0:00:18:24.8.0935: Col #472=+HACTIVEDISPLAY
0:00:18:24.8.0949: Col #473=+HACTIVEDISPLAY
0:00:18:24.8.0966: Col #474=+HACTIVEDISPLAY
0:00:18:24.8.0982: Col #475=+HACTIVEDISPLAY
0:00:18:24.8.0999: Col #476=+HACTIVEDISPLAY
0:00:18:24.9.0015: Col #477=+HACTIVEDISPLAY
0:00:18:24.9.0031: Col #478=+HACTIVEDISPLAY
0:00:18:24.9.0048: Col #479=+HACTIVEDISPLAY
0:00:18:24.9.0064: Col #480=+HACTIVEDISPLAY
0:00:18:24.9.0081: Col #481=+HACTIVEDISPLAY
0:00:18:24.9.0095: Col #482=+HACTIVEDISPLAY
0:00:18:24.9.0112: Col #483=+HACTIVEDISPLAY
0:00:18:24.9.0128: Col #484=+HACTIVEDISPLAY
0:00:18:24.9.0144: Col #485=+HACTIVEDISPLAY
0:00:18:24.9.0159: Col #486=+HACTIVEDISPLAY
0:00:18:24.9.0175: Col #487=+HACTIVEDISPLAY
0:00:18:24.9.0192: Col #488=+HACTIVEDISPLAY
0:00:18:24.9.0208: Col #489=+HACTIVEDISPLAY
0:00:18:24.9.0224: Col #490=+HACTIVEDISPLAY
0:00:18:24.9.0241: Col #491=+HACTIVEDISPLAY
0:00:18:24.9.0257: Col #492=+HACTIVEDISPLAY
0:00:18:24.9.0274: Col #493=+HACTIVEDISPLAY
0:00:18:24.9.0288: Col #494=+HACTIVEDISPLAY
0:00:18:24.9.0305: Col #495=+HACTIVEDISPLAY
0:00:18:24.9.0321: Col #496=+HACTIVEDISPLAY
0:00:18:24.9.0337: Col #497=+HACTIVEDISPLAY
0:00:18:24.9.0354: Col #498=+HACTIVEDISPLAY
0:00:18:24.9.0368: Col #499=+HACTIVEDISPLAY
0:00:18:24.9.0385: Col #500=+HACTIVEDISPLAY
0:00:18:24.9.0401: Col #501=+HACTIVEDISPLAY
0:00:18:24.9.0417: Col #502=+HACTIVEDISPLAY
0:00:18:24.9.0434: Col #503=+HACTIVEDISPLAY
0:00:18:24.9.0450: Col #504=+HACTIVEDISPLAY
0:00:18:24.9.0467: Col #505=+HACTIVEDISPLAY
0:00:18:24.9.0481: Col #506=+HACTIVEDISPLAY
0:00:18:24.9.0500: Col #507=+HACTIVEDISPLAY
0:00:18:24.9.0516: Col #508=+HACTIVEDISPLAY
0:00:18:24.9.0530: Col #509=+HACTIVEDISPLAY
0:00:18:24.9.0569: Col #510=+HACTIVEDISPLAY
0:00:18:24.9.0586: Col #511=+HACTIVEDISPLAY
0:00:18:24.9.0600: Col #512=+HACTIVEDISPLAY
0:00:18:24.9.0617: Col #513=+HACTIVEDISPLAY
0:00:18:24.9.0633: Col #514=+HACTIVEDISPLAY
0:00:18:24.9.0649: Col #515=+HACTIVEDISPLAY
0:00:18:24.9.0666: Col #516=+HACTIVEDISPLAY
0:00:18:24.9.0680: Col #517=+HACTIVEDISPLAY
0:00:18:24.9.0697: Col #518=+HACTIVEDISPLAY
0:00:18:24.9.0713: Col #519=+HACTIVEDISPLAY
0:00:18:24.9.0730: Col #520=+HACTIVEDISPLAY
0:00:18:24.9.0746: Col #521=+HACTIVEDISPLAY
0:00:18:24.9.0762: Col #522=+HACTIVEDISPLAY
0:00:18:24.9.0779: Col #523=+HACTIVEDISPLAY
0:00:18:24.9.0793: Col #524=+HACTIVEDISPLAY
0:00:18:24.9.0810: Col #525=+HACTIVEDISPLAY
0:00:18:24.9.0826: Col #526=+HACTIVEDISPLAY
0:00:18:24.9.0842: Col #527=+HACTIVEDISPLAY
0:00:18:24.9.0857: Col #528=+HACTIVEDISPLAY
0:00:18:24.9.0873: Col #529=+HACTIVEDISPLAY
0:00:18:24.9.0890: Col #530=+HACTIVEDISPLAY
0:00:18:24.9.0906: Col #531=+HACTIVEDISPLAY
0:00:18:24.9.0923: Col #532=+HACTIVEDISPLAY
0:00:18:24.9.0939: Col #533=+HACTIVEDISPLAY
0:00:18:24.9.0955: Col #534=+HACTIVEDISPLAY
0:00:18:24.9.0970: Col #535=+HACTIVEDISPLAY
0:00:18:24.9.0988: Col #536=+HACTIVEDISPLAY
0:00:18:25.0.0003: Col #537=+HACTIVEDISPLAY
0:00:18:25.0.0019: Col #538=+HACTIVEDISPLAY
0:00:18:25.0.0035: Col #539=+HACTIVEDISPLAY
0:00:18:25.0.0052: Col #540=+HACTIVEDISPLAY
0:00:18:25.0.0066: Col #541=+HACTIVEDISPLAY
0:00:18:25.0.0083: Col #542=+HACTIVEDISPLAY
0:00:18:25.0.0099: Col #543=+HACTIVEDISPLAY
0:00:18:25.0.0116: Col #544=+HACTIVEDISPLAY
0:00:18:25.0.0132: Col #545=+HACTIVEDISPLAY
0:00:18:25.0.0148: Col #546=+HACTIVEDISPLAY
0:00:18:25.0.0163: Col #547=+HACTIVEDISPLAY
0:00:18:25.0.0179: Col #548=+HACTIVEDISPLAY
0:00:18:25.0.0196: Col #549=+HACTIVEDISPLAY
0:00:18:25.0.0212: Col #550=+HACTIVEDISPLAY
0:00:18:25.0.0226: Col #551=+HACTIVEDISPLAY
0:00:18:25.0.0243: Col #552=+HACTIVEDISPLAY
0:00:18:25.0.0259: Col #553=+HACTIVEDISPLAY
0:00:18:25.0.0276: Col #554=+HACTIVEDISPLAY
0:00:18:25.0.0292: Col #555=+HACTIVEDISPLAY
0:00:18:25.0.0309: Col #556=+HACTIVEDISPLAY
0:00:18:25.0.0325: Col #557=+HACTIVEDISPLAY
0:00:18:25.0.0339: Col #558=+HACTIVEDISPLAY
0:00:18:25.0.0356: Col #559=+HACTIVEDISPLAY
0:00:18:25.0.0372: Col #560=+HACTIVEDISPLAY
0:00:18:25.0.0389: Col #561=+HACTIVEDISPLAY
0:00:18:25.0.0403: Col #562=+HACTIVEDISPLAY
0:00:18:25.0.0419: Col #563=+HACTIVEDISPLAY
0:00:18:25.0.0436: Col #564=+HACTIVEDISPLAY
0:00:18:25.0.0452: Col #565=+HACTIVEDISPLAY
0:00:18:25.0.0469: Col #566=+HACTIVEDISPLAY
0:00:18:25.0.0485: Col #567=+HACTIVEDISPLAY
0:00:18:25.0.0501: Col #568=+HACTIVEDISPLAY
0:00:18:25.0.0518: Col #569=+HACTIVEDISPLAY
0:00:18:25.0.0534: Col #570=+HACTIVEDISPLAY
0:00:18:25.0.0549: Col #571=+HACTIVEDISPLAY
0:00:18:25.0.0565: Col #572=+HACTIVEDISPLAY
0:00:18:25.0.0582: Col #573=+HACTIVEDISPLAY
0:00:18:25.0.0598: Col #574=+HACTIVEDISPLAY
0:00:18:25.0.0612: Col #575=+HACTIVEDISPLAY
0:00:18:25.0.0629: Col #576=+HACTIVEDISPLAY
0:00:18:25.0.0645: Col #577=+HACTIVEDISPLAY
0:00:18:25.0.0662: Col #578=+HACTIVEDISPLAY
0:00:18:25.0.0678: Col #579=+HACTIVEDISPLAY
0:00:18:25.0.0694: Col #580=+HACTIVEDISPLAY
0:00:18:25.0.0709: Col #581=+HACTIVEDISPLAY
0:00:18:25.0.0725: Col #582=+HACTIVEDISPLAY
0:00:18:25.0.0742: Col #583=+HACTIVEDISPLAY
0:00:18:25.0.0758: Col #584=+HACTIVEDISPLAY
0:00:18:25.0.0775: Col #585=+HACTIVEDISPLAY
0:00:18:25.0.0789: Col #586=+HACTIVEDISPLAY
0:00:18:25.0.0805: Col #587=+HACTIVEDISPLAY
0:00:18:25.0.0822: Col #588=+HACTIVEDISPLAY
0:00:18:25.0.0838: Col #589=+HACTIVEDISPLAY
0:00:18:25.0.0855: Col #590=+HACTIVEDISPLAY
0:00:18:25.0.0871: Col #591=+HACTIVEDISPLAY
0:00:18:25.0.0885: Col #592=+HACTIVEDISPLAY
0:00:18:25.0.0902: Col #593=+HACTIVEDISPLAY
0:00:18:25.0.0918: Col #594=+HACTIVEDISPLAY
0:00:18:25.0.0935: Col #595=+HACTIVEDISPLAY
0:00:18:25.0.0949: Col #596=+HACTIVEDISPLAY
0:00:18:25.0.0966: Col #597=+HACTIVEDISPLAY
0:00:18:25.0.0982: Col #598=+HACTIVEDISPLAY
0:00:18:25.0.0998: Col #599=+HACTIVEDISPLAY
0:00:18:25.1.0015: Col #600=+HACTIVEDISPLAY
0:00:18:25.1.0052: Col #601=+HACTIVEDISPLAY
0:00:18:25.1.0068: Col #602=+HACTIVEDISPLAY
0:00:18:25.1.0085: Col #603=+HACTIVEDISPLAY
0:00:18:25.1.0101: Col #604=+HACTIVEDISPLAY
0:00:18:25.1.0117: Col #605=+HACTIVEDISPLAY
0:00:18:25.1.0134: Col #606=+HACTIVEDISPLAY
0:00:18:25.1.0148: Col #607=+HACTIVEDISPLAY
0:00:18:25.1.0165: Col #608=+HACTIVEDISPLAY
0:00:18:25.1.0181: Col #609=+HACTIVEDISPLAY
0:00:18:25.1.0198: Col #610=+HACTIVEDISPLAY
0:00:18:25.1.0212: Col #611=+HACTIVEDISPLAY
0:00:18:25.1.0228: Col #612=+HACTIVEDISPLAY
0:00:18:25.1.0245: Col #613=+HACTIVEDISPLAY
0:00:18:25.1.0261: Col #614=+HACTIVEDISPLAY
0:00:18:25.1.0278: Col #615=+HACTIVEDISPLAY
0:00:18:25.1.0294: Col #616=+HACTIVEDISPLAY
0:00:18:25.1.0310: Col #617=+HACTIVEDISPLAY
0:00:18:25.1.0325: Col #618=+HACTIVEDISPLAY
0:00:18:25.1.0341: Col #619=+HACTIVEDISPLAY
0:00:18:25.1.0358: Col #620=+HACTIVEDISPLAY
0:00:18:25.1.0374: Col #621=+HACTIVEDISPLAY
0:00:18:25.1.0388: Col #622=+HACTIVEDISPLAY
0:00:18:25.1.0405: Col #623=+HACTIVEDISPLAY
0:00:18:25.1.0421: Col #624=+HACTIVEDISPLAY
0:00:18:25.1.0438: Col #625=+HACTIVEDISPLAY
0:00:18:25.1.0454: Col #626=+HACTIVEDISPLAY
0:00:18:25.1.0471: Col #627=+HACTIVEDISPLAY
0:00:18:25.1.0487: Col #628=+HACTIVEDISPLAY
0:00:18:25.1.0503: Col #629=+HACTIVEDISPLAY
0:00:18:25.1.0520: Col #630=+HACTIVEDISPLAY
0:00:18:25.1.0536: Col #631=+HACTIVEDISPLAY
0:00:18:25.1.0551: Col #632=+HACTIVEDISPLAY
0:00:18:25.1.0567: Col #633=+HACTIVEDISPLAY
0:00:18:25.1.0583: Col #634=+HACTIVEDISPLAY
0:00:18:25.1.0600: Col #635=+HACTIVEDISPLAY
0:00:18:25.1.0614: Col #636=+HACTIVEDISPLAY
0:00:18:25.1.0631: Col #637=+HACTIVEDISPLAY
0:00:18:25.1.0647: Col #638=+HACTIVEDISPLAY
0:00:18:25.1.0664: Col #639=+HACTIVEDISPLAY
0:00:18:25.1.0680: Col #640=+HACTIVEDISPLAY
0:00:18:25.1.0696: Col #641=+HACTIVEDISPLAY
0:00:18:25.1.0713: Col #642=+HACTIVEDISPLAY
0:00:18:25.1.0727: Col #643=+HACTIVEDISPLAY
0:00:18:25.1.0744: Col #644=+HACTIVEDISPLAY
0:00:18:25.1.0760: Col #645=+HACTIVEDISPLAY
0:00:18:25.1.0776: Col #646=+HACTIVEDISPLAY
0:00:18:25.1.0793: Col #647=+HACTIVEDISPLAY
0:00:18:25.1.0811: Col #648=+HRETRACESTART+OVERSCAN
0:00:18:25.1.0832: Col #649=+HRETRACESTART+OVERSCAN
0:00:18:25.1.0852: Col #650=+HRETRACESTART+OVERSCAN
0:00:18:25.1.0871: Col #651=+HRETRACESTART+OVERSCAN
0:00:18:25.1.0889: Col #652=+HRETRACESTART+OVERSCAN
0:00:18:25.1.0910: Col #653=+HRETRACESTART+OVERSCAN
0:00:18:25.1.0930: Col #654=+HRETRACESTART+OVERSCAN
0:00:18:25.1.0949: Col #655=+HRETRACESTART+OVERSCAN
0:00:18:25.1.0963: Col #656=
0:00:18:25.1.0976: Col #657=
0:00:18:25.1.0988: Col #658=
0:00:18:25.2.0000: Col #659=
0:00:18:25.2.0013: Col #660=
0:00:18:25.2.0025: Col #661=
0:00:18:25.2.0037: Col #662=
0:00:18:25.2.0050: Col #663=
0:00:18:25.2.0062: Col #664=
0:00:18:25.2.0074: Col #665=
0:00:18:25.2.0087: Col #666=
0:00:18:25.2.0099: Col #667=
0:00:18:25.2.0111: Col #668=
0:00:18:25.2.0123: Col #669=
0:00:18:25.2.0136: Col #670=
0:00:18:25.2.0148: Col #671=
0:00:18:25.2.0160: Col #672=
0:00:18:25.2.0173: Col #673=
0:00:18:25.2.0185: Col #674=
0:00:18:25.2.0197: Col #675=
0:00:18:25.2.0210: Col #676=
0:00:18:25.2.0222: Col #677=
0:00:18:25.2.0234: Col #678=
0:00:18:25.2.0247: Col #679=
0:00:18:25.2.0259: Col #680=
0:00:18:25.2.0271: Col #681=
0:00:18:25.2.0284: Col #682=
0:00:18:25.2.0296: Col #683=
0:00:18:25.2.0308: Col #684=
0:00:18:25.2.0323: Col #685=
0:00:18:25.2.0335: Col #686=
0:00:18:25.2.0347: Col #687=
0:00:18:25.2.0360: Col #688=
0:00:18:25.2.0372: Col #689=
0:00:18:25.2.0384: Col #690=
0:00:18:25.2.0397: Col #691=
0:00:18:25.2.0409: Col #692=
0:00:18:25.2.0421: Col #693=
0:00:18:25.2.0433: Col #694=
0:00:18:25.2.0446: Col #695=
0:00:18:25.2.0458: Col #696=
0:00:18:25.2.0470: Col #697=
0:00:18:25.2.0483: Col #698=
0:00:18:25.2.0497: Col #699=
0:00:18:25.2.0509: Col #700=
0:00:18:25.2.0522: Col #701=
0:00:18:25.2.0534: Col #702=
0:00:18:25.2.0546: Col #703=
0:00:18:25.2.0559: Col #704=
0:00:18:25.2.0571: Col #705=
0:00:18:25.2.0583: Col #706=
0:00:18:25.2.0596: Col #707=
0:00:18:25.2.0655: Col #708=
0:00:18:25.2.0668: Col #709=
0:00:18:25.2.0680: Col #710=
0:00:18:25.2.0692: Col #711=
0:00:18:25.2.0705: Col #712=
0:00:18:25.2.0717: Col #713=
0:00:18:25.2.0729: Col #714=
0:00:18:25.2.0741: Col #715=
0:00:18:25.2.0754: Col #716=
0:00:18:25.2.0768: Col #717=
0:00:18:25.2.0780: Col #718=
0:00:18:25.2.0793: Col #719=
0:00:18:25.2.0805: Col #720=
0:00:18:25.2.0817: Col #721=
0:00:18:25.2.0830: Col #722=
0:00:18:25.2.0842: Col #723=
0:00:18:25.2.0854: Col #724=
0:00:18:25.2.0867: Col #725=
0:00:18:25.2.0879: Col #726=
0:00:18:25.2.0891: Col #727=
0:00:18:25.2.0904: Col #728=
0:00:18:25.2.0916: Col #729=
0:00:18:25.2.0928: Col #730=
0:00:18:25.2.0941: Col #731=
0:00:18:25.2.0953: Col #732=
0:00:18:25.2.0965: Col #733=
0:00:18:25.2.0978: Col #734=
0:00:18:25.2.0990: Col #735=
0:00:18:25.3.0002: Col #736=
0:00:18:25.3.0015: Col #737=
0:00:18:25.3.0027: Col #738=
0:00:18:25.3.0039: Col #739=
0:00:18:25.3.0051: Col #740=
0:00:18:25.3.0064: Col #741=
0:00:18:25.3.0076: Col #742=
0:00:18:25.3.0088: Col #743=
0:00:18:25.3.0101: Col #744=
0:00:18:25.3.0113: Col #745=
0:00:18:25.3.0125: Col #746=
0:00:18:25.3.0138: Col #747=
0:00:18:25.3.0150: Col #748=
0:00:18:25.3.0162: Col #749=
0:00:18:25.3.0177: Col #750=
0:00:18:25.3.0189: Col #751=
0:00:18:25.3.0201: Col #752=
0:00:18:25.3.0214: Col #753=
0:00:18:25.3.0226: Col #754=
0:00:18:25.3.0238: Col #755=
0:00:18:25.3.0251: Col #756=
0:00:18:25.3.0263: Col #757=
0:00:18:25.3.0275: Col #758=
0:00:18:25.3.0288: Col #759=
0:00:18:25.3.0300: Col #760=
0:00:18:25.3.0312: Col #761=
0:00:18:25.3.0325: Col #762=
0:00:18:25.3.0337: Col #763=
0:00:18:25.3.0349: Col #764=
0:00:18:25.3.0362: Col #765=
0:00:18:25.3.0374: Col #766=
0:00:18:25.3.0386: Col #767=
0:00:18:25.3.0398: Col #768=
0:00:18:25.3.0411: Col #769=
0:00:18:25.3.0423: Col #770=
0:00:18:25.3.0435: Col #771=
0:00:18:25.3.0448: Col #772=
0:00:18:25.3.0460: Col #773=
0:00:18:25.3.0472: Col #774=
0:00:18:25.3.0485: Col #775=
0:00:18:25.3.0505: Col #776=+HRETRACESTART+OVERSCAN
0:00:18:25.3.0526: Col #777=+HRETRACESTART+OVERSCAN
0:00:18:25.3.0544: Col #778=+HRETRACESTART+OVERSCAN
0:00:18:25.3.0565: Col #779=+HRETRACESTART+OVERSCAN
0:00:18:25.3.0585: Col #780=+HRETRACESTART+OVERSCAN
0:00:18:25.3.0604: Col #781=+HRETRACESTART+OVERSCAN
0:00:18:25.3.0622: Col #782=+HRETRACESTART+OVERSCAN
0:00:18:25.3.0643: Col #783=+HRETRACESTART+OVERSCAN
0:00:18:25.3.0667: Col #784=+HTOTAL+HRETRACESTART+OVERSCAN
UniPCemu Git repository
