Reply 3301 of 27788, by Skyscraper
wrote:This child, after CF-boot and battery related problems, seems to be good ;) - I'll take it to my house, near 'main' PC, with tha […]
This child, after CF-boot and battery related problems, seems to be good 😉 - I'll take it to my house, near 'main' PC, with that little cute 15" Compaq CRT - for 'fast' DOS gaming <3
It seems like a really nice system. 😀
Reply 3302 of 27788, by Indrid Cold
- Member
wrote:wrote:This child, after CF-boot and battery related problems, seems to be good ;) - I'll take it to my house, near 'main' PC, with tha […]
Thanks 😉
Reply 3303 of 27788, by brostenen
- l33t++
VL-Bus and stuff... Nice. 😜
Reply 3304 of 27788, by Indrid Cold
- Member
Thanks, I can say it is a clean machine, in wonderful shape, after all. Love that 'Intel Inside'sticker
Reply 3305 of 27788, by Imperious
Yesterday I removed Winxp off my Abit machine due to it being too sluggish, even with 1Gig Sdram installed and
put Win2000 on it. I'm a bit surprised that a 128MB 9800xt beats a 6800GT in 3dmark2001 but I did get higher
FPS in Doom 3, around 44fps.
The Video card and Cpu is being bottlenecked quite severely by 133mhz sdram and KT133 Chipset I think, unsurprising when I think
that this mobo started life with a Duron 650@800-900mhz and a TNT2 Pro and 192MB Ram.
The 6800GT is in there really only for benchmarking and to see how far it could be pushed, I'll shove the 9800xt
back in there once I'm finished mucking about with it.
Reply 3306 of 27788, by Sutekh94
- Oldbie
After some trouble with drivers not working, I managed to test out my recently-acquired Banshee PCI. It seems to be fully working! Not bad for $12 off of eBay including shipping. I tested it using a K6-2 450MHz on a Mitac 5114VU super socket 7 mobo (VIA MVP4 chipset) out of a Compaq system:
My YouTube | My DeviantArt
Reply 3307 of 27788, by kithylin
- l33t
wrote:At least some boards try to charge the batteries. You can sometimes get away with it and you'll probably be fine, but I like not to take the risk on the off-chance the battery decides to pop. As such, I would probably have added a diode, though that might require a different set of batteries if the voltage drops too far - the diode will have a marginal effect on the voltage.
I own two 486 motherboards and (1) 386 motherboard. I've measured all of them, and not a single one of them output any power on the cmos battery terminals at all when running. They don't charge anything.
Both of my 486's have been connected to a 4xAA NiMh bank for cmos for going on 5 years now. Haven't had to remove em for a charge yet.
Reply 3308 of 27788, by Cyrix200+
- Oldbie
wrote:Im doing some benchmarking. 😀
I know the CPU I need is in this box...
😲 Jeez at least put some newspaper inbetween 😉
1982 to 2001
Reply 3309 of 27788, by Cyrix200+
Reply 3310 of 27788, by h-a-l-9000
That would increase the risk of static electricity 😉
1+1=10
Reply 3311 of 27788, by Skyscraper
wrote:> 😲 Jeez at least put some newspaper inbetween 😉
I got this package today. The best ESD protection ever.
Reply 3312 of 27788, by clueless1
- l33t
wrote:I got this package today. The best ESD protection ever. […]
Oh, my Lord! Please, just shuffle your feet along the carpet really good before touching all the components, will you? That will put the poor board out of its misery.
Reply 3313 of 27788, by vetz
- l33t
wrote:snip
It's an ASUS XP55T2P4, they are unkillable.
Reply 3314 of 27788, by brassicGamer
- Oldbie
wrote:I am doing inventory so I finally have a list of all my stuff (except for memory/cables etc). Today was CPU day 😀
Nice collection - IIT, Cyrix MII, PPro, Pentium Gold Tops, and a DEC Alpha next to the K6s?
Reply 3315 of 27788, by Skyscraper
wrote:wrote:snip
Yes they are! 😀
Reply 3316 of 27788, by Azarien
wrote:Trying to fix a CRT.
Yay, it worked!
Reply 3317 of 27788, by brostenen
- l33t++
Ouch!!!!
Reply 3318 of 27788, by brostenen
- l33t++
wrote:I own two 486 motherboards and (1) 386 motherboard. I've measured all of them, and not a single one of them output any power on the cmos battery terminals at all when running. They don't charge anything.
There is a difference in barrel batteries then? Intriguing... Hmmmm...
Someone know how to spot if a 386/486-mobo need chargeable or non-chargeable batteries
Reply 3319 of 27788, by kithylin
- l33t
wrote:wrote:I own two 486 motherboards and (1) 386 motherboard. I've measured all of them, and not a single one of them output any power on the cmos battery terminals at all when running. They don't charge anything.
Probably do what I did, connect a digital volt meter to the terminals when it's on and see if it's outputting any voltage. If it does then it charges, if it doesn't then use whatever battery you have and just know you'll have to replace it some day.
Even though my 486's are on packs of nimh cells, they were specifically drained down to 3.3v (Before connecting to the machine) 5 years ago and one is down to 1.65v now the other down to 1.77v when I checked last week.
So they don't charge and they're just drain-only. I have their bios settings saved in pictures on my other machine so some day when they get low enough to lose settings I'll recharge em. So far it's going on 5 years now since this feb 2016 and haven't had to yet.
