Reply 80 of 187, by superfury
Looking at what the Turbo XT BIOS does:
mov dx, 61h
in al, dx ; Read machine flags
or al, 00110000b ; clear old parity error
out dx, al ; Write them back to reset
and al, 11001111b ; enable parity
out dx, al ; Write back, parity enabled
mov al, 80h ; allow NMI interrupts
out 0A0h, al
mov ax, 0000000000110000b ; Assume monochrome video
mov [ds:10h], ax ; card has been installed
int 10h ; initialize if present
mov ax,0000000000100000b ; Assume color/graphics video
ifdef IBM_PC ; Read 5150 switch config
mov al, 0CCh
out dx, al ; Reset keyboard
in al, 60h ; Read config switches
mov ah, al
else ; Read 5160 switch config
in al, 62h ; Get memory size (64K bytes)
and al, 00001111b ; in bits 2,3 low nibble
mov ah, al ; Save memory size nibble
mov al, 10101101b
out dx, al
in al, 62h ; Get number of floppies (0-3)
endif
mov cl, 4 ; and init video mode
shl al, cl ; shift in hi nibble
or al, ah
mov ah, 0
mov [ds:10h], ax ; Start building Equipment Flag
and al, 00110000b ; if video card, mode set
jnz @@video_found ; found video interface
mov ax, offset dummy_int ; No hardware, dummy_int becomes
mov [es:40h], ax ; int_10 video service
jmp short @@skip_video
@@video_found:
call video_init ; Setup video
@@skip_video:
mov al, 00001000b ; Read low switches
out dx, al
It seems writes to port 61h somehow affect the values of port 62h to respond with different values giving information about the machine?
Edit: Looking at the ioports.lst of Bochs does indeed reveal something about it:
0061 w PPI Programmable Peripheral Interface 8255 (XT only)
system control port
bit 7 = 1 clear keyboard
bit 6 = 0 hold keyboard clock low
bit 5 = 0 I/O check enable
bit 4 = 0 RAM parity check enable
bit 3 = 0 read low switches
bit 2 reserved, often used as turbo switch
bit 1 = 1 speaker data enable
bit 0 = 1 timer 2 gate to speaker enable
It seems bit 3 toggles something to let port 62h return different values (low/high switches)?
Edit: It looks like I was right, although setting up for two floppy disk drives wasn't so simple as I thought:
byte readPPI62()
byte result=0;
//Setup PPI62 as defined by System Control Port B!
if (EMULATED_CPU<=CPU_80186) //XT machine?
if (SystemControlPortB&8) //Read high switches?
if (((getActiveVGA()->registers->specialCGAflags&0x81)==1)) //Pure CGA mode?
result |= 2; //First bit set: 80x25 CGA!
else if (((getActiveVGA()->registers->specialMDAflags&0x81)==1)) //Pure MDA mode?
result |= 3; //Both bits set: 80x25 MDA!
else //VGA?
//Leave PPI62 at zero for VGA: we're in need of auto detection!
result |= 4; //Two floppy drives installed!
else //Read low switches?
result |= 1; //Two floppy drives installed!
else
return PPI62; //Give the normal value!
return result; //Give the switches requested, if any!
byte PPI_readIO(word port, byte *result)
switch (port) //Special register: System control port B!
case 0x61: //System control port B?
*result = SystemControlPortB; //Read the value!
return 1;
break;
case 0x62: //PPI62?
*result = readPPI62(); //Read the value!
return 1;
break;
case 0x63: //PPI63?
*result = PPI63; //Read the value!
return 1;
break;
case 0x92: //System control port A?
*result = SystemControlPortA; //Read the value!
return 1;
break;
default: //unknown port?
break;
return 0; //No PPI!
byte PPI_writeIO(word port, byte value)
switch (port)
SystemControlPortB = (value&0x7F); //Set the port, highest bit isn't ours!
return 1;
break;
case 0x62: //PPI62?
//PPI62 = value; //Set the value!
return 1;
break;
case 0x63: //PPI63?
PPI63 = value; //Set the value!
return 1;
break;
MMU_setA20(1,value&2); //Fast A20!
if (value&1) //Fast reset?
doneCPU();
resetCPU(); //Reset the CPU!
SystemControlPortA = (value&(~1)); //Set the port!
return 1;
break;
break;
return 0; //No PPI!
void initPPI()
SystemControlPortB = 0x7F; //Reset system control port B!
PPI63 = 0x00; //Set the default switches!
register_PORTIN(&PPI_readIO);
register_PORTOUT(&PPI_writeIO);
Bits 0-1 of the high switches seem to select the video adapter installed (according to the ioports.lst's values).
Bit 0 of the low switches sets 1 floppy disk when set without bit 2 of the high switches.
If bit 0 of the low switches and bit 2 of the high switches are both set, it sets 2 floppy disks it seems.
Any other combination seems to set no floppy disks at all it seems.
Anyone can confirm this or add information to this?
UniPCemu Git repository
