Reply 260 of 388, by zerker
Well, I guess Sound Blaster midi can't support EVERYTHING, nice as that would have been. I suspect Prince of Persia 2 is the same situation. Thankfully both games run flawlessly in DosBox.
Reply 261 of 388, by bjt
dehavilland wrote:
PRINCESS MAKER 1 LOADS BUT STILL NO MIDI SOUND??!!
Tested here and confirmed working with hardware MPU (Voyetra V-400x). Like Princess Maker 2, the game requires MPU interrupts and is hardcoded to IO 330 and IRQ 2/9. Setting your card & SoftMPU to IRQ 9 should work, maybe there is a timing issue.
Will test with a SB16 at IRQ 9 here when I get time - need to open up the machine to change jumpers.
Reply 262 of 388, by bjt
Actually Prince 2 runs OK through a SB16 for MIDI here. I don't think the IRQ setting in the setup program is used for anything. It's definitely a UART-only game.
Reply 263 of 388, by dehavilland
Setting ALS100 at IRQ9 is not working at least...Currently my ALS100 is configured using Intel ICU (as it is a PnP card) using different MPU of Sound blaster (2/9) and MPU401(10). PM2 is working while PM1 is not...very strange.
I also have a SB16 CT1740. I will test it too if I have time by setting SB16 to A240/I9.
Amibay username:winstonwu91
Recent wants:A cheap intelligent midi interface card, a good record player
A young Chinese student studying in US, drives a vintage car, use a vintage typewriter and loves vintage PC.
Reply 264 of 388, by bjt
I forgot that enabling IRQ generation is keyed to filename on the later versions of SoftMPU. For now you could try renaming the AUTOEXEC.EXE to PM2.EXE. You'll need to edit PM.BAT too obviously.
Reply 265 of 388, by dehavilland
Thank you!
Now midi works flawlessly by renaming AUTOEXEC.EXE to PM2.EXE. Another game for the list, right? 😎
Reply 267 of 388, by zerker
Hrm. I have at least one idea to try, so I will poke around when I have time. If it still doesn't work, I'll raise a thread in the DOS subforum to debug further there.
EDIT: And I figured it out. I was manually setting the IRQ for the MPU to the same as my AWE64. This was a mistake, as I suspect the game was clobbering the correct interrupt handler with the one for the MPU (which isn't actually used, due to UART mode). Either way, the game worked correctly if I left the MPU IRQ set to the default of 2.
Reply 268 of 388, by kbs6271
MAINBOARD - VIA EPIA 800 integrated sound chip : VIA VT1612a
- not support MIDI/GAME port
- Softmpu1.9, sb:220 irq:9 mpu:330 (dma:1) output:com1
1)Princess maker2 - pass
2)Curse of Enchantia - pass
3)David Wolf - pass
4)Innocent Until Caught - pass
5)Sorcerian - pass
Reply 269 of 388, by kbs6271
MAINBOARD - ECS P6VXM2(VIA VT82C686B) integrated sound chip and MIDI/GAME port : Avance Logic ALC100C
- Softmpu1.9, sb:240 irq:9 mpu:330
Reply 270 of 388, by kbs6271
Sound Blaster IRQ2/9 TEST
-Sound Blaster pro 2.0 ct1600
-Sound Blaster 16 ct1740 , ct2230, ct2290 , ct2950
-Sound Blaster awe32 ct3900
MAINBOARD - Abit BH6(440bx), MSI MS6309(694x)
:Abit BH6 - ACPI OFF, L1 cache OFF
:MS6309 - L1 cache OFF
1. -Sound Blaster pro 2.0 ct1600 : IRQ2 jumper setting
= Test Game : Princess Maker 2 --- fail
- Softmpu1.9, sb:220 irq:9 mpu:330 output:com1
= Test Game : Princess Maker 2 --- pass
2.Sound Blaster 16 ct1740 , ct2230, ct2290 and Sound Blaster awe32 ct3900
:ct1740(IRQ2 jumper setting), ct2230/2290(DIAGNOSE : IRQ2 setting)
:ct3900 (DIAGNOSE : IRQ2 setting)
:ACPI on = IRQ2 fail, ACPI off = IRQ2 ok
-- L1 cache OFF ----- pass
-- L1 cache on ------ fail
2.Sound Blaster 16 ct2950 = IRQ2/9 FAIL
=== ct1740 test https://youtu.be/hZJLFFrlrsU
Reply 271 of 388, by kbs6271
YMF718/719 - Princess Maker 2 test
:Abit BH6 - ACPI off
:MS6309 - Compliance with o/s off. Power Management off L1 cache OFF
-- Abit BH6 - ACPI off ----- pass
-- Abit BH6 - ACPI On ------ fail
-- MS6309 - Compliance with o/s off. Power Management off L1 cache OFF---- pass
-- MS6309 - Compliance with o/s on. Power Management on L1 cache On---- fail
:Abit BH6 -ACPI off, MS6309 - Compliance with o/s off. Power Management off L1 cache OFF
=== ymf718 test https://youtu.be/XagtjcP0jGE
Reply 272 of 388, by kbs6271
Hoontech soundtrack 97 GOLD (crystal CX4237B + dream sam9407)
:IRQ9 OK
:MPU-401 compatible MODE , MIDI FONT ram MODE
MAINBOARD - Abit BH6(440bx) : L1 cache OFF, MSI MS6309(694x) : L1 cache OFF
- Softmpu1.9, sb:220 irq:9 mpu:330 + MPU-401 compatible mode(crystal CX4237B)
3)David Wolf - pass
5)Sorcerian - pass
- Softmpu1.9, sb:220 irq:9 mpu:330 + MIDI FONT ram MODE(dream sam9407)
3)David Wolf - pass
5)Sorcerian - pass
Reply 274 of 388, by kbs6271
ESS SOLO-1(ES1938) PCI sound card : IRQ9
: DOS driver configuration file: Essolo.ini HEX : 20 02 01 00 88 03 05 00 01 02 30 03 01 00 00 00 (SB 220 irq 5 MPU 330)
====EDITING = 20 02 01 00 88 03 09 00 01 02 30 03 01 00 00 00 (SB 220 irq 9 MPU 330)
:ADD AUTOEXEC.bat
C:\ESSOLO.com
SET BLASTER=A220 D9 I5 T4
SOFTMPU.EXE /SB:220 /IRQ:9 /MPU:330
:ADD config.sys
rem C:\ESSOLO.SYS (not use)
MAINBOARD - Abit BH6(440bx) : L1 cache OFF/ACPI off , MSI MS6309(694x) : L1 cache OFF/ Compliance with o/s off. Power Management off
-Essolo.ini HEX EDITING
:20 02 01 00 88 03 09 00 01 02 30 03 00 00 00 00 === DDMA MODE
:20 02 01 00 88 03 09 00 01 02 30 03 01 00 00 00 === TDMA MODE
:20 02 01 00 88 03 09 00 01 02 30 03 02 00 00 00 === SB-link(PC/PCI) MODE
SOFTMPU - sb:220 irq:9 mpu:330
:Abit BH6(440bx) : DDMA MODE/TDMA MODE/SB-link(PC/PCI) MODE
3)David Wolf - pass
5)Sorcerian - pass
:MSI MS6309(694x): DDMA MODE(VIA DDMA)
3)David Wolf - pass
5)Sorcerian - pass
Reply 275 of 388, by kbs6271
ESS MAESTRO2(ES1968) pci sound card : IRQ9
: DOS driver configuration file: MSTRINF.INI HEX :
HEX default - 00 00 00 00 20 02 01 00 88 03 00 00 00 02 40 03 00 00 00 00 00 00 00 00 (SB 220 irq 5 MPU 340)
=== EDITING - 00 00 00 00 20 02 01 00 88 03 09 00 00 02 30 03 00 00 00 00 00 00 00 00 (SB 220 irq 9 MPU 330)
:ADD AUTOEXEC.bat
C:\MAESTRO.COM
SET BLASTER=A220 D1 I5 T4
:ADD config.sys
rem C:\AECU.SYS (not use)
MAINBOARD - Abit BH6(440bx) : L1 cache On or OFF /ACPI off
: ESS MAESTRO2 - AUTO detect(DDMA MODE / SB-link(PC/PCI) MODE , etc...)
:Abit BH6(440bx) : DDMA MODE/SB-link(PC/PCI) MODE + L1 cache On or OFF /ACPI off
3)David Wolf - pass
5)Sorcerian - pass
Reply 277 of 388, by bjwil1991
Sound card: Sound Blaster 16 WavEffects CT4170 (Vibra 16xv)
OSes: MS-DOS 7.10/Windows 98SE
CPU: AMD K6-2/300 @ 166MHz (underclocked for NHL Hockey 95 running in command prompt in Windows 98SE)
Motherboard: Abit AB-TX5 Intel i430 Motherboard
Mouse: Logitech Optical Wheel Mouse (USB to PS/2 adapter used)
Keyboard: Compaq Internet Ready PS/2 Keyboard
Monitor: 15" NEC MultiSync LCD1530V Flat panel monitor TFT
Floppy: Epson SD-700 Dual Floppy drive
CD Drives: LG 52x32x52x CD Burner & Gigabyte OEM 52x CD Drive
HDD: Maxtor 6Y200P0 @ 6GB storage due to BIOS limitations up to 32GB (7.8GB is the magic number if the drive is bigger than 32GB) UDMA 6 (ATA/133)
MIDI Boxes: Roland SC-55 (used for GM games and files) and Munt (MT-32/CT-32L) emulation software on my laptop connected to the SC-55's MIDI Thru connected via a Roland UM-One MKII USB MIDI adapter
GPUs: STB Velocity 3D (S3 ViRGE-VX 988) 4MB PCI Video card, and STB Black Magic VooDoo2 3dfx card (for 3dfx games)
Joystick: Gravis Analog Pro with throttle and programmable buttons 3 & 4 and adjustable calibration
Games tested:
A10 v1.5 - pass
DooM v1.9 - pass
Sid Meier's Civilization - pass
Lemmings II - pass
Star Wars: TIE fighter - pass
Earl Weaver's Baseball II - pass
Frederik Pohl's Gateway - pass
Indiana Jones and the Fate of Atlantis - pass
The Secret of Monkey Island - pass
Gateway II - Homeworld - pass
NHL Hockey 95 - DOS: Fail Windows 98SE: pass
Police Quest VGA - pass
Police Quest II - pass
Police Quest III - pass
Wing Commander II - pass
NHL Hockey 95 in pure DOS doesn't play nice at all, but in Windows 98SE, it plays perfectly without issues. The game music seems to have issues at CPU speeds above 166MHz.
Reply 279 of 388, by kbs6271
PCEM 10.1 SB16/AWE32 emulation ira2/9 + Princess Maker 2 test
(PCEM : XT ~ p1 emulator, http://pcem-emulator.co.uk/)
1.SB16/AWE32 configuration irq 2/9
-mainboard rom
compaq deskpro 386 -pass
dtk 386sx clon - pass
award sis 496/497 - fail
ami winbios 486 - pass
award 430vx pci - pass
intel premiere/pci - pass
2. Princess Maker 2 : GM test
*softmpu /sb:220 /irq:9 /mpu330
