First post, by ExTneicsol
I've a gus max and i just recently noticed that it just output on the left speaker ... i've check the connector and the cable and everything look fine. (and i've tested with another card and i work on both side) As i can see in the jack (side is made of transparent plastic) no broken part as far as i can see ... did i've missed something?
