Reply 3400 of 30381, by Skyscraper
wrote:That's funny, we used the same exact card to get the bracket from 😁
Regarding capturing, you might have to seriously upgrade your machine. Capturing at 1600 x 1200 60 fps my Haswell Pentium Anniversary CPU just handles it at around 70% CPU load.
I think a FX6300 would work well.
Well when you need a bracket you look for something useless to act as donor, a DVI addon card for Intel chipsets with built in video is pretty useless! 😁
I'm going to try an old Scoket-775 Asus P5K motherboard with a Q9550, if that does not work I will upgrade to a Socket 1366 motherboard with a low power 6 core Xeon.
I think I mostly will capture at 1280*1024 and lower resolutions.
