First post, by Roland User
kode54
You can convert your http://mudlord.info/products.html VST MIDI Driver in analogue SAViHost ?
The reason I ask this is the correct operation of your host, but in this case your host is required to keep open in the tab configure VSTi ... as your host has an unpleasant delay when Reproducing VST loading https://temp-share.com/f/cxfrwhccfc/5b51dca58 … c3d65d7d42dfb1b.
Reply 1 of 28, by kode54
The unpleasant delay when loading Roland's VST is due to their annoying DRM solution, which involves loading an external Adobe AIR application.
Reply 2 of 28, by Roland User
Yes , but SAVIHost by preload delay not found.
Can I make the same algorithm or introduce a delay at the beginning of Reproducing in your driver?
If yes , as ?
This delay is very desirable, but not to lose the notes.
Ideally product must be as your VSTMIDI DRV in core with interface as SaviHost , product must loaded once VST Plugins and select midi in device eg VST Loop 1 and must function minimize to tray. Once loaded VST Host be work correctly,
Reply 3 of 28, by kode54
So, you want me to copy the functionality of a closed source product? How, by reverse engineering it?
Reply 4 of 28, by Roland User
Is VST MIDI DRV closed?
I thought you wrote this driver, and you can turn it into an application )
Reply 5 of 28, by kode54
No, but SAVIHost appears to be.
Reply 6 of 28, by Roland User
No, I'm about turning your VST MIDI DRV to application with the choice of downstream such Asking name Loop 1 and select your application Loop1 input port, further functionality should be the same as it is now with the loss of correction unpleasant notes.
Reply 7 of 28, by Roland User
Please make as application VST Host , no driver mode,
Reply 8 of 28, by Roland User
The difference between your SAVIHost and VSTMIDI Drivers that's what
https://temp-share.com/f/wktjovaxpw/e7a2a8af2 … a9950c6a51da4c7
If possible, make a VST MIDI DRV so that he did not lose a piece of music or convert it to normal VSTHost application be reset synth just as it does VSTMIDI DRV
Reply 9 of 28, by kode54
But SAVIHost is not my software. VST MIDI Driver and foo_midi are my only foray into VST host software. Both are user mode software, and both use an out of process hosting system, so they support cross-architecture, as well as prevent crashes from taking out the host application.
A host application with a full editor would require significantly more work. Not to mention, I have yet to actually delve into client side MIDI input code, so I'm not sure how that even works.
Reply 10 of 28, by Roland User
Yes, I also ask, to make the conversion from the driver to the application. The application should be allowed to select the input port and delay time. And yet. Everything else should be left as it is.
Reply 11 of 28, by Roland User
Must be as in CoolSoft VirtualMIDISynth when loaded big SoundFont Banks..
There is delay and precache midi commands to play without errors and lost notes.
Analog this function
You can even make a choice at a reset before the MIDI command processing as GM/GM2/GS/XG additional on pre play
Reply 12 of 28, by Roland User
kode54
You can create very easy midi translator ?
Operating principle :
We select port for send MIDI Stream
We select mode to preset MIDI Mode.
Еxample :
We set for translate MIDI messages to Roland SoundCanvas VA port
We set for preset as GS
when receiving MIDI stream from the cigarette lighter or from another application , transport force presend message for GS reset and use.
This can create as MT-32 / GM / GM2 / GS / XG resets mode
This can be done?
Need very simple interceptor MIDI-messages with the ability to send a prefix to the selected reset mode.
Thanks
Reply 13 of 28, by Roland User
If so make , will be override for any VST synth.
Only will be need midi file with sysex reset for reset synthesizer.
EDIT
James-F
Help me please. What I ask, is useful not only for me, I'm sure of it. I just do not know how to explain kode54 more correctly. The idea I described to you in private messages.
EDIT 2
James-F
If you think what it necessary only for me. Please create interview over this theme. Perhaps after results , kode54 will be create this driver.
I'm persistent, if i believe that what this conveniently and need for more people.
Reply 15 of 28, by Roland User
More about the interesting nuances in the SC-VA
We say that in GM mode Map fixed and no user change , but :
https://temp-share.com/f/olcxffjazo/38a5d227b … 44ee270b6fad1d1
GM maps can selected if use all maps and select map by switch.
EDIT :
Soon I lay auto reset for WMP. Application will be VBScript with convert to exe.
Finish Version 1.0
As can to reset any devices ) you need only midi file with reset )
Reply 16 of 28, by Roland User
This VBScript for Users Microsoft keyboard
VBSCript interesting topics what working more devices as GS so and XG )
Enjoy 😀
If do not working , find keyboiard application and modifed VBScript in line where taskkill , there need replace filename from your Keyboard Media Application.
Reply 17 of 28, by Roland User
Final 1.01 working with all configuration and any keyboards
VBScript autor Jamal
Enjoy
Script not work if open file from browser FireFox and other.
As will be in IE , I'm not tested.
Reply 18 of 28, by Roland User
Roland SoundCanvas VA compact version : https://temp-share.com/f/lcxfrjdljl/daf4a8ed0 … aedac01e8621e15 this without crack or warez. If need activator - search in internet.
Wha Include :
SoundCanvas VA 1.02 only 32 bit version
SAVIHoST 32 bit version
Reseter for WMP (uncorrect working from browsers)
LoopMIDI
MIDI For resets and UNIreset in folder %indir%\MIDI Reset
Edit
Fixed error.
Interval too small. Reset not worked.
Reply 19 of 28, by swaaye
Split off-topic content to new thread.
