Reply 100 of 894, by sunaiac
Maybe do not show his adress so publicly 😀
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 101 of 894, by thierry
yess! , edited , upload new pic soon
Reply 102 of 894, by chrisNova777
how much do the clone cards cost..
im looking for an interface that is compatible with sequencer+ gold by voyetra
http://www.oldschooldaw.com/forums/index.php?topic=2368.0
ive tried to document some of the compatible interfaces here
Reply 103 of 894, by keropi
is there a download for this sequencer so I can test? I don't think there would be any problems running it unless it looks for a specific mpu to run.
sales thread is over at amibay: http://www.amibay.com/showthread.php?77213-Mu … bit-card-clones
edit:
just saw the free download info and requirements, don't see a reason why it wouldn't work with a PCMIDI card
Reply 104 of 894, by chrisNova777
https://archive.org/stream/radio_electronics_ … nics_March_1992
check this out this magazine appears to show how to make your own midi card with 2 in 2 out... i wonder which card it is + if its mpu compatible
it has detailed instructions + blueprints inside
re: PC MIDI card usable with SEQ+GOLD? yes of course there is a driver written especially for this type of card!!
my question is whether or not it will allow me to use more than one card to achieve more than one midi output port
i sent u a pm about this just now! and i found some interesting information on my page about the voyetra interfaces from
a newsgroup post from way back in november of 1990
its interesting because originally this program DID REQUIRE MPU-401 in the first 2 or 3 versions of the program
but they stepped away from mpu-401 compatibility when these V22 + V24 interfaces were released in order to break the boundaries that were associated with the mpu-401 standard
so they built their own driver API which they called VAPI and this allowed them to create these more functional interfaces for the apps which allowed more features that
were not possible with the mpu-401 architecture.. such as muting on the fly of notes being played + i think midi patchbay features... + the ability to have multiple interfaces working
together as one... they built their own custom standard which they had more control over.. this all began with version 4.0 of the SEQ+GOLD app + the release of the V22 + V42 interfaces in late 1990.
the time of this announcement i found . seen here --> http://www.oldschooldaw.com/forums/index.php? … msg2551#msg2551
Reply 105 of 894, by keropi
That schematic you found is for a single/dual UART-mode mpu interface , just like the one on SB cards - as far as I can tell. It lacks the "roland intelligent mode" features but I assume SEQ+GOLD doesn't care about them...
I do have 2 MPUs here so I can test whatever you want provided you describe the process and give me the needed files. I can setup one MPU at port 300 and the other at port 330 with different IRQs, this is no problem for me. But on the software side I'll need guidance .
Reply 106 of 894, by gdjacobs
Then all one has to do is strap on a microcontroller to provide metronome and the rest of the intelligent functions... like HardMPU
Reply 108 of 894, by chrisNova777
https://archive.org/stream/byte-magazine-1986 … e/n209/mode/2up
check this page out some blueprint action here - this time frm 1986!!!!!
Reply 110 of 894, by DNSDies
I'd really like to get one of these cards.
I have several games I'd like to play with their MT-32 sound, but SoftMPU causes problems, even when using two sound cards.
Reply 111 of 894, by leonk
Interested in a card as well. If you are no longer able to make these, can you open source the dump / schematics? It would be a waste to see this work disappear. 🙁
Reply 112 of 894, by thierry
i need another too , the card its great , works exelent
Reply 113 of 894, by keropi
I should have some news soon about the upcoming mpus 😀
Reply 114 of 894, by stamasd
And the world rejoices. 😀
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 115 of 894, by leonk
ARG!!! Keropi! Just take my money and send me that MQ MPU!! 😀
Reply 116 of 894, by KoenigUnhold
@keropi: I saw over at AmiBay, that the PCBs you ordered for a new batch of clone cards was lost. Do you think you will ever produce new clone cards? If not, could you please reconsider open-sourcing the design files (schematics, PCB layout, PAL fuse maps, ...)? An alternative would be to offer pre-burned EEPROMs and PALs for sale. That way you could generate a bit of revenue for the expenses you had so far.
Reply 117 of 894, by keropi
anyone interested there are some more clones available on AmiBay , assembled by Marmes : http://www.amibay.com/showthread.php?85759 - they are the same as the ones I offered quite some months ago 😀
Reply 118 of 894, by PhilsComputerLab
Great to see this project alive and kicking 😀
Reply 119 of 894, by Marmes
Hi!
Thanks keropi!
I tested this with some games, oh man, anyone with a MT32 or other module should definetly have this.
Cheers!
