First post, by kaputnik
- Oldbie
So, my Athlon rig had no I/O shield, and I decided to do something about it. Figured there are a lot of those missing out there, so thought it might be a good idea to snap a few photos and write something quick up about it, hoping it'll help/inspire others in the same situation.
The two-part I/O shield that gave me the idea. Figured it would be easy enough to just replace the middle part with one of my own making, keeping only the fastening edges.
Drilled out the rivets keeping the shield together, and cut a blank piece of .5 mm sheet metal to the same size as the old one. Used galvanized steel because that was what I had at hand. Aluminum, plastic, etc is of course easier to work with.
Cut away everything but the frame from the other part of the shield, using a regular pair of scissors. Snapped a pic of the Athlon rig's back side, corrected the perspective error in Photoshop, and printed it in 1:1 scale, to use as a punching template. Punched the centre of the round connector holes and some other strategic places, and used the old I/O shield as a template to trace the holes for the D-subs. Drilled and filed out the holes, and completely forgot to take any pics during that. Protip: a step drill bit is extremely useful when working with thin sheet metal.
Glued together the sheet and the frame with cyanoacrylate glue, and cleaned some rough edges up a bit with a piece of emery cloth.
Installed in the computer. Doesn't look too shabby if I might say so myself, and probably by sheer luck, it fit right away without any further modifications 😀
