First post, by jheronimus
Hi!
I have a Compaq Presario 433 all-in-one machine with a 486DX2 CPU.
The attachment 2016-02-14%2017.27.44.jpg is no longer available
I think it's a really cool looking machine which is why I've decided to work around its limitations — namely, a lack of CD-ROM. For that purpose I've found an external LPT Backpack drive — only to learn that there is actually a bunch of LPT standards with varying bandwidth and my Compaq seems to have the slowest one. That makes it nearly impossible to play any game that relies on having a 2x drive or higher (The Dig, Full Throttle).
So, long story short, I need an LPT controller or a multi I/O that has EPP/ECP-capable port. That turned out to be quite challenging:
- shipping controllers from European and American eBay vendors to Russia costs a lot.
- no local vendor I've come across knows whether his cards supports EPP/ECP.
- before you mention SCSI drivers — the only one I've managed to find so far was expensive and actually slow (3x, if my memory serves me).
Some people here suggested I just find any multi I/O with LPT jumpers. I did just that (namely, a Goldstar Prime 2-based card), but it turned out to only have SPP. So, having jumpers doesn't mean the card has EPP/ECP.
Today I've found a vendor with several multi I/Os. Here is the photo of all the cards (there are some modems, SCSI controllers and BNC LAN cards, too):
The attachment P1000348.JPG is no longer available
The attachment P1000343.jpg is no longer available
The attachment P1000344.jpg is no longer available
The attachment P1000345.jpg is no longer available
Questions:
1) the MP452 card mentions only Centonics parallel port with a bi-directional mode switch. Does that mean it's only good for 200 KB/S (as per here)? Seems to me that Cetronics is an earlier version of LPT that only later became standard IEE1284 LPT, so could it be that bi-directional is actually EPP?
2) what is the brown-colored sound card with Yamaha chips on the first picture?
Thanks!
MR BIOS catalog
Unicore catalog
Reply 1 of 11, by brostenen
The soundcard: https://fccid.io/KRNKTL-3180
I googled: "fcc id#krnktl-3180"
EDIT:
I searched a bit more...
http://www.yjfy.com/museum/sound/sound-8-ISA.htm
I can not find any drivers in a short time, so if they can be found, you have a tiny bit of info now. 😀
Hope this can help a bit.
Reply 2 of 11, by Jepael
The MP452 card uses a SIS 82c452 chip which is almost identical of many xx16c452 chips like on your other parallel card.
Actually it appears that the "bidirectional" in that case means the data written to parallel data bits are readable.
I don't know if it means that the external device can forcibly overwrite the data bits so that the PC can read them.
Later "bidirectional" parallel ports had an extra bit to tri-state the output data buffers so that it can read input data so that it does not need to overwrite what was written out.
So no EPP/ECP on those cards definitely.
The sound card is definitely some kind of soundblaster clone, the FCC ID can reveal at least the manufacturer.
I can't read much of the text but the chip U10, which is an Intel 80C51microcontroller manufactured by MHS, most likely has the SB DSP firmware version written on it on the bottom row, Vxyy where the DSP version is x.yy.
Edit: in the better image of the card, it's the manufacturing date. But the IO hub chip is Aztech so yeah, generic Aztech SB clone.
Reply 4 of 11, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
The ECP/EPP cards tend to come in ISA-16bit and highly integrated (not many chips on board).
1+1=10
Reply 5 of 11, by dr.zeissler
Does anyone have the description of the jumpersettings for this card?
https://computer-retro.de/Bilder/Multi-IO/LPT … 51-ISA-1996.jpg
I cannot not find it here: https://th99.infania.net/i/iio16_i.htm
All I find is that similar equipped card (chips) with a different jumperlayout but without jumperdescription.
https://theretroweb.com/expansioncards/s/snc- … urbo-wincom-i-o
Reply 6 of 11, by PC Hoarder Patrol
dr.zeissler wrote on 2026-05-28, 08:34:
Does anyone have the description of the jumpersettings for this card? https://computer-retro.de/Bilder/Multi-IO/LPT … 51-ISA-199 […]
Card has an entry on TRW with unofficial settings... https://theretroweb.com/expansioncards/s/unknown-io4s3p-a2
Reply 7 of 11, by dr.zeissler
Very helpful thx!
Reply 8 of 11, by BitWrangler
h-a-l-9000 wrote on 2016-04-22, 22:12:
Yah, I would figure on looking for "late" ISA i/o, 94 or newer, single ASIC, probably any boasting of having a 16550 UART have ECP/EPP also.
Reply 9 of 11, by dr.zeissler
Seems that there is no way to jumper the LPT to $3BC on that card.
My card is missing settings for LPT3 exactly like the card shown in the picture here in the thread.
$3BC setting for my card should be the green marked block, either for LPT1 or LPT2 but in MSD I always get 278h.
The target I have to set is LPT2 and $3BC and IRQ5.
Reply 10 of 11, by weedeewee
dr.zeissler wrote on 2026-05-28, 20:28:
Seems that there is no way to jumper the LPT to $3BC on that card. My card is missing settings for LPT3 exactly like the card sh […]
Looking at your photo and the TRW guessing info, I'd say you have your card set for PRT2 io 278.
my guess for setting PRT1 to 3BC would be to have the one jumper in the PRT1 block on the TRW guessed documentation.
Haven't looked at the IRQ settings yet.
edit: I guess the middle photo in the TRW guessed documentation is wrong.
Do not ask Why !
Reply 11 of 11, by dr.zeissler
Interestingly the setup works as LPT2 and 278h/I5 too so no need to set it to $3BC. Thx guy's for the support!
