Raw reads from PS/2 port
First post, by xjas
Is it possible to see all the raw data coming in on a PS/2 keyboard port? Can I point a serial terminal at it somehow?
I'm trying to reverse engineer my Creative Prodikeys. 😉 I'd like to know if it is sending MIDI messages down the PS/2 bus or something else.
Reply 1 of 13, by .legaCy
I guess that might be possible because hardware ps/2 keyloggers exists.
But i have no experience with it.
http://forum.arduino.cc/index.php?topic=2526.0 Maybe it will help
Reply 2 of 13, by xjas
Oh cool, that's actually related to my end goal. B) I want to build an Arduino device that acts as a PS/2 passthrough for the QWERTY keys but filters out the MIDI messages and sends them to a standard DIN5 jack.
Reply 4 of 13, by .legaCy
So you will use the man in the middle setup, you will forward the standard keyboard keys to ps2 and the midi messages to DIN5.
It will be connected like
(prodikeys)--> (arduino)---->(ps/2 jack)
+---------->(DIN5)
And you will code the part that receive the signal, check for standard keyboard keystroke and send to ps/2 and if the signal is not a standard keyboard keystroke you should send to DIN5
Of course there's a protocol that you will need to know to do this "routing" but i guess that on arduino forum should be enough documentation to achieve your gozl.
Reply 5 of 13, by xjas
That's the way I'm thinking right now, but it's only one possibility. 😀 A TSR DOS driver could even work too (bodge SoftMPU???) but sacrifices some flexibility. There's actually very little info out there on how these work. I'd love to be able to just mod in a MIDI port.
Reply 6 of 13, by .legaCy
I dont know if it will work but instead of filtering midi messages from standard keystrokes you could try to replay them(if midi interface will detect the standard keystroke as a bad and drop it
Reply 7 of 13, by BloodyCactus
when dealing with midi you need to be using optocouplers to isolate the midi uart signal. also midi is a non standard uart speed (31250), so you need to get your arduino clock to accept non standard baud rates within the error margin of 31250.
Reply 8 of 13, by Jepael
There are no optocouplers on MIDI outputs, and 31250 is perfectly standard uart speed with zero error when using 16 MHz clock source, affected only by the clock source tolerance.
MIDI specs require 1% baud rate tolerance, usually Arduinos have ceramic resonators and those should be within 1% tolerance unless some extreme conditions apply.
While the keyboard is connected to PC, you should be able to sniff the scancodes passively with Arduino and transmit MIDI messages.
Reply 9 of 13, by BloodyCactus
not all arduino have 16mhz clock source 😀 but yes, the 16mhz ones have a perfect divisor for 31250 baud rate, and it would be fine with anything that has a 16mhz divisor too..
Reply 10 of 13, by xjas
I'm actually wondering what the native clock rate on the keyboard itself is. The PS/2 clock is driven by the *device* but 31250 is out of spec. If this thing runs the PS/2 port at that speed making it work like I want to would be pie.
I suspect it doesn't and the signals were resampled (" ") in its original software.
Reply 11 of 13, by bjt
Pretty sure the keyboard keys will just be custom scancodes, you can sample them using any keylogger program.
The translation to midi likely happened in the software.
Reply 12 of 13, by BloodyCactus
ps2 used to be hooked to the 8042 controller chip and setup for IRQ. ps2 is weird, since it contains the A20 gate code.
lots of companies made the bigass DIP chip thats in old ps2 keyboards. I have no idea whats in a modern one.
its clock rate is 'falling edge', so you can bitbang it at any speed you want provided the controller can feed at the same rate
Reply 13 of 13, by gdjacobs
Some have 20mhz 😀 That works too.
