First post, by PhilsComputerLab
Not sure if anyone else finds early ATI cards all over the place with naming them and specifications.
A Radeon 7200 can come with all sorts of core and memory clocks, there seems to be no guarantee as what you're going to get. Same goes for older cards with Rage 128 Pro. Could be an OEM card that won't work unless you modify the drivers, clocks all over the place. Even the specifications online, in reviews and from people vary greatly.
Did ATI just let everyone free rains when it came to this sort of stuff?
I'm finding the best way to get these cards is by going for the early models that match the photos of releases. Saphire cards and others often come with surprisingly different clock speeds, but no difference in model number.
Reply 1 of 18, by leileilol
Radeon's relatively easy considering the confusion of the earlier Rage and Xpert@ branding (and it certainly doesn't end there either)
Reply 2 of 18, by PhilsComputerLab
Yes that's exactly what I'm talking about. It took me a while to find a "proper" Rage 128 Pro. They go under the name of Fury and Xpert@ and all sorts of other terms.
Then Rage6, but also Radeon DDR...
Reply 3 of 18, by ODwilly
The All-in-Wonder cards are even worse. It was not until recently that I realized that my old 32mb cards were actually Radeon 7200 DDR's. The all in wonders all use the same Rage Theater chip from the Rage days so it was challenging even figuring out if my cards were SDR or DDR. Let alone what gen they were.
Reply 4 of 18, by elianda
I usually go for PCI VENDOR / DEVICE / SUB IDs. Then adding memory/core clock rates, memory bus width and type. Then I just look up in tables which card it is.
Youtube Channel
Reply 5 of 18, by PhilsComputerLab
Yes. I wish sellers would go through the effort and do that 😀
Reply 6 of 18, by sunaiac
Haha, I have the same problem.
My collection of early nvidia is quite good, so I'm trying to get the ATIs now.
But since I have no idea what sellers sell, nor how to find the actual card I'm looking for, the progress on that front is more or less stalled.
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 7 of 18, by PhilsComputerLab
Glad to see that I'm not alone 😊
Nvidia is indeed quite straight forward.
What GPU ID tools are available for Windows 98? I use PowerStrip often, it shows the clocks but nothing about the core configuration. I tried an older version of GPU-Z but it crashed with an error, I think it was missing a DLL.
Reply 8 of 18, by leileilol
Powerstrip's great. It even id's weird laptop gpus well and even PowerVR PCX cards
Reply 9 of 18, by PhilsComputerLab
It's also great for v-sync control. The Matrox provided tool for example doesn't work for me, but PowerStrip works.
Reply 10 of 18, by Putas
You do realize the Theatre is not a graphics chip communicating with memory?
Reply 11 of 18, by Munx
Not when it came to the 8xxx and 9xxx series though.
640MB 8800gts being weaker than a 512MB 8800gts is a good example.
My builds!
The Underdog - The budget K6
Reply 12 of 18, by vlask
Only AIDA64. Work in W98 and can identify a lot of cards. Still some minor models not and they do not seem to want to update them (too old, i asked them). Still can do much more than GPU-Z. GPU-Z is Win XP/ATI/Nvidia/Modern Intel only - it has no detection of Matrox or S3 cards and showing bad memory clocks for SDR cards for example. Also new versions freeze (use 0.7 or older) when used on older cards like GF 4MX and similar. Autor dont support also anything older than year 2000 (with few exceptions like Riva TNT).
http://www.aida64.com/downloads
Not only mine graphics cards collection at http://www.vgamuseum.info
Reply 13 of 18, by PhilsComputerLab
Sounds good, I think I have that program on my file server, will check it out for sure.
The Rage 128 Pro quite impressed me when I benchmarked it recently. The 16 bit image quality is a bit poor, but the card really shines at 32 bits, it loses much less performance than the other cards.
Reply 14 of 18, by ODwilly
Yep, but seeing as how the 7000 series cards look identical to the 8000 series it was difficult to figure out what drivers were the proper drivers, back then I knew nothing about CPU-Z or Powerstrip or anything like that. Combining the words "Radeon" and "Rage Theater" and 32mb made for some confusing google searches.
Reply 15 of 18, by PhilsComputerLab
Yea it doesn't help that's for sure.
Does anyone else feel that Rage is a better name that Radeon?
Rage Fury sounds pretty decent. Radeon reminds me of...
Reply 16 of 18, by leileilol
Nvidia's got a worse problem.
Reply 17 of 18, by nforce4max
It wasn't that bad and back then one could have done a google search then found out which was what unlike some of the older ATI cards. Geforce 9 series was straight forward unlike some of the rebrands that came later when you had low end Fermi cards when everything else was Kepler ect.
Reply 18 of 18, by ODwilly
leileilol wrote:
Nvidia's got a worse problem. […]
Now lets hope Nvidia does not see this post and decide to adopt new mascots for their next gen graphics cards 😵
