First post, by ExTneicsol
Does anyone know how? I'm trying to modifie the prepgame.exe from the GUSpnp to work with the compaq ultra sound 32 pro.
After I flashed my GUS PnP clone card it suddenly worked well with all stock GUS PnP software. Is that an option for you?
You can't "decompile" a DOS program generally. The best you can do is "disassemble" the program, which will get you a huge load of assembly language that will still be pretty meaningless without meticulous, manual analysis.
wrote:After I flashed my GUS PnP clone card it suddenly worked well with all stock GUS PnP software. Is that an option for you?
Yes after i've done that it worked right away (used the ini of the compaq, changed the id of manufacturer also) but it mean we will probably loose the InterWave Tone Control ...
It is not the first program i see patched, i know i've not the expertise to do it ... but at least i can try.
