Kreshna Aryaguna Nurzaman wrote:I was about to suggest microphone preamp, but I guess it's cheaper to buy DAC with good recording capability, like Behringer UCA-202 or 222.
I looked those up, they need RCA connectors? I don't have a splitter cable...
clueless1 wrote:What distro are you running? I've had mixed results with various linux distros and their audio mixers. Maybe a trip to your distro's support forum will pay bigger dividends.
Linux Mint, but it's no different than any distro with a ALSA+PulseAudio mixture. I honestly think it's a flaw with my integrated audio as I had this same problem under Windows 7. Last time I asked for help about something there I got zero responses despite bumping multiple times, THEN their webserver got hacked.
So... yeah.
ratfink wrote:Have you tried using noise removal in audacity. Was pretty good in cleaning up some of my noisy recordings. Not the same noise problem, but it might help.
It ends up butchering the actual audio, the noise is too great. I sound very muffled over Skype, Teamspeak, Mumble, anything with a "noise cancellation" filter built in.
mrau wrote:could you upload a sample?
Here's what it sounds like at base level: https://dl.dropboxusercontent.com/u/45822870/ … thoutBoost.flac
Here's what it sounds like at maximum gain + maximum "Microphone Boost": https://dl.dropboxusercontent.com/u/45822870/WithBoosts.flac
Note how the noise is amplified and overpowers most of the audio, and how the audio itself is more high frequencies than low.
― Κυνικός Δράκων
