First post, by badmojo
Hello experts,
From what I understand, these Creative MIDI cables (which came with some Live! / Audigy cards) can be used with the MIDI in / out ports on a Roland SCC-1.
Can anyone confirm or deny please?
http://www.ebay.com/itm/Creative-5-pin-Mini-t … 4cAAOSw5VFWK5~E
Thanks!
Reply 2 of 11, by firage
Yep, seems to line up in testing. Made a beautiful illustration for posterity.
My big-red-switch 486
Reply 3 of 11, by badmojo
Fantastic! Thanks for going to the trouble to confirm and thumbs up for the beautiful illustration!
I've just bought 2 of them for 9 bucks 😎
Reply 4 of 11, by Skyscraper
Can you link the Creative mini DIN ---> DIN MIDI cables you bought (if there are more of them), the ones I find always seem to be $17 - $20 for a single cable, with expensive US or Canadian shipping.
Reply 5 of 11, by badmojo
Sorry I just got lucky, the seller doesn't seem to have any more. You could ask though I guess, here's the auction link:
http://www.ebay.com.au/itm/172167154145?_trks … K%3AMEBIDX%3AIT
Reply 6 of 11, by Skyscraper
Thanks, I doubt he has more cables as he dosn't seem to sell much stuff.
I guess I have to build my own cables as I'm too cheap to buy the expensive ones. 😀
This mini DIN connector looks good.
http://www.vetco.net/catalog/product_info.php … roducts_id=6590
Reply 7 of 11, by badmojo
Just wanted to report back that the Creative cables work fine with a Roland SCC-1.
Reply 8 of 11, by HighTreason
I've been using an SCC-1 cable with an Audigy 2 for years which, as is obvious by now, has worked without issue though mine does not appear to connect the additional two pins anywhere. Means nothing as the Audigy wouldn't use them anyway, only some obscure manufacturer specific stuff ever made use of those.
It is about the only legitimate use I have found for the SCC-1 in all the years I have had it. They should have just put a bunch of those cables in that ugly yellow box and called it done.
Reply 9 of 11, by firage
Huh? It's a fantastic board, for both its intelligent mode interface that's better integrated than LAPC-I's (smaller card, no external adapter weirdness, no -5V requirement) and the best GS/GM compatibility around including capital tone fallback.
Reply 10 of 11, by PeterLI
Great product. But @ USD 300 a SC-7/55 module is more economical. 😀
Reply 11 of 11, by gdjacobs
Although I generally defer to your knowledge of all things MIDI, I see the SCC-1 and a sound card hosted MPU-401 UART plus SC-55 as an apples and oranges comparison.
