First post, by mzry
Heya,
I noticed the PCI versions have the soldering points on the PCB for the missing DVI port. If someone just soldered a DVI connection on there would it work?
Heya,
I assume so as I think the only difference between the Mac and Windows version is the BIOS and DVI port.
wrote:Heya,
Not really. The reason is that not only the DVI port is missing on the V5 PCI from your picture but also the Silion Image chip and related SMDs next to it. See bellow the pictures of V5 MAC and the V5 PCI to notice the differences from a HW perspective:
http://www.tdfx.de/pic/voodoomac_5500_01b.JPG
http://www.tdfx.de/pic/voodoo5_pci_01b.JPG
There were some OEM V5 PCI cards with Silicon Image and SMDs without the DVI connector but those aren't too common.
The BIOS is the last piece to make the DVI-D work and the appropriate version you can find here:
http://3dfxbios.cl-rahden.de/index.php?title=Voodoo5
Good luck,
G1nX
Retro-gamer & VGA Collector
Powered by Voodoo5 6000
Ouch okay, not such an easy fix then 😀 Thanks for the advice!
