ultramars wrote on 2020-12-23, 09:53:i found out about softMPU, but i'd like to make music with cakewalk pro for windows, that only accepts clever MPU-401 interface […]
darry wrote on 2020-12-18, 07:00:
However, using the SoftMPU utility will let you emulate an MPU-401 over a serial interface.
EDIT: What motherboard are you using ?
i found out about softMPU, but i'd like to make music with cakewalk pro for windows, that only accepts clever MPU-401 interface (or just the original one), and there isn't any softMPU for windows so far 😒
a sound canvas with serial interface is cheaper than the modern clone of the MPU-401, ( let alone the original card 🤣) so i was hoping to get a cheaper fix with a sound canvas + an interesting sound module.
It'd be interesting to figure how the serial midi inteface reports to windows (3.x or 9x) through its windows midi drivers: is there maybe a chance that it appears to the cakewalk as a valid clever MPU-401 ?
i will soon get a 80486 central unit from a friend, but i don't know the motherboard model yet.
Thanx for your reply ; i didn't get any email about it though: i'm gonna have a look about weather i can set up such email alerts in my profile
MPU-401 compatibility is only required for DOS applications.
Windows applications can use any MIDI port for which Windows has a driver installed . An MPU-401 compatible interface is not required for Windows .
To use a serial MIDI cable under Windows 3.1, the proper driver is required . The only Windows 3.1 driver package for Roland serial MIDI drvices that I have found is this . It contains drivers for both serial MIDI and MPU-401 . You must use the serial MIDI one, not the MPU-401 one . Contrary to what the file name says, this should not be SCC-1 specific and should work for all serial MIDI equipped Roland devices as far as I know. In fact, the serial MIDI part likely does not even apply to the SCC-1 as I has no serial port interface as far as I know .
The attachment Roland-SCC-1-MPU401-Windows-Drivers.zip is no longer available
EDIT : Source is http://www.houseofsynth.com/roland-scc-1-wind … ndows-95-driver
