Reply 12060 of 53149, by adalbert
Just received a box of hardware:
2x Voodoo II PCI 12MB VRAM
2x GeForce 2 MX
1x Yamaha XG YMF724E PCI
1x Sound Blaster Live PCI
1x 3COM Fast EtherLink XL PCI
1x 3com 3c905CX PCI
1x SATA RAID PCI
1x SCSI PCI controller (full length) with memory and CPU
1x 50 pin SCSI controller
for ~30 EUR shipped.
    1.25 MiB
Reply 12061 of 53149, by HighTreason
Paid off my debt to PayPal.
Bought a PAS16 - I believe it is from another Vogoner but the transaction did not happen on this forum, so no rules were broken. Looking forward to that getting here because I have really really missed my Pentium and whilst I can run it without sound or with a shoddy ESS I have spare, it just isn't the same.
I also grabbed an S3 Trio 64V+ with Scenic MX2 because I had no luck with my ISA RealMagic card (It was stubborn and awkward to operate) plus I always wanted to play around with one of these. Helps that it wasn't really too costly either. Here's the listing. Such devices probably aren't much interest to anyone else, but I'm a video guy, I originally got into this hobby out of necessity specifically because I am a video guy, I find cards related to video decoding or encoding interesting and like finding excuses to work with them.
Reply 12062 of 53149, by Cyrix200+
Cool, I have seen dozens of cards with the 'Scenic Highway' header, but never the actual addon card!
1982 to 2001
Reply 12063 of 53149, by keropi
HighTreason if you find out how to use the Scenic decoder do tell, I had no luck with mine:
Reply 12065 of 53149, by HighTreason
There's every risk it won't work, but it wasn't much more than a Trio 64V+ with the extra RAM anyway so I figured it was worth a go.
I have driers for Win31 (Which the intended system is using) but these appear to be locked down to the Trio 64V+ though this may not be the case. It appears that you have to install VFW (Possibly modified by S3 like some Viper cards required) and the Scenic driver, then it will use the regular Windows applications.
I can upload the drivers I have if you like, but obviously I don't even know if they work on mine yet and who knows what they might do if they don't work - the SPEA VFW for the ShowTime basically disabled video entirely once the card was removed and it was not easy to make the OS work again, I ended up re-installing from scratch in the end. I'm happy to risk my Windows install on my card as it's a clean install and will probably break anyway due to other changes in the system since.
I really ought to look into access to Vogons Drivers...
Reply 12066 of 53149, by chose007
another things came to me
Chieftec for watercooling project and Tyan 2x sA in it like bonus.
few 512 rimms
and lot of vgas
Creative G256
Asus TNT 2 PRO Deluxe
Hercules G2 GTS
Hercules G3 Ti 500
Asus FX5800
Club 3D R9700
and some newone but not usual
3870X2 with DDR4
and 2x 3870X2 with DDR3 + lot of blocks
new one MSI slotA
Reply 12067 of 53149, by keropi
mrau wrote:
@keropi may i ask what you have tried? imho it should be as simple as inserting the add-on and running a supporting media player (xing i think)
It's been some time now but I am pretty sure I did not try XING. I installed the vga's driver, the "S3 Video Live" thing and just tested with mpeg-1 files with windows media player (IIRC).
I'll hunt down XING for a future test 😎
Reply 12068 of 53149, by mrau
http://www.s3graphics.com/en/drivers/legacy_s … re_archive.aspx this may be relevant,
http://www.ebay.com/itm/S3-Hardware-MPEG-Boar … =item51dfaef5d4 photos suggest it works more like HighTreason says, in the manual it says tojust open an mpeg file via media player;
Reply 12069 of 53149, by Cyrix200+
That makes me feel a bit jealous! Where did you find it?
chose007 wrote:
another things came to me ... new one MSI slotA […]
new one MSI slotA
1982 to 2001
Reply 12070 of 53149, by ODwilly
I am pretty sure there is still an ebay seller selling those MSI boards NOS for a reasonable price.
Reply 12072 of 53149, by Jade Falcon
Rank BANNED
BANNED
new one MSI slotA
There a seller on eBay selling them nos
I bought one but it was a dud and was missing it's I/o shield. I got a full refund and got to keep the board although.
Reply 12073 of 53149, by Jade Falcon
Rank BANNED
BANNED
My most recent hall.
Sorry for the crummy photo.
I got 3 pent 2 a pent 2 celly. A 650mhz 100fsb pent3
Gigabyte rage 128. Tnt card of sorts. 8500 agp. S3 virge, slocket and some sort of 3dlabs card.
Reply 12074 of 53149, by Lukeno94
Here are my latest purchases:
The Toshiba T4600 I think I mentioned earlier. After having the PSU board recapped, it now fires up fine, but still needs some attention; I need to sort some of the cabling layout inside, and the floppy drive doesn't work (it just makes a horrible whirring noise, almost like a belt has come off the motor if that's how it works), so I'll have to load MS-DOS and Windows 3.11 on another system. I'll use a 512MB CF card with it, as the 800MB HDD it came with is also bad - as were most of the floppy disks it came with, sadly. I do have its original power brick, which works fine. it has a 486SL @ 33 MHz, a monochrome display, and 4MB of RAM.
A Powerbook G3 "Wallstreet". Don't know exactly which model this is, thanks to the smashed screen (although it is a TFT); it was sold as being a 400 MHz Pismo, which it isn't. The HDD does work and it boots up fine to Mac OS 9, but there's a login password so I haven't gotten any further yet. It does have a good battery though, and the CD drive sounds like it should be OK. Also, does anyone know what language the non-Latin characters on the keyboard are from?
An IBM ThinkPad 560X. This is an incredibly thin and light laptop - few modern ones will be lighter. It doesn't have any internal floppy or CD drive, but it works fine with the TP600 external floppy drive, and I hope the PCMCIA ports work. I had to fit a HDD (a 10GB drive), and that now shouts "OMG you have bad sectorz" at me... because I'm pretty sure the BIOS doesn't recognise anything bigger than 8GB. With a bad main battery and CMOS battery (the latter isn't even fitted right now), I can't update it, yey! Everything bar those batteries seems to work fine though, at least what I've tested so far. It has a 233MHz Pentium MMX CPU, NeoMagic MagicMedia 128XD graphics, and a 12.1" 800x600 screen.
I also bought another Satellite 460CDX for parts, although I need to find my longer screwdriver, and sadly both its CD drive and battery were stone dead (the CD drive doesn't even try and spin a disk, which I've never seen before - the light just stays on solidly).
Reply 12075 of 53149, by luckybob
my money is on Japanese.
http://www.wikihow.com/Tell-Chinese,-Japanese … n-Writing-Apart
Reply 12076 of 53149, by brassicGamer
I'd be pissed off if I got a Wallstreet instead of a Pismo. It's not even like the differences are that subtle - the Pismo is pretty much a completely different colour! Love he design of those laptops - totally modular and so very easy to service. Could be worse - the early models with passive matrix were a bit shit.
Reply 12077 of 53149, by HighTreason
Whilst I haven't technically bought it yet, I have just placed an order for the 12" vinyl of "Megatronic - Power of dancing" because it is one of my favorite records - especially the Deejays Mix which is on said vinyl - and therefore I must own it on a proper medium instead of a crappy digital knock-off.
Never ordered from anyone on Discogs before so I hope it goes smoothly, the seller has to determine the total manually. He seems to have a 100% positive rating anyway, so if that is saying anything there should be no problems and it shouldn't cost much (Around 4 Euro for the record and supposedly 7.50 Euro shipping) so I won't be too upset if it does end horribly. You don't know if you don't try and I have never seen this record come up on eBay.
With pretty much all the computing stuff out of the way, the hoarding of records has begun. Past a few last repairs I have to do or missing parts for a couple of machines I doubt you'll all be seeing me in this thread very much in the future as I won't fill it with non-computing items. I expect I'll still grab the occasional thing though and I'll surely be around in the Modern Hardware and Dumpster Find thread, plus I'll still be as active on the forum as ever because I'm not giving the computers up, I just own as much of what I wanted to own that I'm ever likely to find and have been priced far enough out anyway that there's simply nothing much left for me to buy anymore. I have thought for a while about trying to get away with starting a "What retro music have you listened to lately" thread, primarily so I could annoy everyone with obnoxious 90s beats and questionable 80s ballads, but I figured it wouldn't fly and I can't be bothered to venture to other parts of the forum to see if something like that exists already.
I'd better stop now so I can pay the rent this week.
Reply 12078 of 53149, by Lukeno94
I wasn't entirely amused, considering the whole reason I bought a Pismo was to take the screen across from my defective Lombard, which may have needed a cable swap, but otherwise shouldn't have been problematic. That, and whilst it wasn't exactly bank-breakingly expensive, it was also a little more than I'd have ideally liked to have paid., Goodness knows if I'll be able to do that screen swap with this, not least since I know it doesn't have the 14" screen, but hey ho. At least I know the VGA out works, although it didn't want to boot from a CD-RW of Mac OS 9's installer (unsurprisingly).
The pictures weren't clear enough for me to make out the model code, and I'm not familiar enough with Powerbook G3s (or at least, I wasn't) to spot the difference in blurry photos.
Reply 12079 of 53149, by BloodyCactus
Got a CT3980 from a guy at work, an awe32 with all the fixings. Dropped 2x16mb sticks and diagnose.exe tested the ram, said its all ok!
I wrote an old dos awe32 s3m player.. now I need to find the source for it 😒
