Reply 40 of 90, by mrau
i guess it should do :>
If you have a better idea, im all ears. Now is the time to find this stuff out properly. Once i load everything down with 20+ games, things might be different.
i thinks its worth a shot/benchmark
Any chance of a 3dmark 2001 benchmark with a dx9 card? I suppose any of the Geforce 5 series or ATI 9000s will max the score out, I'm getting around 1,800 on my machine.
A dx9 card on PCI is going to be a challenge. The fastest pci card I own is the ati 9250. And I have yet to find it. I will happily oblige if I can get the card found.
In other news, I did some more testing. I was faffing about with performance test 6.1, which is a newer version of passmark 4.0 if i'm correct. It had three "advanced" presets for hard drive testing. workstation, web server, & file server. Each basically set a slider defining % read to write, random % and such. No test gave any sort of conclusive results that I could measure. I then decided to run all three tests at once and a 4th thread on a network drive. Hoping I could just saturate the damn thing and get some results. All tests were done with the onboard scsi and the 15krpm scsi drive I have. The network was limited to a 10/100 as I have yet to get a gigabit card that works with pci 2.1.
images: http://imgur.com/a/6w2eb
some reason the 3rd thread got almost zero in the scores. If I ran just one test, I get the highest mark almost exactly. I'm probably not doing something right. any advice?
7.2 -7.4 mb constant, something is being saturated here for sure; pci device with dma without i960?
i will look into it. hopefully i can find something.
but can you tell if its a pci device with dma without active i960? also how fast is a single thread?
finally found a working gigabit Ethernet card. It is a stock Intel one. had to force it slightly into the pci slot because the card itself is pci-x. Made no difference in the previous test. however I did find a client?server benchmark in this suite. so I installed it on my 2x quad core xeon monster and had a run with that.
I tested several 6 different ways. send, receive, and 2 threads. cached and uncachced for each. Well, the only concrete results i got were the i960 caps out at 70mb/s. when in bridge mode, I can cap out the pci bus at ~93mb/s. It is slightly interesting how the 2 threads took 2 cpus to 100% each. and on my xeon the test didn't even register on the cpu usage meter. 😜
the testing continues!
wrote:the testing continues!
That's super!
I have found a 2nd board!
Well kinda. It is actually a Supermicro P6DLH. just won it yesterday. http://www.ebay.com/itm/301969642018
now this wont be a dual socket 8, but dual slot 1. The auction comes iwht a pair of 333's! I did not have a pair of these chips, so I can scratch 2 things off the list. The only difference between the p-pro overdrive and real p2-333's is the L2 cache. The overdrives have fullspeed cache, instead of the 1/2 speed of the "consumer" P2.
So I can now do a bit of testing betweent the chips. the slower cache is a negative, BUT it might be offset by the faster main memory (sdram). YAY! Isn't this fun?
Dual CPU's = fun
Slot CPU's = fun
wrote:Isn't this fun?
Fun doesn't cut it anymore! I'm not sure this amount of enjoyment is even legal!!!
Very nice! I know you've been searching along time for this board!
Have the UP5 myself with dual socket 7 or dual Pentium Pro and 512mb RAM. Finding an AT case for UP5 was hard, but in the end I managed to mount it in an ATX case without modding.
Got another motherboard recently. A Supermicro P6DLH. VERY similar to the asus. But overall a board that has several pros and cons compared to the P65UP8. Basically it comes down to how you want to use the board.
edit pic:
Different pci placement, no onboard scsi, daughtercard, chipset, overclocking!
I haven't played much with the new board much, but it seems to work fine at first glance. It supports overclocking! the board has silk-screened options for 50 to 75mhz fsb. I googled the clockgen chip and it has MANY more options. Most notably it will go up to 83mhz fsb. This works fine on the P6DLH, but the overclocking is disabled on the P65UP8. Same chip. I was REALLY hoping I could overclock the p-pro OD chips. the P65UP8 has the same clockgen, but I suppose the daughtercard overrides the jumper settings somehow. Or the OD chips set it to 66mhz, or both. Anyway, I did a few basic tests and they came out exactly as you would expect a p2-333 would be. it does work just fine @ 83mhz! This new board has the bios option for USWC, but I only get ~17fps in quake. So yea, I do need to investigate this.
how fast are these OD's compared to normal p2?
is the graphics card on the i960 or the other ports?
wrote:how fast are these OD's compared to normal p2?
significantly. The core is identical, but the overdrives have full speed L2 cache, where the normal p2 uses 1/2 speed.
I have the gfx card on the normal pci bus.
wrote:significantly.
yes yes 😀 but any tests that you have done that would allow for direct comparison?
wrote:I have the gfx card on the normal pci bus.
did You try those special cpu tools that are usually mentioned here when someones doing and amd build?
no, not yet. I do have it on my short list of things to do.
what cpu tools are you referring to? Also, this is Intel, so I hadn't thought to even look at them if I'm honest.
MTRRLFBE http://rayer.g6.cz/programm/programe.htm this or similar ones; im not sure if this one works with p6, it shouldnt set your box ablaze either way
more's mentioned here https://en.wikipedia.org/wiki/Write_combining
I've had success increasing the dos video performance on my PR440FX @ 350mhz, I switched the video card to an Nvidia FX5500 128bit 256MB.
The quake demo3 performance was only 16.1fps without fastvid running 640x480 fullscreen minus 2, running fastvid the score increases to 28.6 it runs very nice despite the resolution it looks sharp unlike most accelerated games appear that muddy(at 640x480).
Speedsys
Memory EDO DIMM - 256mb
Memory Bandwidth - 263.88mb/s
Video - 79,327kb/s
CPU score - 402.21
Datacache L1 (16Kb) - 1331.68mb/s
Datacache L2 (512Kb) - 495.11mb/s
Memory throughput - 138.41mb/s
Quake 640x480 - minus 1 fullscreen
demo1 - 29.2fps (80.3fps @ 320x200)
demo3 - 27.7fps
Pcpbench 640x400 - 49.1fps
3Dbench 2 - 469.2fps
Does it look like memory is holding the system back? I'm not sure what this machine should be benching.
