Reply 12220 of 59961, by devius
Good luck setting it up. I still haven't managed to make mine work properly, although I only tried it on one motherboard that was a bit limited in terms of BIOS options, and gave up after a whole day trying.
Whatever you do make sure you install it on a motherboard that allows reserving specific IRQs for legacy ISA devices.
Retro Coisas no YouTube
Reply 12221 of 59961, by Lukeno94
brassicGamer wrote:
Right who won the Voodoo II for 2 quid on ebay last night? Can't believe i forgot to raise my max bid!!!!
Holy hell. I thought my VII was cheap, given the usual prices... but that's just awesome!
Reply 12222 of 59961, by brassicGamer
It was one of those that went under the radar because it didn't have 3DFX or Voodoo in the title. I'm so gutted, as it had the SLI cable and I've been looking to complement my current VII for ages. Ah well, patience is a virtue.
Reply 12223 of 59961, by Lukeno94
Mine came with the SLI cable and the driver disk as well, but £2 is a good price for ANY graphics card!
Reply 12224 of 59961, by nforce4max
Cyrix200+ wrote:
Bought a bunch of random memory on 'Marktplaats', our local auction site. I was mainly interested in the cache modules. […]
Unfortunately, I got confronted with the same problem as others have recently: bad packaging 🙁
Good thing it was on not so interesting memory. Could probaby solder the components back on, but I don't know if it's worth the trouble, I'm drowning in SDRAM. Might be good practice in soldering 😀
Does anybody know what the module in the middle is? The shorter one? Looks a bit like notebook memory? I haven't got a better picture at the moment.
One of those cache modules looks very similar to one that would be used in some 486 Compaqs, I could be wrong but I have ran into some in the past but they did not have the module install but just the empty slot. The one in the middle and not the two pipeline burst modules on the left.
Reply 12225 of 59961, by Bancho
Won these 2 Inwin Powerman 300watt PSU's for £5 delivered off ebay! The packaged was 6kg, wouldn't be surprised if it cost more to send! They certainly have some "Heft" to them. Going to replace the rubbish 200watt PSU in my Pentium III machine.
Reply 12226 of 59961, by stamasd
Cyberdyne wrote:
stamasd wrote:
Found a cheap(-ish) IBM PS/2 model 30 (8530) motherboard, with 286/10 CPU. Unfortunately it doesn't include anything else, especially not the ISA riser board. What are the odds that I'll find one of those somewhere? OTOH it has on-board MCGA video.
This is my first foray into non-PC x86 hardware. Should be fun.
The 286 version of Model 30 had full VGA on board!
I don't have first hand experience with PS/2 systems and the information on early models is scarce. However wikipedia seems to disagree - and we know wikipedia is never wrong. 😀
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 12227 of 59961, by brassicGamer
devius wrote:
Also, it looks like you got a box full of trash 😢
Looks like? Turns out i did. Tested everything today - none of the cards work and i am locating drivers for the XG before i pass judgement on that - already had to replace a cap that had been ripped off. Half the motherboards work and fortunately it was the more useful ones (MVP3 + 4, Slot 1). Plus the K6-2 and the PIII is good. I've asked for a refund of some kind as they were sold as working and i got a message back saying she was at the hospital with her son. TMI if it's true.
Reply 12228 of 59961, by seob
No you where right. It's not vga, but mcga. Very close related to vga, that why a lot of vga games will work. But it's mcga graphics. I had to breakaway 1 pin in my vga cable to be able to connect it to my vga monitor.
Reply 12229 of 59961, by PeterLI
IBM PS/2 Model 30 8530 8086: MCGA
IBM PS/2 Model 30 286 8530 80286: VGA
Reply 12230 of 59961, by carlostex
@HighTreason
If the Maestro 32/96 had a real OPL3, it would be simply the best card for DOS games. Its still a card far better than the AdLib Gold, although the CQM FM synthesis on the AWE is going to be more competent than what the Maestro has to offer.
Reply 12231 of 59961, by HighTreason
The machine I plan to install it in doesn't really use FM very often so that doesn't concern me too much. I have used cards with that Crystal chip before and did always find the FM a little bit scratchy on them and the SBPro always sounded like it was playing through a piezo-speaker.
@devius; Aye, I've heard they can be problematic, no doubt it will spit the dummy out with me because that's they way things go for me, even stuff that's meant to be easy always puts up a fight when I go near it. That's half the fun of messing with this stuff I suppose.
Reply 12232 of 59961, by nforce4max
Just bought a Intel-AL440LX board that has the Yamaha OPL4-ML option for $30 with free ship. Can't wait to give it a try.
Reply 12233 of 59961, by carlostex
I must be losing brain cells at an astonishing rate. I meant AWE64 Gold.
Reply 12234 of 59961, by stamasd
Well I will find out after I receive the motherboard, if I ever manage to make it work.
FWIW I found a ISA riser for it as well, but it costs 3x what the motherboard itself cost me. haven't pulled the trigger on this one, I first want to make sure the motherboard isn't dead.
Also, would you know where I can find some documentation on the system 8530/286? I haven't been able to find any. A hardware maintenance manual would be nice. 😀
I/O, I/O,
I/O, I/O
Reply 12235 of 59961, by rein_ein
Got lucky at flea market:
Super 7(this time for sure) GA-5AA with bulged caps but posting good - 1.5$
Nintendo GameBoy DMG-1,not in good condition,but working at least,comes with 3x cartridges - 4,5$
And traded one of my 4gb ddr2 registered sticks for this X-Fi
Reply 12237 of 59961, by wbc
$12 with shipping (quite expensive, but nevermind)
This Trio3D/2X is sooo great in 2D (excellent VBE 2.0 support and image quality + it's compatible with nearly all games\demos) that I'm even planning to replace my Matrox Millennium I 😀
(yep, some bugs like high gamma or improperly working 360x??? modes are still here but I'm writing a TSR to fix them)
--wbcbz7
Reply 12238 of 59961, by Artex
Got this Socket 940 board + FX53 for $25! A new build is in the works... 😀
Reply 12239 of 59961, by stamasd
Man, I'm still mad at AMD for what they did to socket 939/940.
I mean, they launched the pair as *the* socket(s) for the future, that would be supported with new processors for a long time... So I saved money for a while and built a rig, expecting to be able to upgrade it for a number of years... and then 6 months later they dropped it, no more new CPUs for 939/940. I was so upset. Insread of having to buy just a CPU, in order to upgrade later I had to buy CPU+motherboard+memory. Especially annoying since socket AM2 differed from 939 by just one pin. Guess they learned some tricks from Intel along the way... 487SX anyone? :p
I/O, I/O,
I/O, I/O
