amd k6-2
First post, by cnpr
Hello everyone, does any one know if the motherboard ga586hx version 1.56 support the k6-2 processor? think about going to 350 mhz.
Reply 1 of 13, by kaputnik
Nope, not right out of the box. There are modded bioses available, but you also have to do some mods to the voltage regulator to get the right voltage.
Reply 3 of 13, by cnpr
I was afraid of that. I really don't want to mod it though. What is a good ss7 board to get? I only found a few on ebay.
Reply 4 of 13, by Rhuwyn
I am partial to the Asus P5A and P5A-B depending if you want ATX or BabyAT.
Other Good ones...
Gigabyte GA-5AX (Especially REV 5.2)
DFI K6XV3+/66AOpen AX59 Pro
They are definatly getting harder to find.
Reply 6 of 13, by brassicGamer
+1 for the Asus P5A (I have the B model, which is AT). I have also used the IWill XA100 with some success but I noticed some performance issues compared to the Asus that I didn't get around to investigating further.
Reply 7 of 13, by Sutekh94
Can't forget the Gigabyte GA-5AA... basically the AT version of the GA-5AX.
My YouTube | My DeviantArt
Reply 8 of 13, by Agent of the BSoD
FIC PA-2013 is the one I use. Very good board. Unless it's rev 2.1, you can't put in a high power demanding AGP card, like the Voodoo 3, though I just use PCI cards anyway.
Pentium MMX 233 | 64MB | FIC PA-2013 | Matrox Mystique 220 | ESS 1688 | Music Quest MPU Clone | Windows 95B
MT-32 | SC-55mkII, 88Pro, 8820 | SB16 CT2230
3DFX Voodoo 1&2 | S3 ViRGE GX2 | PowerVR PCX1&2 | Rendition Vérité V1000 | ATI 3D Rage Pro
Reply 10 of 13, by Tetrium
HighTreason wrote:
I figured as people are saying board models and such, I should put in a good word for the Chaintech 5AGM2.
I never used a Chaintech Socket 7-ish board, but Chaintech's 6BTM Slot 1 BX boards I found to be really impressive somehow. We got a whole lot of these to build older rigs from (charity work) and luckily my boss was an idiot who thought these were useless as they were too slow, so I got a box of these boards.
These 6BTM's were great to work with at work, but also back when I started actually using them. I really don't understand how hardly anyone knows about these? I'm not a Slot 1 expert, but I don't really see how these are worse than ASUS P2B?
And sorry for diverting from the Socket 7 talk here, but I don't often see Chaintech mentioned a lot 🤣
My retro rigs (old topic)
Report spammers here!
Reply 11 of 13, by PARKE
They even look the same, and ditto for P3B-F 😀. I have a CT 6BJM (S370 version) here that runs on a 1GHz chip with no problems whatsoever. Somebody on the 'Lunchbox' site reports a successful overclock with a C1.0A on this board. [[http://www.oocities.org/_lunchbox/tualeron_su … cess_table.html]] #8
Reply 12 of 13, by Tetrium
They aren't too similar in how they look though...well..in as much as Slot 1 boards can look different 😜.
I used a s370 build for my Celeron 800 rig and it ran pretty much effortlessly. Only gripe I had about that board was it's cramped free socket area (had to find a good but small CPU HSF). I don't remember which board it was...could actually be a Chaintech as well.
And to get back at the original question: 1 more vote for GA-5AX (I think mine was an earlier revision, 4.1 or so?? But it ran perfectly fine).
Reply 13 of 13, by candle_86
Big fan of my Epox MVP3C2
