The 100% via biuld? Thoughts/ideas?
Reply 40 of 45, by matze79
A PIII 733 will clearly kill even a 1,4Ghz VIA C3 Core.
(Except Hardware RNG and Encryption (AES..))
Note that many C3's only have a 1/2 Clock FPU.
Samuel 2 and Erza: 800Mhz Integer, 400Mhz Floating Point Unit.
That means, get at least a Nehemiah.
Reply 41 of 45, by Jade Falcon
Rank BANNED
BANNED
Yeah that was my thoughts. But a Nehemiah at 1.4ghz is a much different cpu then the older c3 in terms of how they preform.
The C3 is kind of a grab bag with performs, some apps they out do a celly, other apps and a 500 something celly will kill the c3, even a Nehemiah.
Reply 42 of 45, by Rhuwyn
@Tetrium Nice list of Tualatin compatible boards.
Reply 43 of 45, by Tetrium
yw 😀.
Alexanrs has helped tremendously with getting the Tualatin motherboard page up and he made the sortable table and without him neither of us might have actually decided to compile that list, he deserves to be credited as well 😀.
And this way we can learn from each other, which has made great things happen here for the benefit of all 😁
My retro rigs (old topic)
Report spammers here!
Reply 44 of 45, by Jade Falcon
Rank BANNED
BANNED
Got the cuv4x today. I popped the 1.2ghz c3 in the system and it booted up!
It's id as a pii but that's not a problem so long as the cars on the l2 is set right.
Reply 45 of 45, by ynopot
Greetings. Will VIA C3-800MHz 1.25v (AG60AB1S) work on DFI CA64-TC (VIA 694T)?
I'm worried about 1.25v.
