Fastest Windows XP System
Reply 100 of 121, by archsan
y2k se wrote:
I don't have much of one since I haven't researched them much. It seems the general idea is the 1080 beats the 980 and 980ti by a decent margin. The only question I really ask myself is if I ought to hold out for some 1080ti thing. Part of the challenge for me is that iRacing is only now in a beta stage for a DX11 engine, so its hard to know if the 1080 will be enough for me. 5760x1080 @ 144Hz is a bunch of pixels and I might want to go to 27" monitors, so that would be 7680x1440 @144Hz.
Hmm the 980 Ti's already sold out, so at least someone thought that that was a fair price. Anyway, I'm going to wait for proper benchmarks (this is what I mean, e.g. 780Ti over 980, 580 over 680 etc). Also rumor has it that the 1080 Ti won't be the full GP100 either, but GP102 variant. Yeah, right... must protect Titan's exorbitant prices. 🙄 (edit -- Oops, make that Tesla & Quadro! Next Titan probably on GP102 as well) The bright side is that the new cards would have at least 8GB vram which is obviously very usable for rendering.
Re: your 3-display setup, I wonder, is something like this supported: [16:9][ 21:9 ][16:9] or wide/ultrawide/wide?
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
Reply 101 of 121, by y2k se
You can using something like SoftTh to do that, but I think there's a performance hit. Nvidia's built in solution requires the same resolution and some modes also require the same connector across the monitors. My 3 in surround are connected by DisplayPort and the 4th by DVI.
Tualatin Celeron 1.4 + Powerleap PL-IP3/T, ASUS P2B, 512 MB RAM, GeForce 4 Ti 4200, Voodoo2 SLI, AWE64, 32GB IDE SSD, Dell 2001FP
Reply 102 of 121, by nforce4max
That crap turned me off to Nvidia a good ways back when Kepler first came out, if I was money bags I would probably go full Quadro. If you want to see something really expensive just look up FTK (digital forensics software) and see how much that costs 🤣, makes those Quadros look like a bargain 😲
At least FTK doesn't suck unlike Encase (projectile vomit). The UI in Encase is cancer...
Reply 103 of 121, by Robin4
PhilsComputerLab wrote:
The 560 Ti is a great card. Quite easy to find second hand and great performance and power efficient. I prefer the value / mainstream cards over high end. So all the x60 cards like the 460, 560 and 660. They are much cheaper and easier to find.
A lot more testing needs to be done, but the XP games I tried all worked fine.
Which driver version did you used for that 560 TI on windows XP?
Reply 104 of 121, by PhilsComputerLab
It was just a brief test and I used the driver that the Nvidia website gives you, so quiet a recent one.
YouTube, Facebook, Website
Reply 106 of 121, by candle_86
Why does it turn you off? Would AMD have survived GTX 680 if it was GK110? I don't think so. Imagine the 700 series up against the HD7000, AMD wouldn't have made it. Be glad Nvidia holds back on consumer it's useful to our wallets to let AMD compete
Reply 107 of 121, by SPBHM
I think GK110 was not quite ready for launch at the time the 680 was launched? they could rush things and end up with another GTX 480 or worse? which they didn't want to repeat? I think we started to see the first GK110 cards being sold like almost a year after the first 7900s... even the professional cards..
also... the gap from the 7970 GHz to the 780 was significant but... not all that amazing even at launch, it would be more like 4870 vs GTX 285 sure, but AMD could manage that because I don't think the 780 and the 7970 GHz would be sold at the same time for the same price, they would adjust prices accordingly, also, it's funny how much better the Radeon has aged, on newer titles it's not uncommon to see a 7970GHz matching or even beating the 780
Reply 108 of 121, by y2k se
Robin4 wrote:
Guessing it was a gameworks driver?
368.22 is the current driver for 500 series cards on Windows XP. I think I have 365.10 or 365.19 on my XP system.
Reply 109 of 121, by PhilsComputerLab
Gameworks doesn't ring any bells, sorry.
Now, what about AMD. My fastest AMD card is a 6770, I really like that card. A single 6 pin connector, decent performance and nice and quiet. But it's slower than a GTX 285.
Now I don't know all the AMD model numbers, what faster AMD cards are worth checking out and good value?
Reply 110 of 121, by nforce4max
5870 and 6970 are pretty cheap if you want something decent but GCN era cards are faster however I haven't gotten around to buying any to see how well they working with xp. If you just want bragging rights and have a half decent case and psu hunt around for a 5970 (dual gpu) for less than $100 usd shipped. 6990 and 7990 are often pricey.
Reply 113 of 121, by y2k se
y2k se wrote:
The XP system paused on NASCAR Racing 2003 Season. Every setting in the game is maxed and I've got 8x AA with 16x Anisotropic enabled in Nvidia's control panel. The worst frame rates I've seen so far are around mid 90's.
I increased AA a few levels and started getting fps drops into the 50's, so I've swapped the 560 ti for a spare 660 ti I had sitting around.
Reply 115 of 121, by Imperious
It's easy to get confused with AMD's model numbers as they played marketing games after the 5850/5870 series.
Esentially it went like this
3850 < 4850 < 5850 < 6950 <7950 same for the 3870 to 5870 to 7970
The 5770 and 6770 are just about exactly the same card, and pretty much the 7770 isn't much better
6850/6870 turned into 7850/7870
r9-270x is the same GPU as 7870 and so is the r7-370
I currently have a r9-270 which has one 6 pin pcie connector. The 270x has 2 and overclocks better.
Reply 117 of 121, by dizzydevil
Hello everyone!
Has anyone tried evga x390 dark with Windows xp support?
There is an installation with various nuances.
Will such a system work fully for games?
Support for Kepler video card or x-fi sound?
Reply 118 of 121, by Warlord
I mean Kepler is pretty old and is already fully supported on XP. So assuming you got XP to instal with modded ACPI, I see no reason it wouldn't work. evga z390 doesn't have any PCI slots. So Idk what XFI card you are going to run. Maybe better question is what is the compatibility issues with a PCI-Express XFI and windows XP. Personally I heard it is shit.
Reply 119 of 121, by darry
Warlord wrote on 2021-03-07, 20:46:
I have a legacy PCI X-FI card (SB0460) in a PCI Express slot (using a PLX based bridge) and use it in Windows 7 and 10. I do only use it for listening to music and some recording . For those uses, it works fine . The board is a Supermicro X8SAX .
