Voodoo 2 SLI Issue
First post, by MrEWhite
So, I have 2 Voodoo 2 Black Magic cards, when I disable the second card and try to run Unreal Tournament at 800x600, the game has pink artifacts on the screen. I took the second card out at the artifacts disappeared pretty much (again, this one was disabled). Is this an issue with my cards or something else? Removing the SLI cable fixes this issue, but I think it still shouldn't be happening.
Reply 2 of 23, by chinny22
I would also double check with another game, ideally something that doesn't use the Unreal engine. (will confirm its not a game/driver issue)
So you have tried each card separately with the other removed completely from the PC. (will confirm which card if any are faulty)
If both cards work fine by themselves but not in SLI, I would try my luck making another SLI cable, much cheaper easier to replace then a voodoo card
Reply 3 of 23, by Tetrium
Is the pink artifact a static block on your screen? And if so, does it change position when you change resolution?
In that case, it might be a memory chip.
My retro rigs (old topic)
Report spammers here!
Reply 4 of 23, by MrEWhite
It was on textures across the entire screen.
But it only happened with one card disabled and only with the SLI cable in again. So, could this be a software issue?
The cards work fine in SLI, I was just doing some testing and came across this issue.
And the same issue is in Quake 2. But again, both the cards work by themselves completely fine, and in SLI. It's only when I have the SLI cable in and I disable a card it happens
Reply 5 of 23, by stamasd
Swap the 2 cards around (move each to the other's slot) and test again.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 6 of 23, by MrEWhite
Still happens.
Reply 7 of 23, by psychz
Is it an original cable? If not, check its length/quality. I used to get weird artifacts on single card mode (not this one, but random artifacts that weren't there when testing each card separately) when my homemade SLI cable was somewhat longer than the stock cable they shipped with the cards back then. Maybe these artifacts weren't so apparent in bigger resolutions, however I'd swear everything was fine at 1024x768.
Stojke wrote:
Reply 8 of 23, by MrEWhite
It's one of these http://www.ebay.com/itm/SLI-Cable-for-3DFX-Vo … s-/131817328341
Reply 9 of 23, by chinny22
Am I missing something why would you even want to do that? Isn't any SLI drawbacks is there?
But the fact Quake does it as well means its not the games fault. Which drivers you using? some of my computers seem to prefer the fastvoodoo others only like the official drivers.
PS $10 for a sli cable! Its a fair price but good money for a simple floppy cable hack
Reply 10 of 23, by MrEWhite
chinny22 wrote:
Am I missing something why would you even want to do that? Isn't any SLI drawbacks is there? But the fact Quake does it as well […]
I've tried fastvoodoo and the official.
I was just doing some testing in framerate and graphic difference for my own personal use. Can anyone else test their Voodoo 2s and see if this happens?
Reply 12 of 23, by Tetrium
Could you post some pics perhaps?
Of the artifacts and the hardware involved?
Optional is to try the set of Voodoos in another board.
Reply 13 of 23, by adalbert
This is what hapeened on my Voodoo 2 12MB (when it was used as a single card). It had two pins of processing unit shorted and one SMD resistor missing plus missing SMD ceramic capacitor. It wasn't detecting full amount of memory. Fixed the shorted legs, soldered new resistor and capacitor and it works fine. Maybe you should look for missing (damaged, detached) components around SLI port.
    351.9 KiB
    512.56 KiB
Reply 14 of 23, by MrEWhite
Before I post pictures of the issue, I just noticed the RAM chips don't share the same speeds. Could this be the issue?
And, apart from the RAM chips, they both look fine after a visual inspection.
Reply 15 of 23, by Munx
Mine have mismatched speeds and I'm not having any issues
My builds!
The Underdog - The budget K6
Reply 16 of 23, by MrEWhite
Right now I'm trying a Diamond Monster Voodoo II 12MB (If I can get mismatched SLI working) with both of the cards to see if it presents issues.
Reply 17 of 23, by PhilsComputerLab
You can try under-clocking the cards?
YouTube, Facebook, Website
