The model of the drive is Plextor PX-20TSi
I got hold of the appropriate cable and installed the drive in a DOS 6.22/Windows NT 4.0 machine with a Sound Blaster AWE64 audio card. However I still cannot get CD audio to work in DOS.
It works fine in Windows NT so it's not a problem with the cable.
The drive is fully functional in DOS apart from CD audio. The CD Player for DOS 2.25e program (CDP.ZIP) reports error #3 ("unknown command") when an attempt is made to play an audio CD.
Does anyone know what the problem could be?
ETA more information: This is the PX-20TSi model with the 68-pin connector not the 50-pin connector. (There are at least two versions of this drive.) It's connected to the computer's integrated AIC-7880 SCSI controller.
ETA2: Here are pictures of the 50-pin model. Note that the bezel is different. The CD audio connector is also different.
The attachment s-l1600 (2)_crop0.jpg is no longer available
The attachment s-l1600_crop1.jpg is no longer available
The attachment s-l1600 (1).jpg is no longer available
ETA3: Here is the manual for the 50-pin model: http://bitsavers.trailing-edge.com/pdf/plexto … nual_199702.pdf
Take care that the document hosted on manualzz.com and manualslib.com is incomplete. It only contains 20 numbered pages. The full manual has 80.
"AI Requires Proof That You Are Human"
