First post, by Kahenraz
- l33t
I've been searching for a while and the closest I could find was the Supermicro P6SBA which only supports up to 100Mhz FSB. Are there any Tualatin boards with 3 ISA slots?
wrote:I've been searching for a while and the closest I could find was the Supermicro P6SBA which only supports up to 100Mhz FSB. Are there any Tualatin boards with 3 ISA slots?
If you really want 133MHz FSB, Tualatin and ISA, then you might better do yourself a favor and simply use a BX board and overclock it.
3 is asking for a lot. You could always go all MacGyver with ISA extensions, I guess.
Native Tualatin support? , I dont know of any but if you use a slotkit , or adapter, the later 440BX boards will run fine and you do get them with 3 ISAs
But why 3x isa, only thing I can think of is video editing card, but there are better PCI verients for those...
Edit: The Supermicro P6SBU Comes to mind.
wrote:Native Tualatin support? , I dont know of any but if you use a slotkit , or adapter, the later 440BX boards will run fine and you do get them with 3 ISAs
So I can LAPC-I/SCC-1/SB16. Slockets are acceptable as I have Tualatin-compatible ones. I just want to be sure I get a board which supports it.
wrote:Edit: The Supermicro P6SBU Comes to mind.
Like the P6SBA, there are only jumpers for 66 and 100Mhz bus speeds:
http://www.manualslib.com/manual/325001/Super … be.html?page=21
Hmm your right, only 100mhz FSB, you can still use one of the Celeron Taulatins with the correct slotkit, there is one thats 1.4ghz at 100mhz fsb , tradoff is 256kb cache, and it will say Celeron instead of Pentium
Edit: You will need a powerleap slotkit or similar http://www.powerleap.com/pdf_files/PL-iP3T.pdf
wrote:Celeron Taulatins with the correct slotkit
It's senseless, as Coppermine 1000 on 133 MHz should not to work meaningfully slower in games than Tualatin Celeron 1.4.
wrote:wrote:Celeron Taulatins with the correct slotkit
Thats true , but OP said he wants to use a Tualatin supported board.
wrote:Thats true , but OP said he wants to use a Tualatin supported board.
He wants Tualatin for more performance.
DFI had a board too "DFI CA61", has 133mhz FSB acording to the manual, its a Via Apollo 133a chipset so shouldn't be too bad, but Ive never used one of these boards. Its a good candidate for a pin modded Taulatin, you can get them on ebay or do one yourself, it works well on my Apollo 133a Gigabyte board....
wrote:Hmm your right, only 100mhz FSB, you can still use one of the Celeron Taulatins with the correct slotkit, there is one thats 1.4ghz at 100mhz fsb , tradoff is 256kb cache, and it will say Celeron instead of Pentium
Doesn't answer the question directly, but the Celeron 1000A is a great overclocker and has 100Mhz bus.
wrote:LAPC-I is most suitable for a 386 and the SCC-1 fits a 486 or Pentium nicely.
So there is a reason a high powered Pentium III board usually doesn't have any ISA slots 😀
Although a motherboard of this sort would be great for a VIA based DOS slowdown machine (which brings ISA MIDI cards back in play).
IPOX IP-3ETI23 is a Tualatin capable motherboard with 3 ISA slots. Technically is an old industrial motherboard, but it fits what Kahenraz was asking for...
http://www.bwi.com/document/603
http://mediaserver.voxtechnologies.com/FileCa … 431830-wm-2.png
wrote:IPOX IP-3ETI23 is a Tualatin capable motherboard with 3 ISA slots. Technically is an old industrial motherboard, but it fits what Kahenraz was asking for...
I can only imagine what the price on that board would be or if can even be found.
Motherboard Reviews The Motherboard Thread
Plastic parts looking nasty and yellow try this Deyellowing Plastic
Ok Its Actually not to bad
http://www.ebay.com/itm/IPOX-IP-3ETI23-for-Pe … 38AAOxyGwNTEIlm
Nice find!
The AGP slot isn't keyed though. Any idea of its universal?
