First post, by Jade Falcon
Rank BANNED
BANNED
The fallowing motherboards support Nehemiah.
Gigabyte GA-6VLE
http://valid.canardpc.com/p2jnlf
Gigabyte GA-PCV2-CSI/DSI
http://valid.canardpc.com/show_oc.php?id=259985
Gigabyte GA-PCV2C-SI
http://valid.canardpc.com/show_oc.php?id=2521488
Gigabyte 6OXT
http://valid.canardpc.com/show_oc.php?id=2244066
Asus TUSL2-C
http://valid.x86.fr/7geucq
Asus CUSL2
http://valid.canardpc.com/tk3flv
Asus CUV4X
http://valid.x86.fr/c50f6x
Abit i815E-W83627HF (cpu-z error could be any i815 abit board)
http://valid.canardpc.com/show_oc.php?id=518404
ECS ref.NO:G320-yymmdd-OT-01-00-FF-FF$ (I think thats a laptop)
http://valid.canardpc.com/show_oc.php?id=512258
VIA EPIA-M
http://valid.canardpc.com/show_oc.php?id=1240568
I'll add more when I get the time. I'll make one for all other via c3's as well,
Reply 1 of 8, by Tetrium
I'm not sure if you're aware of this, but VIA actually had a VIA C3 compatibility list (even though it doesn't mention which exact C3 core is supported by which board). There's a copy on Vogonswiki here, maybe this will help you a bit 😀.
My retro rigs (old topic)
Report spammers here!
Reply 3 of 8, by Tetrium
Tertz wrote:
Which of these boards have ISA slots is also important to note, as the advantage of C3 is compatibility with DOS games.
Theres another list which mentions s370 boards with certain features, like Tualatin support and the presence of ISA slots here.
I did start to compile a list of VIA C3 compatible boards and Tualatin capability or ISA slots somewhere on this forum, but it was quick & dirty and I never bothered to finish that list.
I don't think that by simply using both lists one can get a comprehensive list, there's probably also motherboards out there which do work with C3, but are not listed on the VIA list and possibly also motherboards that are listed, but need certain features (like a newer BIOS or a certain board revision) that may be unavailable at this time.
Reply 4 of 8, by Tertz
The most interesting are fast C3 (Ezra 1000, Nehemiah 1200) practically compatible MBs with: Intel chipset + ISA and preferably AGP too. And working combinations of C3 compatible slotkets with other boards with similar traits.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 5 of 8, by Jade Falcon
Rank BANNED
BANNED
I am aware, but that list does not state what boards work with Nehemiah cpu's and is not quit complete. Like how many slot one boards are on that list?
I'm going to make this list more complete once I get the time. I don't see why such a list needs to have isa, agp and chipset. That info is readily advable. But I can add that once I get the time.
Reply 6 of 8, by Tetrium
Yes I know. Information is sketchy when it comes to which C3 variant is actually supported by which exact boards.
Will be interested in seeing your list nearing completion 😀.
Reply 7 of 8, by Jade Falcon
Rank BANNED
BANNED
For now I'm going to work just on Nehemiah. When I run out of resources I'll work on the others.
I'm probably just going to stick with cpu-z validations for the most part. I'll make a spread sheet once I get a good list going too.
I'm sure a well made full list will be very useful for some of us.
Reply 8 of 8, by Tetrium
Jade Falcon wrote:
For now I'm going to work just on Nehemiah. When I run out of resources I'll work on the others. I'm probably just going to stic […]
I tend to agree, would be very useful 😀
