First post, by rubenerd
Hey guys, before I pour tons of hours into researching this, does anyone remember if there was ever a DVI graphics card with Windows 3.1x drivers? Or did DVI come too late?
Basically the desk in my tiny new apartment can't fit two sets of peripherals 😢 , so looking to build a KVM setup. If I could get a DVI card for this old Pentium 3.1x/95 tower, I could have it on the same unit as all my other machines.
I learned the hard way DVI KVMs universally use DVI-D, so passive DVI to VGA passthrough adaptors won't work. It's a real shame, I have the keyboard and mouse working with a ton of adaptors.
Reply 1 of 12, by nforce4max
I don't think that anyone has brought this up before but I have my doubts as the support for 3.1 stopped sometime around the TNT2 and Voodoo 3 era.
Reply 2 of 12, by keenerb
Don't some cards with VGA/KVM mirror both interfaces by default?
If so, maybe a generic VGA/VESA driver might work?
Reply 4 of 12, by happycube
There are affordable VGA->HDMI converters that should work with any card, but I don't know if they work with LCD monitors and/or can even be made not to do scaling.
Reply 5 of 12, by vetz
TNT2 is also an option. Came primarily with AGP DVI, but it has the drivers.
PCI option also available, but hard to find:
GB Riva TnT Pro (Gateway Wallace AGP DVI-Out) CT5828
Reply 6 of 12, by candle_86
actually really easy, get an active VGA to DVI adapter, they exist. The only catch is they need power usually provided by USB, so you will need to hook the USB portion up to a USB port possibly with a USB Extension cable
https://www.amazon.com/StarTech-com-DVI2VGAE- … r/dp/B00C93JQXS
Here is one I have used. You can put that on the back of the KVM and your good to go. The Active part means it will convert the signal between analog and digital itself.
Reply 7 of 12, by happycube
That adapter converts DVI-D into VGA, which is the wrong direction in this case...
Reply 8 of 12, by candle_86
Should work both directions
Reply 9 of 12, by NJRoadfan
Most Matrox G400 cards support a DVI output daughter card. They have full Windows 3.1x drivers with on the fly resolution switching. I can confirm the DVI output works with the drivers as well.
Reply 10 of 12, by vetz
I haven't got the DVI working in DOS mode with the Matrox cards. Only Windows.
Reply 11 of 12, by NJRoadfan
Odd, mine always worked fine in DOS with the DVI board. Its a Matrox Marvel G400TV card with the DVI daughter card FWIW. Matrox did release a DOS BIOS update for these that I might have flashed a long time ago. If I recall, it addressed DOS support for the TV output, who knows it might have fixed the DVI output too.
Reply 12 of 12, by swaaye
Old DVI cards tend to be picky about monitor compatibility and it can manifest in various ways.
