Reply 12540 of 58958, by TheAbandonwareGuy
brassicGamer wrote:
Seller's pic and no details given in listing but pretty self-explanatory for anyone with half an idea: […]
- Rage 128
- Voodoo 3 3000 AGP
- Sparkle S3 Trio64 V2/DX
- Something currently unidentifiable (probably MX440) x2
- MX440
- 3D Rage Pro
- Creative Annihilator CT6970 (GeForce 256)
- STB Nitro 3D/GX
All for £4.99
Where are all these GF256's being found? ive been searching ebay everyday for 3 months looking for one. Posted ads on amibay everything.
Reply 12541 of 58958, by nforce4max
- Rage 128
- Voodoo 3 3000 AGP
- MX440
- 3D Rage Pro
- STB Nitro 3D/GX
All for £4.99
So have I and while there are some what few there are most are junk or overpriced and not worth the time. Some here happen to live in areas where this stuff grows like grass and streets are paved with gold top pentiums /face palm
Just keep looking or sub in something even if it is not period accurate.
Reply 12542 of 58958, by Unknown_K
Geforce 256 were not easy to find even a long time ago. If you recall the first models were SDRAM then came the faster DDR variety. Cooling on them sucked (cheap fans) so I expect they died from heat or not too many people bothered to get them till T&L games were common and Geforce 2's were out (or Radeons).
Reply 12543 of 58958, by brassicGamer
I've been buying job lots of cards for a number of years now and this is the first one i have encountered. I know sometimes it feels like time is running out to find certain items but, as others have said, patience and smart searching are the best way. It's the only way to find popular items for low prices. Ebay listings without complete descriptions and without item names in the heading are how i find most of my stuff and this requires searching through hundreds of ambiguous listings on a daily basis.
Reply 12544 of 58958, by Nvm1
Got one last week locally from Asus for €12 including postage, it's the V6600 Deluxe AGP version with box, 3d glasses and manual/drivercds. This is the SDram version so not top of the line but I couldn't let it slip through my fingers for that price 😈
Reply 12545 of 58958, by devius
orinoko wrote:
Good news is they have a Yamaha audio chipset, if memory serves right, and they can be plugged into into an external display, and make for a great DOS gaming machine!
That is correct. Although I don't know the exact Yamaha sound chip in it, it's probably something from the YMF71x line, considering it was detected as OPL-SAx. Everything else also works fine and it's in great condition considering it's age. It looks as though it was used for maybe a year and then put aside for a long time. Too bad the screen isn't better, otherwise it would be pretty close to the perfect laptop for 90's DOS games.
As for GeForce 256's, I also got one of those (the DDR version actually, Asus V6800 DDR) in a relatively cheap bundle. The only 3Dfx Voodoo I have was also part of a cheap bundle. That's the only way to find less common hardware for cheap, but it's usually a lot of work and you have to search through lots of listings full of TNT2 M64's and GeForce MX's. Usually when something is very well described and listed properly the sellers know what they have and try to charge as much as possible.
Reply 12546 of 58958, by chose007
3 months? Thats nothing if you want things like this 😀 Maybe reason that I bought all last 3 years which were for sale. Iam joking ... only have 5 pieces and not searching more this time.
Today some new gold park at me. First Pentium and some LSI cpus? Dont know what is it.
Reply 12547 of 58958, by candle_86
I'm hoping its a Voodoo Banshee, I think it is
The attachment WP_20160622_14_54_17_Pro[1].jpg is no longer available
The attachment WP_20160622_14_54_29_Pro[1].jpg is no longer available
Got from ebay
Reply 12548 of 58958, by Rhuwyn
candle_86 wrote:
I'm hoping its a Voodoo Banshee, I think it is […]
Got from ebay
It is I got one just like it not long ago.
Reply 12549 of 58958, by nforce4max
Got from ebay
It is and do not try to remove the cooler or you will break it, I had two of this exact card and destroyed one. The thermal epoxy used is very different from the white stuff and it is Strong! Try to remove it and you will crack the plastic encapsulation and kill the gpu. Gateway sold a few of these in their systems but it is made by ELSA (I think) so it is of good quality but still gets scorching hot so just add a fan.
Reply 12550 of 58958, by nforce4max
- Rage 128
- Voodoo 3 3000 AGP
- MX440
- 3D Rage Pro
- STB Nitro 3D/GX
All for £4.99
Went scrounging earlier today and found a number of them as Dell versions including a GF3 Ti all for less than $15 usd. There wasn't much else.
Reply 12551 of 58958, by candle_86
Got from ebay
No worries there, if it works I let well enough alone. It should compliment by k6-3 nicely
Reply 12552 of 58958, by BloodyCactus
picked up a 3com 503 8bit isa with rj45 jack for my 8088 build, its known this card works on 8088 which is nice.
Reply 12553 of 58958, by Jade Falcon
Rank BANNED
BANNED
Got from ebay
If you freeze the heat sink and or card then that take a screw driver to the card it will come clean off.
I done that plenty of times on 3dfx cards.
Reply 12555 of 58958, by Stojke
Just don't use play-doh on it.
Reply 12556 of 58958, by candle_86
Jade Falcon wrote:
If you freeze the heat sink and or card then that take a screw driver to the card it will come clean off. I done that plenty of […]
Got from ebay
I have zero wish to take the heatsink off
Reply 12557 of 58958, by Imperious
Got a few motherboards today. Acer XT mainboard Ebay purchase. The other 2 are Socket 478 533fsb ACER/FOXCONN 651M03-6L, and AMD socket 754 ENERGY SIS760GX-MN.
The last 2 I believe were specifically aimed at the OEM market and not generally available to the public. I bought them mostly for a bit of tinkering, but don't expect overclocking
will be possible. $15 for the both NOS.
Reply 12558 of 58958, by MrEWhite
-cringe-
Reply 12559 of 58958, by stamasd
That XT clone looks nice, but it appears to only have 576kB RAM (256kx2 + 64k)
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
