Glide help
First post, by Oldskoolmaniac
So i have a voodoo3 2000 pci card Ive tried this card in so many motherboards and glide dosnt seem to work right in the gog versions of Unreal Tournament and Dues ex G.O.T.Y.
whenever i select glide as render device it keeps resorting back to driverclass 800x600 and stuck in window mode, but in directx i have no problems.
Ive tried th latest driver as well as unofficial drivers, even updated the bios on the card itself.
Unreal gold runs fine under glide.
Motherboard Reviews The Motherboard Thread
Plastic parts looking nasty and yellow try this Deyellowing Plastic
Reply 1 of 18, by nforce4max
I wonder what changes if any were made to those gog versions, this is why I often resort to seven seas looking for old things 😉
Reply 2 of 18, by Oldskoolmaniac
i guess ill try look for the original disc and see.
Reply 4 of 18, by Oldskoolmaniac
collector wrote:
Ask for old hardware help in Marvin.
Crap sorry my bad
Reply 5 of 18, by Stiletto
Moved to Marvin.
do the Fandango!" - Queen
Stiletto
Reply 6 of 18, by leileilol
It's possible the Gog versions think they're smart enough to slip in a Glide wrapper, so find a glide2x/3x.dll in Deus Ex/System and eliminate them. it then should use your real voodoo card
Reply 7 of 18, by Oldskoolmaniac
That is a really good point, yea ill try that.
Reply 8 of 18, by PhilsComputerLab
Yup, that's often the case. I'm pretty sure all three games come with nGlide. You will also find the nGlide config executable in the game folder, that gives it away as well.
@ Oldskoolmaniac
nGlide does run under Windows 98. If you have a high powered Windows 98 machine with a DX9 graphics card, it runs games very well, even past the performance of a V5.
Reply 9 of 18, by Oldskoolmaniac
I looked in the folder and there was an nglide.exe and that was it i deleted it and still same problems, would i have to replace glidedrv.int
Reply 10 of 18, by PhilsComputerLab
You need to delete the .dll files like leileilol mentioned 😀
Reply 11 of 18, by Oldskoolmaniac
there isnt a single dll file in any game
Reply 12 of 18, by leileilol
Because Windows is hiding them. You must unhide them in your folder options settings or something
Reply 13 of 18, by Oldskoolmaniac
Ok i feel like dummy 🤣 i found them, removed them and all is good thanks
Reply 14 of 18, by FFXIhealer
Good job to those who helped. Retro gaming win!
Reply 15 of 18, by Oldskoolmaniac
Ok so i have something i just notice for this same card direct3d is disabled in dx6.1a, is it cuz i have a pci version?
Also i can run any version of 3dmark cuz of this.
Reply 16 of 18, by leileilol
You should be able to use Direct3D on any 3dfx card.
3dm2001 will be fussy on <V2 however (no DX7 driver support for Voodoo Graphics), 2003+ will not run at all on any Voodoo.
Reply 17 of 18, by Oldskoolmaniac
I have directx 6.1a it came with windows98, im thinking i might have to redownload the drivers
Reply 18 of 18, by Oldskoolmaniac
It was cuz i was using these drivers: 3dHQ V1.09.00 Beta10 for some reason it only half installed on my gateway, but on my p3 rig its fine so I just installed the latest official and all is well.
