Perception of speed
First post, by snorg
So if a raspberry pi is about as fast as a Pentium II 300....why does it not feel as fast? Is it because I've been spoiled by modern machines? Code bloat? It certainly does not feel as fast as a PII 300 felt back then. For instance, I'd have a hard time using a bog standard raspberry pi model B/B+ as a desktop, but I had no problem using a PII 300 as a desktop back in the day. Is it a disk access thing? Internet? Something else?
Reply 1 of 26, by PeterLI
The question is what was the benchmark used? Very narrow CPU / FPU only or overall performance? This is where there are often deviations between a narrow benchmark and reality.
Reply 2 of 26, by Errius
I assume that Windows 98 is less demanding than any variety of *nix?
Is this too much voodoo?
Reply 3 of 26, by leileilol
I'd assume common *nix libs are bloated with a high memory footprint for the sake of security, hampering the slow CPUs. More buffer overflow checks than optimized functionality to keep the Debian list happy. Should be no different than watching Doom crawl in DamnSmallLinux on a Pentium.
Supposedly the GPU is supposed to overcome the CPU performance with specially optimized games for GLES, though GLES isn't perfect for everything. That Q3 port is much slower than running Q3 on a P2-300 with W98+V2, especially with Q3's inefficient use of textures. (and OA is much, much worse in that regard - another lesson learned the hard way)
Reply 4 of 26, by gdjacobs
Hmm... DOOM was quite quick on a P90 running Slackware, but that was 15 years ago running SVGAlib so it was essentially direct access to the hardware. X11 is a known speed problem as it was designed back in the 80s and never intended for the performance now being asked of it. Extensions like RENDER and GLX help but don't totally make up the difference.
As for libs being bloated, some are, some aren't. Fortunately it's Linux so you can choose. Darwinism at work, folks.
Reply 5 of 26, by keenmaster486
Some of the speed perceptions, especially in the GUI, might have to do with the fact that the SD card reads much slower than a hard drive.
Somebody should do various benchmarks on the new Pi 3 and see how it compares to various x86 machines.
Does anyone think it the slower DOOM might also be because that game was highly optimized for x86 systems with VGA, direct HW access, hardware paging, optimized Pentium instructions, etc.?
Should benchmarks be run on a bare-bones UNIX, Linux, or RISCOS system or something like that?
World's foremost 486 enjoyer.
Reply 6 of 26, by Scali
Pretty much yes.
Quake was a landmark in game development and Pentium-based optimization in general, and DOOM was an exercise in optimizing a raycaster for 486 and Mode X.
A lot of tricks rely directly on how the Pentium CPU and FPU work down to the instruction pipeline level, and graphics-wise you depend on VGA's unique Mode X memory layout.
Just taking a vanilla C-version of the DOOM code, and compiling it for a vanilla linear framebuffer will result in a much slower version of DOOM than the original release.
Even so, properly optimized C-code should easily run 3d code efficiently on an ARM CPU as fast as a Raspberry PI.
I wrote the 3d routines for a GP2X demo a few years back: https://youtu.be/qTgCE_TN6qw
This runs on a simple ARM CPU at 240 MHz, with no FPU and no 3d acceleration. I used no assembly optimizations here, it's just standard C, compiled with GCC.
If you can make it do that, then certainly you should be able to make a Raspberry PI run Quake 3 properly, making use of its GPU.
Reply 7 of 26, by konc
I see what you mean. For me it all comes down to this: try using now a PII 300 with modern software (as you do with the Pi) and I think you'll find it even worse.
The PII back then felt so fast because 1)It was running software of its period and 2)it was among the fastest systems available. Now the Pi that you mentioned as an example still runs period correct software, but is nowhere near the fastest available systems. Modern fast systems, even though they deal with a lot more, do feel equally fast as the PII back then, don't they?
Reply 8 of 26, by ynari
My main retro PC is a PII 300. It's plenty fast for DOS and quite fast for OS/2, but I wouldn't call it lightning fast for modern Unixes. Whilst software will still run on those systems, it's no longer optimised for them - the memory footprint in particular will be higher, and they'll expect a graphics card with a reasonable throughput (possibly not an issue if using AGP, but if using PCI...)
Reply 9 of 26, by Errius
Has anyone tried the newer pi models? Mine are 1st generation. Speed's up to 1.2 Ghz quad-core in the latest one.
Reply 10 of 26, by keenmaster486
Amen. We need a DOSBox benchmark thread for non-x86 systems such as the Pi.
DOSBox used to run at little more than bare 8088 speed on my 1st gen Pi. Haven't tried it on the newer ones. There should be ways to optimize DOSBox for Pi, though.
Reply 11 of 26, by clueless1
It's not the hardware; it's the software. Case in point: I have a Dell Dimension P3-933. I first tried a very light linux distro on it (antiX) and it felt extremely sluggish in the GUI. Then I put Win98SE on it and it felt like I was running an i7 with an SSD. The difference? modern software vs retro software.
Reply 12 of 26, by gdjacobs
If you use an older Linux release, you'll probably notice that it's quick as well. Software grows to fill hardware capability.
Reply 13 of 26, by idspispopd
Scali wrote:
Pretty much yes. DOOM was a landmark in game development and Pentium-based optimization in general. A lot of tricks rely directl […]
Pretty much yes.
Is it possible that you are thinking of Quake, or even mixing Doom and Quake?
Quake was the first id game which used the FPU and was optimized for Pentium CPUs. It can use VESA modes though.
Doom was optimized for 386/486, and it used Mode Y.
Reply 14 of 26, by spiroyster
486 = Doom & Descent
Pentium = Quake
🤣, Intel could have used that for a punchline upon the pentium release.
Reply 16 of 26, by idspispopd
Pentium = Quake
How? Do you think Quake was developed before the release of the Pentium?
@Scali: Thanks, I didn't doubt your knowledge.
Reply 18 of 26, by spiroyster
idspispopd wrote:
Pentium = Quake
How what? I Didn't think Quake was written before the release of the Pentium. I have no idea tbh, so I certainly couldn't put a specific release date to it. I didn't even know Quake was optimised for the Pentium until your post 😉.
It was a tongue and cheek joke about a hypothetical Intel marketing campaign which didn't occur in which Intel could claim their older 486 could give you the impression of Doom (literal translation) and Descent (going doooown), where as the improved Pentium could give the impression of a (((Quake))) big impact.
iirc, I played descent on a 386... so I could expand on my non-funny joke (If in deed that memory is correct).
386 = Descent (starting to go down)
486 = Doom (all boring, no MMX)
Pentium = Quake (Boom! there it is ... SIMD)
Since I had to explain it, it was clearly not very funny, so for that I apologise. 🙁
Reply 19 of 26, by Scali
Actually, classic Pentium did not have any SIMD, and Quake does not make use of it.
Pentium MMX was the first x86 with SIMD extensions (Pentium Pro also did not have it, the Pentium II is basically a 'Pentium Pro MMX').
Quake is optimized for the pipelined x87 of the Pentium.
