First post, by sombody
Hi do you use the lan on dosbox?
Reply 1 of 4, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
What do you mean by "use lan"?
There is IPX tunneling support.
Mirek
Reply 2 of 4, by sombody
if you can use the local aria network. i want to play c&c with my friends but i dont now how i get the "lan" working. i only can use the modem when i want to use the network.
thx.
Reply 3 of 4, by mirekluza
DOSBox Moderator
Read this:
DosBox Guide to Multiplayer Games
But I do not know whether C&C works or not with IPX tunneling in DOSBOX.
Mirek
Reply 4 of 4, by icemann
I think he means "is it possible to do a LAN, via having dosbox on each of the computer?"
Two stones, two crosses, the rest is just icing. - 7th Guest
