Pentium-S pci video card
First post, by 386SX
I am building a "time correct" 95/96 Pentium first edition 120Mhz (0,60u) config to "correctly" try Quake and Doom generation games. It's the lowest cpu I have for the 60Mhz fsb of the MVP3 (I have a intel older simm mobo but larger for any case I have). I used 2x32MB of sdram and a 2GB ide disk. For the vga I wanted to use a S3 old card before the Virge DX but I can't find one and miss the original Virge or previous cards so I used a Cirrus Logic GD54M30 1MB pci card. For the soundcard I used a CT2950 creative board, for the NIC a KE2000 isa card.
I tried Quake and Duke3D and they run ok (not extremely fast neither slow.. seems right), I expected the vga being slower but which other 1995-96 time correct video card would you use? Do you think the Cirrus logic I used was ok to buy or already slow back then?
Thank
Reply 1 of 10, by nforce4max
I would get an S3 and a Voodoo 1 for a late 96 build if you want to do 3D games. Matrox is a good option for windows, not sure about dos support. Cirrus logic like Trident was the bottom of the barrel even though there are a few even worse brands out there but they are rare and almost pointless.
S3, ATI, and Matrox with a 3D accelerator like a Voodoo 1 then you are set.
Reply 2 of 10, by kixs
I'd use: S3 Stealth64/Trio64, Tseng ET4000/ET6000, ATI Mach64, Matrox Millennium... Cirrus Logic 544X
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 3 of 10, by 386SX
Than for the advices! Regarding the Voodoo card, I already tried it on the Pentium 100/120 but wasn't it intended for the MMX later processors? It certainly runs as I remember (even Half life ran quiet good). I have the Matrox Millennium and it sound cool, but is it good in Dos too?
Reply 4 of 10, by nforce4max
Some people ran it on even less when it was current, voodoo 1 is really meant for p1 systems like yours 😀
Reply 5 of 10, by keenmaster486
How much does the 3D accelerator help with games such as Flight Simulator?
World's foremost 486 enjoyer.
Reply 6 of 10, by jheronimus
Wasn't Voodoo released the year before MMX though?
MR BIOS catalog
Unicore catalog
Reply 7 of 10, by 386SX
I read late 1996 almost like the release of the MMX chip, isn't it? By the way I can imagine many people using the 3d card anyway having even older Pentiums.
I have tested the Millennium PCI 4MB and it's impressive how much improved frame rate in Quake.
Reply 8 of 10, by leileilol
MMX's a very 1997 technology. It was also overhyped, as if one doesn't need a voodoo to enjoy bilinear filtering (at a ViRGE-like framerate 😜) and a web plugin of an MMX-exclusive speedboat(iirc) game.
Since you have a Millenium and Voodoo Graphics, you're already all set for high end 96 period gaming, (both definitely existed long before there was MMX and was not designed for MMX - later 3dfx driver releases added driver optimizations for mmx (and 3dnow) however)
all that's left to worry about is the sound card - the ultimate equalizer of retro PCs with huge YMMVs. IMO for 96 high end period, an AWE64 is appropriate as several 95/96 games do have additional enhanced support for the AWE's EMU8000 chip. like the hrtf-esque high quality sounds in Eradicator. and sure you could also use an AWE32 from 94/95 for those, but it'll be very noisy.
FUCK "AI"
Reply 9 of 10, by 386SX
Thank! The Milennium give me the feeling it will beat any other 2D card in both speed and quality, it seems not fair for the other video cards. 😁 The point was that with this and the Voodoo, basically the P120 seems "old". But I don't want to use a 0,35u processor, I prefer the older ones. I have the AWE64 standard but looking at build date it was already late 1997. When it was released?
Reply 10 of 10, by 386SX
One question, when the Millennium 4MB was release which were the good alternative to its performances? Did it surpass anything until than?
