First post, by TAR
Hi
I'm new to DosBox so likely this is a simple issue.
I will be grateful for any help on the following:
I've mounted C drive as C and can display the directory contents in DosBox.
I launch the program from DosBox using the bat file below, but I get the error message: "ERROR: Invalid path specified in AQT environment variable"
Then the program stops.
Thanks in advance
AQ.BAT
SET AQT=C:\AQTESOLV
AQTESOLV
