First post, by sentinelvdx
I have an old app developed long time ago by a friend which is no more with us.
Thing is that I'm trying to run it with DOSBox, but I get DOS Error 4 when trying to open it.
To be more specific this is the error message:
I'm really new on this, so any help will be appreciated.
Thanks in advance,
Reply 1 of 3, by Jorpho
DOSBox is principally intended by games, and for serious applications you should probably consider a solution such as VMware (with Windows 98) or PCem. If your application is text-mode only, you should take a look at vDOS.
In any case, this sounds like a Clipper application; there have been many threads about these before. You should try using an SVN version of DOSBox; I believe some new fixes have been incorporated since 0.74 was released.
Reply 2 of 3, by sentinelvdx
Solved!
SET CLIPPER=F250
Reply 3 of 3, by sentinelvdx
Thanks, yes, I have tried first vDOS with no success and decided to use DOSBox (which like you, I use it for my old games too).
I wanted to avoid VM's because sometimes I use it on low resource pc's and I'm not always online to use my NAS to host it.
