First post, by rick6
- Member
So, i was given 3 months ago a really cool server from 2000, and it came with really neat stuff like multi-processor board (coppermine) and 5 SCSI hard drives connected to this SCSI controller:
It's a Acceleraid170 from Mylex. I had to test it on a Athlon 3200+ because the board from the old server is still in repairs (new caps and other stuff), and while i was experimenting SCSI for the first time by navigating through the menus of the controller card (after computer post, not inside windows), the computer started acting strange going black, i powered it on it worked fine again untill it didn't power anymore if the controller card was inserted in it's pci slot. Same symptoms on other computers. Tried everything like reflow, replacing the voltage regulator but nothing works. The leds on the card come on, but the the computer won't post if the card is plugged in, only spinning fans.
So i guess that the bios chip on the controller card gave up or something else died on it.
I really wanted to play with these 5 SCSI 40GB (each) hard drives, so my question is..Was i just merely unlucky and i should i get another controller? Or is this something i should stay away from because of high failure rate?
Should i get away from the Mylex brand or are they a good brand? I'm confused about what to do next.
I already got a few controllers in mind from ebay like these:
http://www.ebay.com/itm/HP-Netraid-Storage-Co … HkAAMXQVT9SwAcK
http://www.ebay.com/itm/RAID-Controller-MYLEX … Q0AAOSwK7FWhVrB
http://www.ebay.com/itm/Mylex-Ultra-2-PCI-SCS … 4cAAOSwFnFV9TzQ
http://www.ebay.com/itm/Mylex-D040461-8E-Acce … B4AAOSw0HVWCsiH
None of these seem to be as good as the one i got before i think, but this is not my area of expertise. Would any of these be worth the shot for 5 SCSI hard drives?
