First post, by 386SX
I built this everyday main retro pc based on A7V133, 512MB @ 100 CL2, Kyro2 64MB and 10GB UDMA4 disk plus the Duron 1200 SSE cpu with Win ME. I found this config incredibly fast and still ""modern"" but measuring at the power plug I get almost 90W of wattage request. If I use another faster vga the power easily increase to 100/110W , and if I use an older one probably I will not save watts (Voodoo3 will request/dissipate more, G400 probably... maybe the S3 Savage 4? but just some watts).
So I was thinking what other cpu could I use to save power cause almost 100W fixed is quiet a lot even if the VS650 supply I have seems to not have problems with it (4,91V on 5V rail). Maybe the Duron 1000? Or some Geode Athlon based cpu? Or maybe the XP 1500+?
Thank
