Bought this (Modern) hardware today
Reply 300 of 2277, by archsan
mrau wrote:
dying light does not count! that's just spammed with unneeded bloat..
any use except for games?
Not specifically for that Radeon card, but you may want to look at why (top line) Quadros and FirePros are given such huge RAM (24GB, 32GB... and the number will soon extend dramatically with Radeon Pro's "SSG").
I think that Radeon also has support for OpenCL, so you can use it for a physics-based renderer, for example, with very high resolution output and/or very large geometry. Real-time editing or processing of video at 4K/8K and higher may also be one of the potential application of aforementioned Radeon Pro SSG. Other purposes involving GPGPU with very large datasets will also benefit from more memory of course.
Come to think of it, for some people it might be more beneficial to have much more (and faster) RAM accessible to the GPU rather than the CPU these days.
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
Reply 301 of 2277, by foey
Not strictly "bought" but replaced my GTX570 which is on its way out with a Sapphire AMD 7770 Gz Edition. Not an upgrade as such but was given to me as a frebbie! I've been using the Intel Onboard graphics on my i5 2500+ rig for sometime now - It's an improvement 🤣
Cyrix Instead Build, 6x86 166+ | 32mb SD | 4mb S3 Virge DX | Creative AWE64 | Win95
ATC-S PIII Tualatin Win9x Build :- ATC-S PIII Coppermine Win9x Build Log [WIP] **Photo Heavy**
Reply 302 of 2277, by kithylin
archsan wrote:
Not specifically for that Radeon card, but you may want to look at why (top line) Quadros and FirePros are given such huge RAM ( […]
Along this discussion, take a little look here: https://www.youtube.com/watch?v=0W-5qpLyBpA Where he discusses the practical uses (outside of games) for 8GB cards.
Reply 303 of 2277, by mrau
so according to this guy, a high res video will scroll fast because he has 8 gb ram, of which some 0,6 gb is used? srsly?
there are 4 gb cards in the price range i'm aiming at, but most have very low memory bandwidth and that's a killer usually, even though i use 3d stuff rather seldom and only dated stuff
there was a hint on some gpu product in the past, that stuff from system memory could be swapped to unused gpu memory - is there such a thing that really works?
Reply 304 of 2277, by Aideka
Well, the GPU RAM usage in that video went up to around 1200-1300MB when he started applying overlays to the video. Now think about the fact that those all were pretty low resolution still images, what do you think would happen if he used overlay video clips or more video effects?
Offloading things to GPU's is a thing that many video and image editing programs are doing nowadays, and of course you can record for example gameplay videos using the power of the GPU, and that will also use up the VRAM.
3D rendering also eats up as much VRAM as you can throw at it. For games the VRAM usage is going up all the time, especially when resolutions increase, textures get larger, shaders get more complex etc.
Reply 305 of 2277, by mrau
ok, but thats still a narrow group of users;
as for live recording with gpu power - is ati now more or less usable? with my 6670 it wouldnt give any proper results, even when it did, it was slow and quality bad
Reply 307 of 2277, by luckybob
mrau wrote:
what are You going to do with 8gb ram? thats probably half as much as main memory? can it be used for apps when not needed otherwise?
Better textures. The top-tier texture setting in doom requires 5gb minimum. That is today, it's not going to go down once 4k becomes more mainstream.
Reply 308 of 2277, by ODwilly
I have bought two of those exact cards for friends of mine in the past. They do really good in stuff like Far Cry 3, newer stuff not so much but as long as you play in low resolutions and/or low to medium settings they still seem to do well.
Reply 309 of 2277, by m1919
Got one of my single-PCB GTX 295s in.
Not really modern but not quite retro yet. Got a project these will be going into in the next few months.
Crimson Tide - EVGA 1000P2; ASUS Z10PE-D8 WS; 2x E5-2697 v3 14C 3.8 GHz on all cores (All core hack); 64GB Samsung DDR4-2133 ECC
EVGA 1080 Ti FTW3; EVGA 750 Ti SC; Sound Blaster Z
Reply 310 of 2277, by FuzzyLogic
That card would go well with my replacement MSI P45 Platinum. Orc overload.
Reply 311 of 2277, by Dreamer_of_the_past
kithylin wrote:
Like this block, I need the metal backplate for it that's ordered from a different company and will arrive wednesday. This water block by the way really is solid copper inside, block alone weighs 440 grams on the scale, and with the mounting hardware it comes to 580 grams. I'm -NOT- putting that sideways on a motherboard without a backplate, too much weight.
I finally pulled the trigger and purchased the HEATKILLER® IV PRO as well. This thing is heavy indeed. Which backplate did you go for? Why not the one from Watercool? And why do you prefer soft tubing versus hard tubing? Because in my opinion hard tubing looks much prettier and cheaper too.
Reply 312 of 2277, by ODwilly
Bought a couple shady power supplies for $20 each from a friend. An Apevia 700watt and a raidmax scorpio 535watt that is aupposedly 80 plus bronze. Kind of hesitant to trust these
Reply 313 of 2277, by kithylin
Because rigid acrylic tubing requires expensive set of tools to work with. A whole set of cutting tools and melting tools. And you have to heat it up, melt it, bend it, let it cool.. and there's no bending it back if you get it wrong.. etc, etc, etc. It's all just a mess. Flexible tubing you just do it once and it's easy to push and move around, and the tubing is reusable indefinitely (just ship off the smooshed bits on the ends, re-use). I went with the official Heatkiller backplate of course, just PPCS didn't have it in stock at the time and had to order it from https://modmymods.com/ The chrome / nickel plated Heatkiller IV Pro block gets like -3c cooler than the copper one fyi, in multiple different tests on different websites, so I went with that one.
Reply 314 of 2277, by m1919
It's happening.
Waiting on this baby to get shipped.
Reply 315 of 2277, by kithylin
m1919 wrote:
It's happening. […]
It's happening.
Looks like Intel skulltrail? I hope you got it cheap... those things use a ton of power and run rather hot.
It's weird seeing a desktop motherboard in a server chassis too. Totally "custom" job there.
I would think almost 99% that it's not the original motherboard for that chassis.
Reply 316 of 2277, by luckybob
@m1919
Reply 317 of 2277, by mrau
luckybob wrote:
@m1919 […]
@m1919
you take your horns off for love?
Reply 318 of 2277, by luckybob
WUT?
Reply 319 of 2277, by mrau
