First post, by coolhaken
Hi all,
I dumped an old BASICA game from a floppy with heavily mold.
After several times of try, there were still 4 bytes corrupt (2EE7~2EEA).
I dumped 5 times and compared every copy, then upload the best one.
Also, this BASICA program is in protected format.
Anyone can help me to recover this program or give me some suggestion ?
Thanks a lot !
    21POINT.7z
    13.8 KiB
    62 downloads
Reply 1 of 3, by Jorpho
Since it's only four bytes, my first inclination would be to find some means of somehow iterating through all combinations until the correct values are found.
But searching for <basica protected> suggests there are other means of unprotecting a BASICA program.
http://www.chebucto.ns.ca/~af380/GW-BASIC-tokens.html#pgwbp
Something called UNPBAS11 also comes up.
Reply 2 of 3, by ZanQuance
Let me fix that for you:
Here you go
[edit]Changed it to ascii mode instead of unprotected program binary mode
    21POINT.zip
    5.21 KiB
    67 downloads
    Source Code
