ZOOL 2 on DOSBOX jams
First post, by PpGibon
HELP! play ZOOL 2 at level 4, I get to a point where the game has jams, try install a different of dosbox, even bought the game on the disc. I do not know what to do
Reply 1 of 4, by Jorpho
The word you're looking for is "freezes".
It's difficult to provide assistance without more details about what you are doing. Did you follow the 60 Seconds Guide?
60 seconds guide to getting your game to run in DOSBox
You should also try an SVN build of DOSBox, as there have been many fixes made since 0.74.
Reply 2 of 4, by PpGibon
ITS WORKING JUUUUPIIIII THEN YOU SO MUCH I LOVE YOU
Reply 3 of 4, by PpGibon
I do not understand, I have launched the game once, I wanted to try a second time and go back to the beginning, Game or will the little disk space either does not see the drive
Reply 4 of 4, by Jorpho
I don't really understand what you are trying to say.
As discussed in the 60 Seconds Guide, you have to mount the directories the same way both before and after installation. If you mounted C:\GAMES as drive C when you installed the game, then you have to keep mounting C:\GAMES as drive C (and not C:\GAMES\ZOOL2, or wherever you installed the game).
