First post, by computergeek92
I have some of my family’s old computers with heapleads of files scattered throughout. It would be easier for me to find good cloning software because some of the drives have bad sectors and I don't want them to fail while I take off the files. Can you help me find an easy to use cloning software please? The machines are from various computing eras, so something that works even on old DOS machines would be great! Thanks for any help.
Dedicated Windows 95 Aficionado for good reasons:
http://toastytech.com/evil/setup.html
Reply 1 of 10, by Jade Falcon
Rank BANNED
BANNED
UNIX live cd and dd command.
Reply 2 of 10, by Jo22
Or this one. http://damien.guibouret.free.fr/en/index.html
Older versions of True Image may also work (7.x,9.x and maybe later ones, too).
As far as I know, their "safe mode" found on the live media is based on DOS.
Reply 3 of 10, by Zup
My favourite tool is Acronis True Image, and/or Clonezilla. Clonezilla can run on every computer (they have ISOs that only need a 386).
Keep in mind that those programs are imaging tools (as you requested), so getting a given file from an image will need special tools.
I'm selling some stuff!
Reply 4 of 10, by Jorpho
I don't follow the logic here. Cloning is a more intensive process and probably more likely to cause a drive to fail than "taking off the files".
I had a recent experience in which I learned that pretty much all drive-cloning programs are likely to give up immediately upon encountering an unreadable sector.
Anyway, for something that will work on older systems, http://ping.windowsdream.com/ would probably be the way to go.
Reply 5 of 10, by Jade Falcon
Rank BANNED
BANNED
Jorpho wrote:
I don't follow the logic here. Cloning is a more intensive process and probably more likely to cause a drive to fail than "taki […]
This is why I recommend dd. Lot of options there. Copy the files or the file system.
Reply 6 of 10, by luckybob
I just use winimage. Even works for non-windows backups. never had an issue.
Reply 8 of 10, by leileilol
Manually skipping makes that a pain for any mass imaging use though
Debian's fucked
Reply 9 of 10, by luckybob
I dont image often. Maybe 5 times this year.
Reply 10 of 10, by Jo22
That's as often as I do take a shower.
(Edit: That was a joke..)
